Old 21st June 2014, 14:46   #5626
sumeethaldankar's Avatar
Thanked: 3,698 Times
Originally Posted by revvhed View Post
@sumeethaldankar ..
Anxiously awaiting your report as I have been running on Shell Helix Ultra and was contemplating changing over to Total Quartz 9000. Though yours is a semi-synth to synth. change if I understand correctly.
Hello unfortunately i was called for office duties and had to postpone the oil change till next weekend.But i am curious to know why you want to switch to total from shell.
sumeethaldankar is offline
Old 22nd June 2014, 14:45   #5627
re: Honda Civic : Maintenance, Service Costs and Must dos
Guys,
I own a 2007 model Honda Civic in Kolkata which has done around 22k kms. Recently, I've started experiencing problems with the brakes in a way that they do not seem to have enough bite.
A couple of months back, the service centre(Eastern Honda) had checked up on this issue and found no problems. I'm still not fully satisfied though.
I need some advice from you guys as to how to go about this issue. Moreover, is there any service centre in Kolkata which is not an authorised Honda centre but one which offers great service at reasonable costs? Also, if the brake pads/callipers need to be replaced, how much would they cost?
Thanks,
anunaynitdgp is offline
Old 23rd June 2014, 02:06   #5628
MARCUS_520i's Avatar
Thanked: 167 Times
Hi Anunay! Welcome to the forum and to the now limited(since they're not selling these in India anymore) Honda Civic Club.
Although I do not know about Honda workshops in Cal, I can give you a rough estimate of how much the brake-work would come down to, since my '08 baby just came back from a much needed 50,000 km service which demanded a lot of attention the brakes and related components.
A complete replacement of all the brake pads(front and rear pairs) will cost you INR 15,000/-; that's INR 7500/- per pair.
The brake disc skimming for all 4 discs will be INR 2500/-
The caliper on my front RHS needed replacement and just 1 caliper bought from the Honda workshop set me back by a HUGE INR 12,500/-
Replacing all 4 could buy you a used Maruti 800
So, only brake-work bill for me was INR 30,000/- WITHOUT TAXES OR LABOUR CHARGES.
But since brakes are the most primary of all things as far as safety of the occupants of a vehicle goes, I got it done without a doubt in mind. And if your car needs some TLC in the brake department, I'd suggest you drive it down to a good Honda workshop, get it diagnosed and spend your buck on the necessities first.
Keep us posted on how it goes!
Cheers.
MARCUS_520i is offline
Old 24th June 2014, 09:52   #5629
bigblackshark's Avatar
Thanked: 74 Times
Had posted this in the modifications thread over a week ago but got no responses so thought I should ask here.
Where in Mumbai can I get door visors of the mugen replica kinds And led scuff plates for the civic?
bigblackshark is offline
Old 27th June 2014, 13:53   #5630
coolkurt's Avatar
Thanked: 1,724 Times
How frequently does the fuel filter have to be changed? How frequently in terms of time and kms clocked?
coolkurt is offline
Old 27th June 2014, 14:01   #5631
I believe it's every 40k Km in terms of distance. Time based well i am not sure but if you running CNG i won't bother changing same for 4 years atleast.
sumeethaldankar is offline   (1) Thanks
Old 27th June 2014, 16:13   #5632
sarathlal's Avatar
Thanked: 6,332 Times
Yes, the interval is 40k kms/2years.
sarathlal is online now   (1) Thanks
Old 28th June 2014, 18:18   #5633
laluks's Avatar
Thanked: 16,486 Times
40K agreed, 2 year duration is it mentioned in the manual?
laluks is offline
Old 28th June 2014, 18:47   #5634
I finally changed to fully synthetic Shell Helix Ultra.I found the car to be a bit smooth and the engine to be a bit more responsive.The oil is suppose to have a drainage interval of 10K but would the oil filter last as long ?
Old 28th June 2014, 20:41   #5635
SmartCat's Avatar
Thanked: 52,355 Times
These days, I set the tyre pressure to 28 PSI (Honda recommends 30 PSI). This improves the low speed city ride quality massively, especially over deep ruts. Suddenly, my Civic's ride quality is magic carpet-like. You have to experience the difference to believe it. I'm wondering how just 2 PSI makes such a significant difference.
I'm willing to sacrifice the extra tyre wear and lower mileage for the comfort. I anyway change tyres at 40,000 kms/4 years even if there's decent tread depth.
However, I intend to inflate the tyres to 30 PSI on highway drives.
SmartCat is online now
Old 28th June 2014, 21:39   #5636
Yes i have experienced the magic carpet feel too at a reduced tyre pressure.I have 205 size and fill up 32 psi and run for around 2-3 weeks or around 300-500 kms.With time or distance as the pressure reduces the ride gets softer and comfortable.I am not sure if this will accelerate wear and tear of the tyre but they look good even after 10k and 3 years of running.I believe higher pressure is recommended for highway driving where the tyre does not flex much as it becomes stiffer.Someone can correct me if wrong.
Old 30th June 2014, 09:11   #5637
sarathlal's Avatar
Yes, it is. In the manual, the service interval for every detail is given in terms of km's and time, whichever comes first.
For Civic, the interval is in every 20K kms/1 year range. Certain types like the fuel filter in question, comes up in every second such occurrence, which would be 40K kms/2 year range.
Old 30th June 2014, 17:07   #5638
iTNerd's Avatar
Thanked: 1,221 Times
So I had my Civic through a thorough wash and dry cleaning today morning. I had steam pressure wash on the engine bay too. Now, a strange issue that cropped up after 3/4 hrs after the wash.
1) The alert came out on its own (flashing lights and anti-theft alarms).
2) The door open gauge remains ON even when all the doors/boot are properly closed.
3) I can't use the remote key button to lock the car anymore. It does nothing. However, if I use the key to manually lock it, it works. And I can again use the unlock remote button to unlock it. So, that rules out battery problem on the remote key.
4) I also see that the side-step LED (on all four doors) do not lit up when the door is opened. (It used to bring up the CIVIC LED blue glow previously).
5) I tried the head unit, head lights and indicators - all works.
So I am quite puzzled what could be the reason. I am guessing washing the engine bay or the dry cleaning of upholstery might have induced some water to the electricals. Any idea how I can troubelshoot?
iTNerd is offline
Old 30th June 2014, 17:12   #5639
saket77's Avatar
Thanked: 14,788 Times
Looks like a door/boot/bonnet switch is stuck in on position. Or may be the rubber bush which presses agaisnt those switch to turn the off is not doing its duty for some reason. This justifies why you alarm is sounding and not arming up the car. May be some water has gone into those switches too, which if is the case, should resolve once the water dries up.
saket77 is offline   (1) Thanks
Old 30th June 2014, 21:19   #5640
iTNerd's Avatar
I tried a few minutes, no luck! It seems like some fuse or electrical circuit have gone kaput. Will take the car to service center tomorrow to diagnose the problem. Hope it is just a simple issue.
iTNerd is offline   (1) Thanks
