Old 30th March 2021, 22:56   #2386
Thanked: 1,971 Times
Originally Posted by abhatt View Post
Thanks for all the suggestions. Can you help me understand the usage of dash cam? From what I understand 1) Helps with evidence in case of an accident 2) Capture beautiful driving shots
1. What is Parking Mode useful for?
2. Do I need GPS module?
There are 2 70mais on Amazon.
1. Option 1
2. Option 2
Which one would you recommend?
Also, I hate hanging/dangling wires. I hope, it can be fitted without harming the internal looks and it stays that way over time.
I like TPMS but I don't want another display on the dash. I was planning to get this
I got a car cover for my Polo which is unused. I have a good basement parking space however this year had to stay in my home town where it was parked on the Road however I forgot my car cover in Bangalore. Is there a cheaper alternative or should I buy the one offered by Jeep?
Your reasons for having a Dash cam are correct. Additionally if Parking Mode is enabled them it can record video while your car is parked and someone messes with it, useful if your parking area is susceptible to people fiddling with your car.
Option 1 is the one without GPS. So it won't record location and speed information with the video.
Option 2 does the above things as it has an inbuilt GPS.
I would suggest Option 2.
Regarding wiring, there are two ways. First you can power it using the supplied Cigarette Lighter Adapter and route the wire through the A Pillar and then across the roof lining till it reached the rear view mirror. Then you can bring it down and plug it in. It comes out quite neatly provided the installation is done correctly and diligently.
Second option is to hard wire it using a Fuse Tap adapter. You will need to reach through to the Fuse box which I understand is beside the Glove Box towards the door. I have never opened that area. Rest of the wire routing will remain the same.
I would suggest using the cigarette lighter adapter.
Also buy from 70mai.in as they are cheaper than Amazon. Disclaimer: They claim to be offical 70 Dealers for India. I have never bought from them , although I plan to buy from them soon. I have no association with them whatsoever.
Traveler is offline   (1) Thanks
Old 1st April 2021, 20:41   #2387
Thanked: 624 Times
Re: Jeep Compass : Official Review
Originally Posted by luvurride View Post
Well if you frequently drive around dusty roads, you will keep getting it. I have been facing the same in my Octavia and now X1 as well. When you get a good water service done, it cleans up the dust around the pads and the squealing noise stops only to come back after a few days of run on dusty roads. Unfortunately, Bangalore is cursed with bad roads and there is no way I can avoid this. The phenomenon also occurs when you do long trips for few days without a wash.
Thanks for pointing this out, the last 100m approach road to my society is now just dry mud/sand due to some pipework being done. I got the car thoroughly washed, especially the wheels and the noise went away.
Turbolove is offline
Old 1st April 2021, 20:45   #2388
Baddychat's Avatar
Thanked: 280 Times
Originally Posted by Iceman33 View Post
Guys, I recently brought 4X4 automatic. Done some 2K so far, mostly on highways.
Planning to go to Spiti this summer but really worried about the low ground clearance.
Can someone suggest solution to this GC problem? One way could be adding some steel underpinnings. Any reference for a good mechanic to do that in Delhi?
As Behemoth mentioned, the Compass should easily make it to Spiti.
I had a question though. What OEM tire came with your Limited Variant. Only thing to consider is if you plan to do serious off roading there on HT tyres. Otherwise for a regular Spiti run you need not bother.
Baddychat is offline
Old 2nd April 2021, 09:54   #2389
Apologize for butting in. I also have 4x4 Limited Plus and it comes with Bridgestone Turanza T01 tyres. The size is 225/55 R18 . Unfortunately there is no AT tyre available in this size in India at present.
The stock tyres are not at all capable of going off-road. The low profile will result is sidewall getting ripped apart incl case of rocky terrain.
I took it up with FCA too but did not get any satisfactory answer. They were just beating about the bush and said that for off-roading one should buy the trailhawk.
When I pointed out that even the Trailhawk came with Firestone HT tyres, they never replied. Infact I had to correct them that Trailhawk came with HT tyres whereas they were claiming it came with AT tyres.
Really sad state of affairs, marketing and selling a true blue SUV with 4x4 and off-roading capabilities but putting HT tyres on them.
Old 2nd April 2021, 10:07   #2390
Pancham's Avatar
Thanked: 3,160 Times
Are you sure? Because the New Compass' brochure says that all variants come with AT tyres. This includes the Firestones.
Pancham is offline
Old 2nd April 2021, 10:18   #2391
If they have changed to AT then Kudos to them. However I highly doubt it. As far as I know there is no AT tyre available in 225/55 R18 in India. I checked just this week.
Traveler is offline
Old 2nd April 2021, 10:21   #2392
I just checked the brochure. It says All Season Tyres and not All Terrain Tyres. It's the same as earlier. No AT tyres.
All season tyres are not AT, these are normal tyres. Infact all tyres sold in India are mostly All Season. We don't have Special Winter Tyres which are needed for sub zero temperatures and are used in colder countries.
Traveler is offline
Old 2nd April 2021, 10:26   #2393
Pancham's Avatar
My bad. That was a sorry miss on my part. This is clearly a cost cutting measure I guess. But I want to understand this better. If there is no AT tyre available in India for that size, will Jeep need to out of their way to source such tyres/import them? If yes, will they not land themselves in a soup due to the import ban or any import issues?
Pancham is offline
Old 2nd April 2021, 10:38   #2394
There are capable manufactures in India who can easily make these tyres. The issue is Jeep should be willing to sign up with them. MRF Wanderer and Apollo Apterra both have AT treads and have local manufacturing facilities.
Also the import ban allows special sizes to be imported. My guess is that 225/55 R18 is a special size and should be allowed to be imported.
This is pure lethargy on part of Jeep that they don't take the initiative to get this done.
Old 2nd April 2021, 18:10   #2395
Baddychat's Avatar
Thanked: 280 Times
I also own a LP and am aware of the acute shortage of options for this size.
Moreover the government's Atmanirbhar program has put a temporary stop on import licenses being made available to various manufacturers/distributors.
Since he had mentioned that he drives a Limited variant, hence I had asked the question regarding the tyre size. Limited has 17 inchers and I think there are AT options like Falken available for that size.
Old 2nd April 2021, 18:40   #2396
Thanked: 1,803 Times
You should have asked FCA why are they offering 4x4 on the Limited Plus if they do not want you to take it off-road
BTW Trailhawk comes with Falken Wildpeaks, not Firestone. Yes, they are H/T but they are very very good, and their feel and tread pattern is closest that an H/T can come to an A/T. I changed to the Falkens last year, and have done 7000 kms on them on the most punishing of terrains without them breaking a sweat.
Unfortunately they do not come in Limited Plus size, plus these tires are imported, so there is a supply shortage. My advice to all Compass owners is to try the Falken Wildpeaks, if they can get their hands on them
achyutaghosh is offline
Old 2nd April 2021, 21:03   #2397
I did exactly that. Their answer was for offroading please buy Trailhawk that comes with AT tyres 😂
Traveler is offline
Old 5th April 2021, 12:30   #2398
Thanked: 192 Times
Hi all, been stalking the thread for a while now. Landmark Gurgaon says that Anniversary edition is sold out and that they are cancelling bookings. Jeep says it’s still in production, you can book it! Meanwhile landmark says they can give me a blue/silver anniversary edition diesel auto! Seems like the dealer is pushing inventory, but there’s simply no way to get hold of reliable information from any source. NCR members- any idea what’s the actual situation?
philipmathen is offline
Old 5th April 2021, 19:21   #2399
jeeplife_newbie's Avatar
Thanked: 34 Times
Hi, my SA in WSL Chandigarh told me that FCA has told them today to stop taking any more bookings for the diesel manual and diesel automatic variants of the anniversary edition. Petrol automatic is still available.
jeeplife_newbie is offline   (1) Thanks
Old 5th April 2021, 21:53   #2400
Thanked: 192 Times
Thanks, but does seem that some limited stock available. But colour choices are limited
