Old 3rd August 2013, 12:31   #421
manikjeet's Avatar
Thanked: 296 Times
Re: Mercedes W124 E Class Support Group
No need to go to ASS. I am uploading the Charts for the Wheel Alignment for every ones benefit.
manikjeet is offline   (1) Thanks
Old 3rd August 2013, 12:42   #422
Thanked: 650 Times
Can you help us get the complete workshop manual ( preferably pdf)
vikramvicky1984 is offline
Old 3rd August 2013, 12:54   #423
manikjeet's Avatar
Thanked: 296 Times
Surely I will Upload the scanned copy of the whole manual but i would take some time. I will have my office boy started on it.
Also in the mean time if you have something specific I would love to help you.
Old 3rd August 2013, 13:00   #424
Thanked: 266 Times
I have the workshop manual here in mumbai. If anybody here needs anything ...... i am in the burbs
53BHP is offline   (1) Thanks
Old 4th August 2013, 09:53   #425
DudeWithaFiat's Avatar
Thanked: 944 Times
Hi all,
Had taken the W124 to the service center to check whether everything is alright and to a fix a problem that had developed with the power-window. After listening to the engine for a bit the mechanic said that the o'rings mights be due for a change. We had it changed. Both diesel o'rings and injector o'rings. After that, I feel that clicking sound of the engine is now more pronounced and has become a bit tractor-like. My dad says he can't hear any difference and I might be imagining things. Is it possible that the clicking noise (sound from the lifter?) rises a little after the o'ring change and will settle down after running a few hundred km? Or could be that I'm imagining things?
E250 and 1,25,000km done.
DudeWithaFiat is offline
Old 4th August 2013, 11:58   #426
Viraat13's Avatar
Thanked: 3,419 Times
Originally Posted by DudeWithaFiat View Post
Had taken the ... I'm imagining things?
Haha. Same thing happened to me. The clatter is sharper, isn't it? Wait for it to settle down, and it should become quieter. My car had a diesel leakage because of a torn O ring at the filter, and the performance became better after I changed the rings, so I guess it wasn't a minor leak at all.
Viraat13 is offline
Old 4th August 2013, 12:02   #427
manikjeet's Avatar
Thanked: 296 Times
It might be in your head itself but if u can make a video we can judge it better. And even its a case it will settle down.
Old 4th August 2013, 22:22   #428
Hi all,
I don't think the injector has got any o rings. The o rings in place prevents the engine oil from entering the pre combustion area. Changing them will not affect the performance in any way.
Also adding a picture I found in our own classifieds. Check out the outside temp reading.
tharakan9 is offline
Old 5th August 2013, 07:23   #429
FlatOut's Avatar
Thanked: 385 Times
Hi all,
Are you talking about the delivery valve seals as well, where the injector pipes come out of the top of the injector pump? If so, then there will be a little more clacking sound for a while - but it should only be a little more, and be even to all cylinders. If it is an uneven click/clack, from just one or two pipes/injectors, then it's possible one or more new seals hasn't seated correctly or that there is a tiny bit of dirt contaminating the joint. Give it a thousand km and if still very noticeable then have it looked at. Cleanliness when carrying out delivery valve seal replacement is everything.
FlatOut is offline   (1) Thanks
Old 11th August 2013, 10:42   #430
Thanked: 944 Times
Hi all,
Yesterday while I was driving, I noticed a very slight grinding noise coming from the passenger side, from somewhere near the wheels when the steering wheel is turned (I don't exactly remember whether it comes when I turn the steering wheel to the right or to the left). The previous owner had told me that the suspension bushes are due for a change. I plan to do that after the weather here gets a little better and the govt. fills those potholes that develops magically every year when it starts raining (talk about corruption). Is the noise coming from suspension? I took a look near the wheels, but could not see anything amiss.
P.S:- The wheels are out-of-balance which I am getting balanced on tomorrow since today is a holiday.
Old 12th August 2013, 13:24   #431
DeepakMenon's Avatar
Thanked: 182 Times
First balance your car; and alignment; while you are it
Jack up your car and visually go through the all the bushes, tie rod ends, balljoints, wheel bearings, shocks, brakes
If it is the ball joint; i would suggest change it immediately as failed ball joint is dangerous and will let your wheel out; it is a known fault..
DeepakMenon is offline
Old 16th August 2013, 14:57   #432
Thanked: 650 Times
I am lately getting a slight squeaking noise when i turn the steering (comes from the wheel itself), what could this be? It only comes when i start the car after few days, is gone once the car has been run.
P.S. Its heavy monsoons in Mumbai now
Old 16th August 2013, 19:47   #433
Thanked: 182 Times
Like i said before squeak is a general thing to say.. it can be a range of things.. like somethimes old tires squeak; out of alignment tires squesk.. if steering wheel then the contact ring..
No way to be sure till you visually check the underside
Old 21st August 2013, 12:15   #434
manikjeet's Avatar
Thanked: 296 Times
I wanted to ask if anybody can guide me where to find a new coolant bottle for my E220. I have a leaking bottle.
I will also like to know if it can be repaired and how. If I don't find a replacement bottle.
Old 21st August 2013, 14:30   #435
Thanked: 182 Times
Check with any part dealer; New is available; or get one from Ebay
or go to local junkyard; like Kurla in Mumbai and get one
If you want to repair; then Plastex [Google for the kit]
