Originally Posted by Jash2709 1. So I assume that there has to be constant gear shifting to be always in the right power band? Is that tiring at times? Also what do you have to say about power delivery on ghats and sudden overtakes?
2. From my last test drive, the compass can't take half clutch-ing, the car simply stalls. I think post 2018 it was their way of solving the clutch plate issue. I know it's not a good habit in the first place but I feel almost everyone is used to it. How did you get by it considering you drive two diesels?
3. This is probably the most crucial question! After Sales! Jeep has somehow a notorious name for this. I have read posts citing that sometimes the service teams take months together to fix issues. I have been driving a Honda Civic 1.8 and a couple of Marutis so I can say that I have been pampered! And then there are JC clutch and battery issues. Please let me know how your experience has been so far
I extensively read your posts about the rattle jugaad and the boot capacity issue. Those are some great insights. Thank you for that. The reason for getting an SUV is road tripping across India and considering the roads here, sedans can be a nightmare and mini anxiety attacks. So it all boils down to smart packing I suppose. Also, the variant I am planning to buy will cost me about 30+ lacs on road. Despite the lovely interiors what scares me about Jeep is that i can't take a 30 Lac car making noises like my Vitara Brezza.
The reason for asking these questions is that there only so much that you can get to know through test drives and that too in a cramped city like Mumbai.
Anyway! I have just joined the community and it's been lovely!
Can't thank you guys enough for all the help! |
Welcome to the community and happy to help!
Let me address you queries quickly:
1) Not really, you don't need to shift gears more frequently if you are driving between 0-40 (Typical city traffic), however if you are driving 0-60, you will end up having to shift to 3rd and then 4th, and it is something that you get used to and I don't even notice it anymore. On the Highway, between 70-90 speeds, you can stay in 4th and also overtake easily. In the Jeep, I find that the ideal rpm to shift gears is 1900 rpm, at which the torque is also close to its max and the torque is maintained till around 3000rpm, after that it tapers off. If you want maximum mileage the ideal shift range is 1900-2500 rpm. If you want max power range, the shift range is 2500-3000 rpm. There is no point revving the engine higher as it starts to be vocal after 3000 rpm and you also won't make quick progress as the torque drops off. This is typical for many common rail directed engines in this class and displacement these days. Driving a diesel engine car is quite different from a Petrol engine one.
But the high torque at lower engines of Diesel engines is quite addictive and you do get a nice push once you get the hang of it and they are quite fun to drive.
2) Half clutching is something that diesel engines (both my cars) do not like at all ! When you slow down for speed breakers, its better to shift to first gear and take it slow. Both the Laura and JC don't like been taken over big breakers in 2nd gear. They can both do it, if you release your foot from the accelerator and also from the cutch fully - they will go over the breaker as the anti stall programming prevents stalling in this condition, but it tends to speed up suddenly and it kind of jumps over the breaker, resulting in a bumpy ride for passengers (
my wife tends to do this, when the front wheels cross the breakers, she just revs it and the poor rear passengers are jumping to the roof over breakers!)
For long clutch life, it is imperative that you avoid half clutching in traffic and also keep your foot off the clutch when driving - some people have a habit of keeping their foot on the clutch even when there is no need to press it (by force of habit). It is better to keep it only on the dead pedal or on the floor - this prevents early clutch failure.
3) In Gurgaon, our service experience with Landmark has been pretty good and aside from the regular extras which the SA's try to push in the services, we have not incurred any additional extras on the car. The only item which failed prematurely was the battery and I replaced my with an equivalent Exide DIN70 battery from Outside. Apart from that in 3 1/2 years now, I have not had any failures or unexpected breakdowns anywhere.
I have also taken extended warranty and my car is under 3+2 year warranty and covered till 5 years.
Service is once a year / 15000 kms, which is a decent service interval and does not necessitate going to the service centre too often.
Service experience to a large extent depends on your local service provider and if you have a good service centre near you, you should not worry on this aspect.
4) The build quality of the Jeep Compass is very good and it has a 5 star NCAP rating. You need not worry on this aspect and it is worlds better than the Vitara Brezza! You will enjoy it a lot on highways and long drives.
The weak headlights are also resolved in the new version so that should also not be an issue now.
The Boot space is ok and I have also learnt to manage with it! I have taken out the boot floor and replaced it with an ACP panel of the same shape and size - this has probably liberated another 50L of space in the boot and I also remove the parcel shelf entirely when I need more space.
I was also thinking of downsizing the spare wheel, but there are no good options available in the market, hence could not go through with it.
The spare wheel can be removed (I anyway keep Tyre sealant and inflator in the car for emergencies) but somehow on long trips I would not be comfortable without a spare wheel.
For Mumbai, the Jeep is a compact enough car, but in city you will hardly use its power. You will only enjoy the power when you head out on the highways - so if you frequently head out on long drives, it will make it worth it!
Hope I have not confused you more! Buying a car is a difficult decision and I for one have only bought cars my heart wanted
and maintained them well and retained them for a long time!
A car should be one that brings a smile to your face everytime you drive it and enjoy it on the open roads. If you don't get that feeling, don't buy the car!
When you test drive the new Jeep Compass next week, would be lovely if you share your experience in detail and also some pics - many people are looking forward to the new Jeep Compass and it would really help them.
