Old 17th March 2012, 00:14   #3016
normally_crazy's Avatar
Thanked: 544 Times
re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by jatinpatel View Post
Hello all,
As i had mentioned it before on the thread that i would be doing the bulb upgrade to 100w for Hi-beam which has bulb no.9005 as no upgrade options available for 9006 no bulb except for Extreme Vision which i already have.
So finally today got the bulbs of Hi-beam upgraded to 100w 9005 HB3 costing 650 per piece along with relay and wiring the bulb is of Navara company of Germany its OEM to Bmw and Merc.
The bulbs which came out of the hi-beam position were philips extreme vision 60w with bulb no 9006 which after little bit of mods to the bulbs manage to fit them inside the low-beam and coupled with the new 100w Hi-beam the difference is SUPERB!!
Total cost to me was
650x2 for bulbs = 1300
Relay + wirring + sockets + labor =1500
Total =2800rs am not counting the cost of Extreme vision here as i already had them.
but just for record each bulb of extreme vision is 475rs.
Will let the pics do the talking, dont know how to add text before each pic so
1st pic All Lights OFF
2nd pic Low Beam having 60w Philips extreme vision
3rd pic Hi + Low + fogs
4th pic Hi + Low + fogs to give depth of view of light throw
5th pic Bulb box.
@sdking
The extreme vision were improvement over the absolute blind and rubbish stock bulbs but yet didn satisfy 100% it satisfied me only 70% but current setup am very much satisfied.
Looks better than stock in the pictures. Lets change my set up on Monday
normally_crazy is offline   (1) Thanks
Old 17th March 2012, 01:14   #3017
danlalan's Avatar
Thanked: 281 Times
you have a civic?
when were you going to tell us.
danlalan is offline
Old 17th March 2012, 09:32   #3018
Thanked: 544 Times
Originally Posted by danlalan View Post
you have a civic?
I don't know what to say. I have the Civic since almost an year and a half ! LOL
Old 17th March 2012, 11:50   #3019
Akshay1234's Avatar
Thanked: 12,919 Times
you have a civic?
He already told us
http://www.team-bhp.com/forum/test-d...le-whammy.html
Akshay1234 is online now
Old 17th March 2012, 20:40   #3020
Thanked: 544 Times
Originally Posted by akshay1234 View Post
Thanks Akshay. Dan - there is a LTR here as well
Old 18th March 2012, 13:01   #3021
danlalan's Avatar
Thanked: 281 Times
Just had a look at that. Same year as mine. Ive just done 20 k kms. Time for another CIVIC Meet/ drive
danlalan is offline
Old 19th March 2012, 09:28   #3022
Thanked: 30 Times
Has anyone tried changing the interior lights with the LEDs? Can someone guide on the options available and how they rate?
swarooppatil is offline   (1) Thanks
Old 19th March 2012, 11:59   #3023
Thanked: 30 Times
the exact model no for the Philips Extreme Vision is
HB3-9005
HB4-9006
bought these and also got them fitted at Pai Automobiles santacruz(w).
Hope this helps if anything more then keep posting
Checked with Pai Auto, Santacruz. They informed that the Xtreme Visions are not available in the Philips Spec lamps i.e. 9005/9006. The person said for Civic they have only in Essential Power which is 30% more light.
Old 19th March 2012, 20:32   #3024
jatinpatel's Avatar
Thanked: 196 Times
Am sorry to all i created a confusion from my side just rechecked the boxes of the upgraded same wattage bulbs it says
Philips Premium Lighting 30% more light
these are available for 9005 and 9006 spec bulbs.
jatinpatel is offline   (1) Thanks
Old 20th March 2012, 20:49   #3025
sumeethaldankar's Avatar
Thanked: 3,686 Times
hi guys,
I started my Civic today and was idling the engine for a while, i turned the steering a bit left/right and as i was doing same i observed the tacho needle rose a bit and the engine sound grew a bit louder.Is this normal ? i understand the power steering is powered by the engine but will it cause the tacho needle to rise when turned at idle.The needle did not actually rise very high or something but sort of twicthed when i turned the steering a bit.
thanks
sumeethaldankar is offline
Old 20th March 2012, 21:28   #3026
laluks's Avatar
Thanked: 16,486 Times
Could it be that your fan got switched on and you saw a small increase in rpm from 800 to a 1000+ and back?
laluks is offline
Old 20th March 2012, 21:44   #3027
dot
dot's Avatar
Thanked: 734 Times
sort of twicthed
It is pretty normal, specially during cold starts.
dot is offline   (1) Thanks
Old 20th March 2012, 22:43   #3028
Thanked: 76 Times
Have noticed it even during parking while engine is hot as well.
ramanak is offline   (1) Thanks
Old 20th March 2012, 23:04   #3029
Thanked: 544 Times
hi guys,
thanks
Thats pretty normal - cold or hot ! Don't worry !
Old 20th March 2012, 23:18   #3030
gaurav_chopra04's Avatar
Thanked: 574 Times
Pretty normal with Hydraulic steering. The steering pump is powered by the engine and hence the rpm will increase when you are using the steering on idle. In fact, you will hear a proper whin when you lock the steering on each end (left or right).
gaurav_chopra04 is offline   (3) Thanks
