Old 23rd December 2010, 14:55   #211
dhanushs's Avatar
Thanked: 11,480 Times
Re: What's that sound ??
Originally Posted by carboy View Post
.. move the steering towards the right & move out.
Does the sound come when the steering is fully turned?.
dhanushs is offline
Old 6th January 2011, 15:02   #212
jeeva's Avatar
Thanked: 1,337 Times
Originally Posted by Latheesh View Post
WHERE: Strange sound from Front left suspension (Chevy Spark)
WHEN: When you go over rough patches/small potholes without breaking. Some pat-pat noise from front left suspension. No noise when going over spead breaker (after slowing down).
POSSIBLE CAUSE: Checked lower arm with local mechanic friend, he said it looks fine. He said it may be from steering ball joints.
Any clues?
Latheesh,
Its possibly the caliper pins.
jeeva is offline   (1) Thanks
Old 6th January 2011, 16:58   #213
Thanked: 1,911 Times
Originally Posted by libranof1987 View Post
Just get it checked the brake discs changed; though I feel it is normal.
Did you mean change it or get it checked?
As it just the brake pads or everything?
Not sure. Let me check tomorrow if it happens if I just go straight or reverse & not turn the steering wheel.
What does it mean if it comes with the steering wheel turned(fully or partly)?
carboy is offline
Old 6th January 2011, 18:12   #214
Thanked: 20,588 Times
Oh, sorry for the typo. I meant get the brake discs checked.
libranof1987 is offline
Old 6th January 2011, 18:39   #215
dhanushs's Avatar
Power steering's usually give out a whining noise at full turns and loads. Park the car somewhere silent, slowly turn the steering towards full lock, and listen closely to the sound. On approaching full lock, you will hear a whining sound.
Sometimes, the sound will be magnified. Is this the sound you are describing?. Please check and let me know.
dhanushs is offline
Old 6th January 2011, 19:18   #216
noopster's Avatar
Thanked: 13,245 Times
I get a whistling noise ONLY in fifth gear in my Swift. It doesn't happen in any other gear, and seems more prominent when I upshift to 5th at lower speeds (maybe because of less engine noise, though). Brought it up with MASS a couple of times but they couldn't figure it out so let it be since it isn't too loud or annoying. Any ideas?
noopster is offline
Old 13th January 2011, 17:01   #217
S_U_N's Avatar
Thanked: 418 Times
My apologies if this has been covered earlier, but off-late I have started hearing some sound when I press the brake pedal on my 1996 Zen.
When I press the brake pedal (which have become very hard and does not get depressed much (the play has reduced drastically), I hear a sound similar to rats getting hurt and screaming - squeek squeek.
This sound does not come regularly, but comes more frequently if I just pump the pedal three-four times when the car is off.
I also get the feeling that as if I am blowing in some baloon using a pump and some air is escaping while making this sound. Well, that is just my feeling about this whole experience.
Brake pads were replaced in August. Brake liners are in bad shape and I know that.
S_U_N is offline
Old 14th January 2011, 19:04   #218
Thanked: 321,777 Times
S U N, is the sound coming from around the pedal area? If so, use WD-40 generously
GTO is offline
Old 16th January 2011, 09:56   #219
S_U_N's Avatar
Thanked: 418 Times
Thanks GTO. That helped.
I no longer hear the noise; however my brakes are still very 'hard'. The pedal's play is very less.
S_U_N is offline
Old 16th January 2011, 10:48   #220
Nope - there is no sound when I turn the steering wheel fully.
carboy is offline
Old 20th January 2011, 17:05   #221
planet_rocker's Avatar
Thanked: 426 Times
Palio 1.6 GTX
i hear a kharkhar (drum beat) sound whenever the car idles - but, if i press the clutch - the sound goes off / or if i rev a bit the sound goes off and comes back again. the sound intensity (hope i am using the right word) increases with the headlights / high beam.
The sound comes at times and not always - but it is very irritating. i tried looking in the engine ba - but it is difficult to point the source with the engine running.
i got the timing belt, alternator belt, ac belt & clutch bearing changed but still the sound persists.
any pointers? thanks in advance.
planet_rocker is offline
Old 20th January 2011, 18:02   #222
dhanushs's Avatar
Obviously the sound is associated with the engine vibrating than usual. When the headlights are on, more load on the engine - lesser idle speed - more vibration - more sound. When revved, engine is more balanced - less vibration - less sound.
When the clutch is engaged, I guess the vibrations are transmitted and hence less sound.
I suspect engine mountings and related parts. How old is the car?.
dhanushs is offline
Old 20th January 2011, 18:08   #223
Thanked: 426 Times
Engine mounts are fine - got that checked when the clutch release bearing was changed - 56K kms - 8years old.
Engine vibration - not that i have noticed. what can be the cause for this?
Old 20th January 2011, 18:53   #224
Thanked: 426 Times
i found this article on the internet and added to my confusion - but still a nice read!
Release Bearing Noise with Peda-lUp.pdf
Old 31st January 2011, 13:05   #225
S_U_N's Avatar
Thanked: 418 Times
Further update: The Booster (with TMC) had gone bad.
Symptom: The pedal remained hard even when the car was turned on. This was a sign of booster (+TMC) issue.
One could hear air being pumped while pressing the brake pedal even from inside the car.
After getting the new one, braking is a lot more predictable, plus the pedal is depressible once you switch on the engine.
Posting this for the benefit of others.
S_U_N is offline
