Old 26th July 2007, 13:27   #6691
Thanked: 306 Times
Originally Posted by shuvd View Post
Thanks navinji. But, I was thinking of a 4ch amp to feed the upgraded speakers and using the active bass tube I already have.
Then, would I need 2 line level to RCA wires? 1 for the 4ch amp and the other for the tube?
Budget for the 4ch amp is 20k. Say another 15k for the 2 pairs of speakers.
If the existing bass tube cannot be used, then I'll go for a monoblock and a sub. Can this be done? Thanks in advance.
you would need 2 RCA wires as well as a sub level controller. Many amps esp monoblocks come with a small knob that you can install in your dash that lets you control the subwoofe level.
if your active sub has this facility then use it.
For 20K the base Audison (LRx4 or SRx4??) is an option. For 15K try Infinity reference, Illusion Carbon, Hertz Energy, and Alpine Type R. Polk db and Boston are also within your budget.
At this level I would add some damping as well.
your Budget is 20k + 15k
then I would say go for JBL 75.4 amp for the speakers Solid amp with Solid power. cost is about 9k grey or 13k W/B
or one new up coming model let the pic do the taking.
Available for 15K Power 75 x 4 at 4 ohms
Now you have a budget of 20k for the speakers..
You can choose Infinity also or my nowdays peronal Favoroute Illisuon Audio Luccent series they are for 11.5k.
::* i l l u s i o n** a u d i o* ::
Navin Ji the LRx range is above 30k. and the Illusion Carbon is for 25k.
low_bass_makker is offline
Old 26th July 2007, 15:41   #6692
clipto333's Avatar
Thanked: 7 Times
Originally Posted by low_bass_makker View Post
i thought its an audison till i saw the infinity logo. it looks good. i didnt like the previous amps.
cheers
clip
clipto333 is offline
Old 26th July 2007, 15:47   #6693
Thanked: 306 Times
cheers
clip
The same thing I said to Sam Bhai when I saw this picture....
Old 27th July 2007, 00:56   #6694
kunaldhami's Avatar
Thanked: 82 Times
I need new HU for my Maruti800. looking for budget HUs like Pio 295 / Balu Mumbai.
Which HU you suggest?
I have ipod and used to connect it to earlier Sony HU via Aux in.
Speakers are pio 4" co-axials in front and 6" co-axials in rear.
kunaldhami is offline
Old 27th July 2007, 09:29   #6695
navin's Avatar
Thanked: 9,961 Times
I did not like the look of the JBL GTO amps either. Too bad Infinity is only releasing the monoblock and 4ch. amp for India not the 5350a.
navin is offline
Old 27th July 2007, 09:31   #6696
navin's Avatar
Which HU you suggest?.
Hey you answered your own question! :-)
navin is offline
Old 27th July 2007, 11:01   #6697
shuvd's Avatar
@ low_bass_makker - Sir, is that the Infinity Ref 475A? Have these been launched?
WRT the speakers, I don't think Infinity, Illusion, etc are available in Calcutta.
@ navin ji - Thanks for clearing that 2 pairs of RCA part. Except Alpine, none of the brands you have mentioned are available here me thinks.
shuvd is offline
Old 27th July 2007, 11:36   #6698
Thanked: 306 Times
ya that is the Ref 475a. And it has been launched.
recently a fellow member razor4077 got a pair of Illusion Electra for his car. Ask him about it how they sound and how he got hold of them....
Old 27th July 2007, 12:22   #6699
navin's Avatar
WRT the speakers, I don't think Infinity, Illusion, etc are available in Calcutta..
Infinty is ask any JBL dealer. Infinity is a sister barnd. For Illusion PM Bass and Trouble for the nearest dealer.
navin is offline
Old 27th July 2007, 12:53   #6700
Vid6639's Avatar
Thanked: 44,145 Times
How do I clean my coax 6X9 speakers?
I gave my car for servicing and my rear right pioneer 6X9's are going khar khar after that. Dunno if it's water after wash or just dirt.
Switched off and pressed the cone down and I could feel the dirt causing the sound. Tried dusting off a wee bit and it reduced but still goes a lil khar khar.
Any other ways to clean it?
Vid6639 is offline
Old 27th July 2007, 13:00   #6701
navin's Avatar
blow some air carefully. dont use water! I had a friend who "washed" his speakers in WD40 (dont ask me why, I did not ask him. BTW they were Marcom speakers *I can see LBM busy with google now*).
navin is offline
Old 27th July 2007, 13:11   #6702
Thanked: 306 Times
Heheheheh
Blowing compressed air and also move the speaker with hand so that the dirt if stuck will also get removed.
Old 27th July 2007, 14:56   #6703
navin's Avatar
LBM, I meant about Marcom. Did you find out who they really are? You will be surpsrised.
navin is offline
Old 27th July 2007, 15:15   #6704
Vid6639's Avatar
The tweeter dome on top is so big I can't blow air into the axis part. Trying to blow from the side but no use.
I'm guessing compressed air at 80psi is not a good idea.
Vid6639 is offline
Old 27th July 2007, 15:21   #6705
navin's Avatar
No 80psi. try 10 psi from the bottom (around the magnet).
navin is offline
