Old 21st August 2013, 14:34   #436
manikjeet's Avatar
Thanked: 296 Times
Re: Mercedes W124 E Class Support Group
I checked in Chandigarh and I am Unable to find one. I checked a junked car as well but it was in worse condition.
Can you please help me with a link on the E bay preferable from India like you did for the Fuses. ( I got them delivered Thanks).
Chandigarh Junkyard (Burail) dont seem to have Merc parts.
I am checking out the repair kit.
manikjeet is offline
Old 21st August 2013, 14:44   #437
Viraat13's Avatar
Thanked: 3,419 Times
Originally Posted by DeepakMenon View Post
.. if steering wheel then the contact ring..
What can I do to fix this? Really annoying in my E220. It's the steering contact ring for sure. Thankfully only comes up while parking or at parking speed, but it's plenty loud.
Viraat13 is offline
Old 21st August 2013, 16:05   #438
DeepakMenon's Avatar
Thanked: 182 Times
Try Ebay.co.uk tonnes of them available
Viraat; you will have to open the steering wheel and clean the contacts.. check google lot of info on how to do it
DeepakMenon is offline   (1) Thanks
Old 21st August 2013, 17:09   #439
manikjeet's Avatar
Thanked: 296 Times
No one is willing to ship it to India.
Old 21st August 2013, 20:09   #440
Thanked: 182 Times
http://www.ebay.com/itm/Mercedes-w12...497a16&vxp=mtr
http://www.ebay.com/itm/Mercedes-w12...01c27f&vxp=mtr
http://www.ebay.com/itm/Mercedes-w12...e69dee&vxp=mtr
Old 23rd August 2013, 22:07   #441
Thanked: 74 Times
I cleaned mine, quite easy. Make sure you take precautions to ensure Airbag does not deploy. Removing the steering was tricku, but doable. Lubed and cleaned the contact ring.
benz220 is offline
Old 24th August 2013, 00:43   #442
Viraat13's Avatar
It's been cleaned, but it was a while back. I don't think it was re lubed. What grease do I use? Shall I just use synthetic white grease?
Viraat13 is offline
Old 24th August 2013, 02:36   #443
Thanked: 74 Times
Use a light grease, and just wipe it on with very little residual, as the contacts should not be compromised. White grease should be OK.
benz220 is offline   (1) Thanks
Old 24th August 2013, 22:53   #444
Thanked: 74 Times
I have Yokohama C Drive on my car in stock size. They're excellent! Comfortable, with plenty of grip.
OK, time to put on new tyres. Choices are Yokohama A Drive or Continental? Any pros and cons. Sticking with stock size 195/65/15.
benz220 is offline
Old 25th August 2013, 13:38   #445
Viraat13's Avatar
My 300E has A drives, but those aren't the stock size. E220 has C drives. Both the Yokohama's get a little noisy at speeds above 130. But otherwise can't complain. C drives lasting really well. Easily looks like a set that will last 35K kms with ease. Not particularly expensive, so there is that too.
Viraat13 is offline
Old 26th August 2013, 16:52   #446
manikjeet's Avatar
Thanked: 296 Times
I have two new problems with my car.
I got a replacement coolant bottle but the bottle was not the end.
My cars radiator is have a small leak from the top. Now What should I do I am not finding any original BEHR radiators and don't want any repo parts.
Also the battery drainage issue came back and I have tired everything.
Will get a kill switch installed as a last resort.
Using XM1+ on my car 205/65/r15 loving them.
Old 26th August 2013, 18:50   #447
Thanked: 651 Times
I got Yoko AVS DB V550 in OE size, expensive but great tyes.
I earlier had 205/65/r15 which gave a better stance but I feel the steering is much better with OE.
vikramvicky1984 is offline
Old 26th August 2013, 23:05   #448
Viraat13's Avatar
The upsides tyres look nicer, but the stock is much better in every way — ride, handling, steering feel.
Viraat13 is offline
Old 27th August 2013, 10:16   #449
Thanked: 3,031 Times
..l
Get the radiator serviced. In Delhi, they take the radiator out, unsolder the top and bottom tanks, clean the tanks, check the pipes for leaks and seal them. They also check pipes for blockage and clean that if feasible. Then they assemble the radiator and check it for leaks. This assumes that your radiator is copper and not steel. Once done the radiator is good enough for at least five years of trouble free service.
Aroy is offline
Old 27th August 2013, 11:34   #450
manikjeet's Avatar
Thanked: 296 Times
Thanks for the advise. But can somebody please tell me how to find out if the radiator is steel or copper
