Old 11th August 2012, 13:29   #406
inder_s1's Avatar
Thanked: 38 Times
Re: What's that sound ??
If the sound was due to the lower arm bush, then you should be hearing it on all bad patches, irrespective of steering position.
This sound sounds more like a CV joint issue. Please check if the drive shaft boot on the LH side is in good condition (Both inner and outer).
Thank you for the reply.
This sound actually comes on all bad patches and while turning left or right. But will check on the drive shaft as well and update.
inder_s1 is offline
Old 8th October 2012, 20:30   #407
StrangeWizard's Avatar
Thanked: 314 Times
Cross posting from my ownership review :
"Guys I need help.
The alternator screeching noise is back! Few days
back I started the car and it goes khurrrrrrrrrr.
This time I think it is more loud and irritating then
the previous time.
It comes on when I switch on the ac. Also,
sometimes without ac or with ac while driving, if I
have to brake and downshift to 2nd or 1st gear,
this noise comes on again.
Now what should I do? The alternator belt was
changed about a month back only.
Hope not an expensive issue.
Cheers. "
StrangeWizard is offline
Old 11th October 2012, 21:49   #408
di1in's Avatar
Thanked: 293 Times
My OHC 1.5exi has a whistle coming from the front left wheel.. it happens when I accelerate, and after crossing humps (not on the leading slope, but on the falling one only). There car also moves slightly to the left, even after alignment was done twice. Any idea as to what's happening here?
di1in is offline
Old 13th October 2012, 07:30   #409
autocrat's Avatar
Thanked: 740 Times
How many kms has your car done after last suspension overhaul? May be the suspension bushings are worn out, or shocks need to be replaced. The pulling to left side can be due to several reasons - worn out suspension, alignment, tyre pressure difference, binding brakes.. Rule out all simple causes before making expensive changes.
autocrat is offline
Old 13th October 2012, 13:25   #410
di1in's Avatar
Thanked: 293 Times
Suspension overhaul was done 2 years ago. I have since changed he bushings in front at the beginning of this year.
Another thing that i forgot to mention earlier is that the front tire is getting worn out pretty quick. A mech checked it out today, and said that the lower arm is bent and it needs to be changed. This is the second time that arm is getting changed..
di1in is offline
Old 14th October 2012, 17:03   #411
autocrat's Avatar
Thanked: 740 Times
Do you drive on particularly rough roads? Normally its not easy to bend the lower arm - needs a very strong impact. Change asap, you will have to invest in new tyre also if there is excessive uneven wear.
autocrat is offline
Old 14th October 2012, 19:16   #412
Hashim's Avatar
Thanked: 49 Times
"Guys I need help.
the previous time.
Cheers. "
As you said the alternator belt was changed a month back, all it needs is adjustment. A new belt is stiff and when used run for sometime it becomes slightly loose and needs minor adjustment again and then it remains good for quite long. Do get it adjusted as quick as possible otherwise it will damage the pulley.
You might also need to adjust AC compressor for screeching sound when turning on AC.
Hashim is offline
Old 14th October 2012, 19:24   #413
Thanked: 314 Times
Hey thanks. I got it rectified a couple of days back.
The mechanic tightened the belt with some rod and the sound vanished. He gave the same explanation which you gave in your post.
Old 16th October 2012, 12:48   #414
di1in's Avatar
Thanked: 293 Times
Not really rough roads.
I had the mech check it out again, and he had to change the bearings, and bush (3rd time) as well. He says that 195/55/R15 is too tough on the OHC.
di1in is offline
Old 22nd October 2012, 07:12   #415
thoma's Avatar
Thanked: 1,486 Times
Can anyone help me out on this one.
What sound : A faint sizzling like sound; like some loose connection or short circuit.
When : When the ignition key is in the on position, continues occasionally
When it dies : Definitely when the key is turned back; or when the engine is turned on it is not audible but might be present
What it is not : The hizzing sound of fuel pump
How much : Feeble and difficult to identify in a noisy environment; but audible in my garage.
Where : Inside the cabin; audible from the driver's seat; could not identify further; guess it's from inside the dashboard
Which car : Baleno
What I fear : A loose connection somewhere in the electrical; but couldn't even that lead to a major short circuit?
What else : One of the LED that lights up the climate control display conked off a few days before a check engine light came on . Now this has come back to normal (don't know how!) and ever since, no engine malfunction light.
Further : The CEL flashed code 14 when grounded.
Thanks in advance.
thoma is offline
Old 22nd October 2012, 19:07   #416
thoma's Avatar
I took out the flap under the steering and checked for the sizzling sound. A small motor, which oscillates the temperature regulator flap is the culprit. The working of the links are such that once the oscillation reaches the extreme point, the link travels in the reverse direction. It just doesn't seems to get stable at the extreme most point and is constantly trying to stabilize. Does not happen always.
No short circuit. Nothing serious. Relieved.
thoma is offline
Old 23rd October 2012, 10:42   #417
ishotmydog's Avatar
Thanked: 19 Times
Hey Guys, i have a 1.4 TDCI Ford Fiesta. Its only about 4 months old and I've done about 6,000 kms. Lately, while going over potholes and speed bumps there is a noise, which is more of a squeak which comes out of the rear suspension on both the sides.
Is there something i need to worry about or is it just a small niggle?
ishotmydog is offline
Old 23rd November 2012, 23:25   #418
Thanked: 99 Times
I am having the same sound but only from front left strut location. I am also having a new suspension perhaps in my old honda city.
Honda Monk is offline
Old 13th December 2012, 13:51   #419
hellmet's Avatar
Thanked: 1,032 Times
Chevrolet Beat ghungroo like sound from front driver-side wheel
At parking speeds only, there is a tink-tink sound like what comes from a ghungroo, from the front driver-side wheel. As soon as I cross about 25kmph, it vanishes. You can't hear it with the windows rolled up, but is pretty audible windows rolled down.
I took it to the Chevy 'service' center but as usual they're deaf and can't hear it (The KUN guys here in Hyderabad are pathetic).
Anybody here hear anything like this before? I checked the discs and they don't seem loose. I hope it's nothing that would affect the safety of the passengers as I've been continuing to drive the vehicle around. Suggestions for a good mechanic are also very welcome!
Mods, please merge with an existing thread if necessary. Thanks!
hellmet is offline
Old 13th December 2012, 14:10   #420
Samir Taheer's Avatar
Thanked: 279 Times
Re: Chevrolet Beat ghungroo like sound from front driver-side wheel
Thanks!
As silly as it sounds have you checked the tyres? There could be something like a stone or nail stuck in the thread! Its happened to me before!
Samir Taheer is offline
