Old 22nd October 2020, 16:27   #3466
Thanked: 108 Times
Re: The Home Theater thread
HI friends. Need a little advise
My TV (49W800G) has HDMI slots and a coaxial out. While my sound bar will take accept coaxial input it also has a optical input slot. Can I someway do a HDMI to optical connection?
Elito11 is offline
Old 22nd October 2020, 16:30   #3467
Sree73's Avatar
Thanked: 1,012 Times
You can use a coaxial RCA cable. TV has coaxial output and sound bar has coaxial input. That's one option.
Also, there are converters for HDMI to optical & coaxial output. But, generally little costly. in the range of 2 - 2.5K
Sree73 is offline   (1) Thanks
Old 22nd October 2020, 16:53   #3468
Thanked: 108 Times
Thank you! What do you suggest sticking with the coaxial or getting a converter? I have no STB and run this tv purely on Internet
Elito11 is offline
Old 22nd October 2020, 17:01   #3469
Sree73's Avatar
Get a coaxial cable. That's the better option.
Old 22nd October 2020, 17:06   #3470
Thanked: 108 Times
Thank you! Can you please explain why though? The tv supports HDMI ARC and I feel like i will be missing out..!
Elito11 is offline
Old 22nd October 2020, 17:18   #3471
Sree73's Avatar
First of all, you do not have an HDMI input in your sound bar. If that was the case, would have given good quality.
The option of using HDMI to Optical/coaxial conversion is there, but still will not have much improvement over Digital coaxial cables.
So, the best feasible option is coaxial.
Old 22nd October 2020, 17:28   #3472
Thanked: 108 Times
First of all, you do not have an HDMI input in your sound bar. If that was the case, should have been given good quality.
Yeah, to much hassle for the converter. Will stick with a coaxial cable. Thanks
Elito11 is offline
Old 23rd October 2020, 12:47   #3473
Thanked: 978 Times
Thanks for your reply, the 9.2 Receivers are above 1-1.5 Lacs, I am more than glad to upgrade probably I am not looking at the right place, could you share the source which you are using for prices?
Pramod
Just came across this deal on HiFiMart on the LX 303 9.2 CH AVR. At 66k INR its a sweet deal and I highly recommend you consider it. Have never come across this sort of a pricing on a 9.2 AVR.
https://hifimart.com/product/pioneer...receiver-html/
vjbox is offline
Old 27th October 2020, 00:41   #3474
pramodkumar's Avatar
Thanked: 2,268 Times
pioneer
First choice is Yamaha
Second is Denon
Last is Onkyo
Pramod
pramodkumar is offline
Old 27th October 2020, 05:20   #3475
sandeepmohan's Avatar
Thanked: 6,056 Times
There is a reason for that. It is soon to be replaced with the LX304. Also; it might barely push 35 watt with all 5 channels driven. At 9 channels, it will probably be a less than that. With that in mind, your speaker options narrow down to the ones with higher sensitivity, which may not always please your ears. Expansion is not possible by means of a external powered amplifier, if you crave for more power.
Having owned a VSX-1122, I can say that Pioneer does get their sound signature spot on for home theater but they lack in outright grunt.
Old 27th October 2020, 07:59   #3476
bigron's Avatar
Thanked: 2,715 Times
Any 9 channel AVR in that price range be it the Denon X2500 or the Marantz 50XX/60xx, is not going to pump out more than 50/60 watts in 5 channels or 30/35 in full 9.2 set up. The difference is mostly in the auto room calibration software that they employ. They all are cookie cutter black boxes at the price. Pioneer does employ the efficient class D amps in their higher LX models though.
My SR 7012 is also mostly used as a pre utilizing all those advanced algorithms mated to external amplification. Now my old school Denon 4806 was a different 50 pound plus beast altogether with quality transformers inside.
Having said that, a modern 700 and up USD AVR has enough power for most home theater users. People very often overestimate their need for extra amplification in HT setups.
bigron is offline   (2) Thanks
Old 27th October 2020, 08:23   #3477
Thanked: 978 Times
True. I always wonder the wattage obsession with consumers. As though they want to bring the whole roof down with the sound. Right amount of wattage with room treatment will do the magic and that combination is always overlooked!
vjbox is offline
Old 27th October 2020, 08:26   #3478
Thanked: 978 Times
pioneer
Second is Denon
Last is Onkyo
Pramod
Ah I see. But have you heard these modern Pioneers ? They aren’t that bad when compared to similar competition. You just got to pair them with the right equipment and have decent room treatment (applies for any setup) I suggested this one based on your budgets and like I said earlier you can always settle down for 7.2 CH AVR too from other manufacturers in the similar price bracket.
vjbox is offline   (1) Thanks
Old 27th October 2020, 08:50   #3479
The problem with AV receivers is that they seldom achieve what the manufacturers claim in terms of their ratings. To advertise the amplifier as 170 watts per channel (In the case of the LX303) is misleading. In no scenario will the amplifier be operated as mono and in most home theater applications, you need to estimate the minimum as 5 driven channels. Without quality power, you can't get the best out of your speaker.
Old 27th October 2020, 09:06   #3480
bigron's Avatar
Marketing my friend marketing.
160 Watt per channel sounds very enticing to unsuspecting first time buyers. Also discounting that the rating is at 6 ohms and not even 8.
Very few AVR manufactures will give you 5/7 channel rating.
I know Anthem does it ( had an older model). I think Arcam does it to. But none of these mainstream Denon/Marantz/Onkyo etc do.
No body likes the sound of '60 watts per channels, 5 channels driven' in promotion literature.
bigron is offline   (3) Thanks
