Team-BHP > Motorbikes
Old 16th October 2008, 10:42   #136
Thanked: 9,255 Times
Aha! Finally the filters have arrived. It was lying at the post office since last three days! I will post the pictures soon.
Sankar is offline
Old 16th October 2008, 12:54   #137
SunnyBoi's Avatar
Thanked: 4,462 Times
The filter i ordered is a lot bigger than the R1100 but then it's a foam filter.
Pardon my ignorance but what filter did you order?
SunnyBoi is offline
Old 16th October 2008, 13:59   #138
praJEEP's Avatar
Thanked: 12 Times
I presume its a UNI filter.
praJEEP is offline
Old 16th October 2008, 14:07   #139
Yep it's an UNI, but an Australian UNI FILTER, not the American one.
Sankar is offline
Old 16th October 2008, 14:39   #140
praJEEP's Avatar
Thanked: 12 Times
Whats the difference between australian and american one ?
How much did you get it for ? any duties paid ?
praJEEP is offline
Old 16th October 2008, 15:27   #141
Here are the photos of the filter. The contents are: 1) Air Filter, 2) Air filter wrap, 3) Breather pod filter and 5) The Filter-Fix oil.
Except for the brand name, UNI & UNIFILTER i don't think there's any major difference between these two makes. They are different companies, Australian is cheaper and the foam actually feels sturdier than the UNI i had before.
Check out their website here: Unifilter Australia Foam Air Filters for Economy and Performance
Sankar is offline
Old 16th October 2008, 19:05   #142
fieroid's Avatar
Thanked: 306 Times
Mount this directly on the carb man. Whats the cost?
fieroid is offline
Old 16th October 2008, 19:18   #143
The flange ID is too big, 63mm. I'll have to adapt something or get another one imported if i'm to fit it on the carb directly. I got this one to use with the tube. Lemme see how it is.
Airfilter kit (Filter, Wrap & Oil) = AUD 41.36
Breather pod = AUD 6.59
Shipping = AUD 18.18
Customs didn't charge any duty
Btw, Joel are u sure than without TPS connected the ignition timing would be advanced? If that's the case then how is the bike able to pull high RPMs easily, with an advanced timing revving up would feel tight isn't it? I don't have a timing gun to get it checked, nor do i have access to one.
Sankar is offline
Old 17th October 2008, 00:42   #144
muneemmk's Avatar
Thanked: 99 Times
Where is that breather pod going to be used on ? the filter seems like a bargain for that price.
muneemmk is offline
Old 17th October 2008, 10:04   #145
I have installed the filters last night. I retained the pipe from the carb, but removed the airbox completely. 63mm ID is a trifle large (i messed up with the measurements), 60mm would've been correct. I did not take any photos last night as my hands were messed with sticky filter oil. I'll take and post photos today, if possible.
muneem, the breather pod goes into the the crankcase ventilation pipe. With stock setup it goes into the airbox.
Sankar is offline
Old 17th October 2008, 15:43   #146
how did u manage to fit a larger dia filter on to the carb sankar since u mentioned 60mm would have been perfect???
gt_mustang is offline
Old 17th October 2008, 15:55   #147
I installed the filter not to the carb directly but on to the black pipe. I removed the airbox but left the pipe in place. I used duct tape to bring the OD of the pipe to match the ID of the filter. It's a nice snug fir now. Duct tape is pretty strong & thick so it worked well.
Sankar is offline
Old 18th October 2008, 10:17   #148
Here are the filter installation photos. As you can see i have retained the stock curved pipe, the filter is mounted on the pipe. You can also see the breather pod installation. I have tied em with a nylon string as i ran out of cable ties.
From the initial riding impression the filter seems to have really improved the performance, midrange to top end is strong. I have upjetted to 140 mains and 40 pilot.
Sankar is offline
Old 18th October 2008, 10:59   #149
Technocrat's Avatar
Thanked: 2,705 Times
Looks good Sankar.
How much difference has all these mods made from the totally stock bike?
Technocrat is offline
Old 18th October 2008, 11:53   #150
praful's Avatar
Thanked: 769 Times
2 questions :-
1. You mentioned this nearly the exact replica of the KnN R1100, can you tell me whats the product code for this Uni filter?
2. Is the Breather Pod necessary?How does it help? Any disadvantages?
praful is offline
