Old 3rd July 2019, 17:26   #9361
KK_HakunaMatata's Avatar
Thanked: 1,009 Times
Re: Honda Civic : Maintenance, Service Costs and Must dos
I am facing hard gear shifts on my 2008 Civic MT for few months now. I spoke with my FNG and he says if the gear shifts on stand still with ignition off is easier then it could be a clutch related issue and may require a Clutch Kit and Releaser bearing replacement. Anyhow, I will take the car to him and then only will decide on the next course of action.
But just for my understanding what would be the costs for OE parts for Clutch Kit and Bearing. In after market there are options of Valeo & Exedy for Clutch Kit with both of them costing in 4.5k to 5k range and Nachi bearing 1.2k, but FNG was insisting on OE parts for Clutch if at all it has to be replaced.
So, inputs on OE part costs and how to source it in Bangalore would be welcome. Actually my FNG said he can get the OE parts but that would cost MRP + some percentage on top of MRP as dealers would source parts on MRP amount and then add their margin.
KK
KK_HakunaMatata is offline
Old 3rd July 2019, 17:27   #9362
hserus's Avatar
Thanked: 9,335 Times
Did you try flushing and replacing brake and gear oils if you haven't done this for a few thousand km yet?
Originally Posted by KK_HakunaMatata View Post
I am facing hard gear shifts on my 2008 Civic MT for few months now. I spoke with my FNG and he says if the gear shifts on stand still with ignition off is easier then it could be a clutch related issue and may require a Clutch Kit and Releaser bearing replacement. Anyhow, I will take the car to him and then only will decide on the next course of actin.
KK
hserus is offline   (1) Thanks
Old 3rd July 2019, 17:42   #9363
sumeethaldankar's Avatar
Thanked: 3,689 Times
I had got it at 4.3k for the Daikan clutch plate and 900 for release bearing.
https://www.team-bhp.com/forum/long-...ml#post4316070 (Honda Civic Independence : CNG'd. EDIT: 1,13,000 km up and SOLD!)
sumeethaldankar is offline   (1) Thanks
Old 3rd July 2019, 17:58   #9364
I bought the car pre-owned last December and not sure when was this done. Will check on this also. Thanks.
Thanks. I checked your post, you have put Exedy Clutch Kit and Nachi bearing which I had mentioned. How is your car feeling now after 1.5 years of the replacement?
KK
Old 3rd July 2019, 17:59   #9365
saket77's Avatar
Thanked: 14,775 Times
KK
You may give it a shot by lubricating the mechanism under the gear shift stick. The plastic trim can be easily removed by prying.
Also, both Excedy and Valeo are good brands and OE to many manufacturers. You may consider them as replacement. Most likely the Honda OE will be made by either of the two.
Regards.
saket77 is offline   (1) Thanks
Old 4th July 2019, 09:04   #9366
Regards.
Thanks saket, I will ask FNG to try this first. But any idea how to procure any OE parts of Honda.
KK
Old 4th July 2019, 09:41   #9367
Thanked: 6,462 Times
Hi Guys,
Are there any known issues with the facelift Civic Automatic?
Are the following things from first gen resolved / improve?
  1. Engine mounts
  2. Low Ground Clearance (no formal communication of improvement I understand, but anyone who has tried both and experienced if there is any improvement?)
  3. Steering Rack
Also, what do you think is a fair price for a 2011 VAT (92 kms run), Fair condition, 3rd owner car?
2000rpm is offline
Old 4th July 2019, 10:43   #9368
saket77's Avatar
KK
Honda ASC doesn’t sell spares over the counter. The other option is Boodmo. But be prepared to wait a little. As far as I understand, their order handling is not as smooth as the likes of say amazon, etc.
Regards.
Old 4th July 2019, 10:54   #9369
Regards.
Boodmo is out of option. I am done with my share of waiting for their order processing. But I don't think even Boodmo has the OE part for clutch kit. I couldn't find it there in my search yesterday.
Edit - Seems like Boodmo is carrying OE parts of Clutch Disc, Pressure plate (these two come as one package as Clutch Set in aftermarket) and Releaser bearing.
Are these the right parts -
https://boodmo.com/catalog/part-disk...ssure-5369607/
https://boodmo.com/catalog/part-disk...ction-5389019/
https://boodmo.com/catalog/part-bear...e_nsk-4868739/
KK
Old 4th July 2019, 12:57   #9370
laluks's Avatar
Thanked: 16,486 Times
OE clutch is from Exedy. You can search this thread, I have pics when we changed with Exedy from after market. I changed the first clutch at 123k, then till civic went from me till 160k clutch was fine with Exedy aftermarket.
laluks is offline   (1) Thanks
Old 4th July 2019, 15:23   #9371
Are you sure OE clutch part is from Exedy, as Boodmo is selling Exedy also (https://boodmo.com/catalog/part-clutch_set-42795324/) and separate parts marked as OE Honda also. OE parts links I had given in my last post, quoted below.
Interesting thing is Exedy Clutch Set has both Pressure plate and Disc as a set for ~ 4.5k, and parts mentioned as OE Honda is sold as two separate parts both with each of the pressure plate & disc charged at ~ 4 to 4.5k with 9k in total.
If Exedy itself are the OE part makers for Honda, then I will go ahead with Exedy ones and can save ~ 4k.
EDIT - Ok, Thanks. I did dig out your 2015 post, where you have put the stock part pics which are indeed by Exedy . I will get the car checked once, if there is need to replace Clutch parts will go ahead with Exedy itself.
KK
KK
Old 8th July 2019, 16:30   #9372
Pancham's Avatar
Thanked: 3,163 Times
Hi Guys!
I have shifted to Delhi for work and I am looking to get myself a Civic/City. I will be going today to check out the first Civic that I liked.
Any specific things to look at?
Its a 2007 model with 77KMs on the ODO, but reading all your post it seems 2007 and 77KMs is not that much and wont be too much of a headache to maintain.
Also, can you recommend the following:
1. A good genuine Honda Service center where I can get the car checked (I think they charge INR 2000) - anywhere in Gurgaon/Delhi.
2. A good and reliable FNG where I can get the car regularly looked at (if the need be).
P.S: I stay in Noida.
Pancham is online now
Old 10th July 2019, 21:27   #9373
Thanked: 2,189 Times
Originally Posted by Pancham View Post
Hi Guys!
I would suggest, try to go for a post 2010 April car if possible since they would be BSIV. God knows when NGT announces no BSIII cars in NCR.
Also 2007 means you cant use the car for more than 3 years, i.e. till 2022. Why would you want to invest in a car just for 3 years and after that it is scrap.
Saying this only because you are in Noida. Rest of India it isn't an issue...yet.
Altocumulus is offline
Old 10th July 2019, 21:45   #9374
Pancham's Avatar
Thanks. Yes I am aware of the NGT rule. Delhi has a huge stock of old Honda Cars especially Civic an City. The car I saw was in a terrible condition with no service records and airbags busted. Yet it was nice to drive. Search is on.
Old 15th July 2019, 12:33   #9375
Realized in yesterday's short rain in Bangalore that my wiper blades are streaking and there is considerable noise also. Think its time to replace the wiper blades. My question is whether I need to replace the wiper set or only the rubbers.
Can anyone help me with the size of wiper blades and also any recommended brands for Civic.
KK
