Old 10th January 2021, 11:32   #8461
Red Liner's Avatar
Thanked: 19,179 Times
Re: The Home Appliance thread
Hello and Happy Sunday!
Any suggestions on a good Candy thermometer?
Red Liner is offline
Old 11th January 2021, 10:54   #8462
Prowler's Avatar
Thanked: 1,403 Times
We have a 60 L storage water heater which has been working flawlessly for 35 years or so. Some months back it failed - the heating element conked off. It is 13.5 inches long and about 4 cm diameter spherical element. I tried Amazon for a replacement to no avail.
Any pointers as to where to source such a rare item ?
I had ordered a small 15 L water heater for now. Sad to part with a such a piece of family 'heritage'.
Prowler is offline
Old 11th January 2021, 11:04   #8463
Thanked: 3,280 Times
What model and make?. Such vintages are rare and the only way to get spares is to junk another one.
srini1785 is offline   (1) Thanks
Old 11th January 2021, 11:15   #8464
Prowler's Avatar
The name tag was painted over when they painted the house. My father bought that when they built the house. IRC it had some German name.
Actually if you look at the element it can be serviced easily by fitting a 1000W heater coil inside it. It has delicate ceramic rings on the outside. The central rod has a corroded nut.
Modern day water heaters have their elements inside the tank - within the water. These ancient heaters have a cavity where the elements live without touching the water. Thus no corrosion, no leakages and long lives.
Prowler is offline   (1) Thanks
Old 11th January 2021, 11:33   #8465
In that case, the only way is DIY. Corroded nut can be replaced. Preserve any of the seals that you take out, replace the coils by matching the wattage and difference in length can be adjusted by machining parts to fit. I'm afraid it won't be like it was with the original part but can be used as a vintage unit.
All the best.
Old 11th January 2021, 14:16   #8466
Jaguar's Avatar
Thanked: 2,877 Times
OT: Your location states Madras. Why do you even need a water heater, a big one at that?
Jaguar is offline   (1) Thanks
Old 11th January 2021, 14:24   #8467
Prowler's Avatar
All the best.
Thanks Srini. I will have to remove the offending nut very very carefully. The heater element is a standard 1000 W coil used in stoves, room heaters etc.
Once you are used to bathing in piping hot water no matter where you are, you can't get over that habit. A whole family can bath and still be left with plenty of water in the 60 L.
Prowler is offline   (3) Thanks
Old 12th January 2021, 14:19   #8468
vsrivatsa's Avatar
Thanked: 4,058 Times
Any recommendations for a Mixer Grinder of 750 Watts with 3 Steel Jars?
Thinking of the Philips HL7756/00 (Link) - any feedback on this one would be helpful - and open to other recommendations as well.
vsrivatsa is offline
Old 12th January 2021, 14:26   #8469
Gannu_1's Avatar
Thanked: 20,674 Times
Do check out Preethi’s mixer grinders too.
We’ve been using them for decades now and except for the jars’ top replacement and the gaskets (local replacements), the rest are untouched. The body’s white plastic has faded though.
Not that it matters but even the naval and coast guard crew who comes to take over the ships that we build, selects Preethi when we take them to the shop to select the mess traps (naval parlance for cutlery, crockery etc).
Gannu_1 is offline   (2) Thanks
Old 12th January 2021, 14:28   #8470
Eddy's Avatar
Thanked: 14,523 Times
We bought this about 6 months back. So far so good.
We also considered a Bosch machine, considering it has jar clamps and you don't need to hold the lid down while operating it but for some reason, Mrs chose the Phillips.
Edit: We do not grind south Indian chutneys at home.
Eddy is online now   (1) Thanks
Old 12th January 2021, 14:29   #8471
paragsachania's Avatar
Thanked: 27,205 Times
My family swears by Preethi. One of the most robust, reliable and abuse friend mixers around since a while now.
I believe when it comes to South Indian states and the need to grind coconut for their daily chutneys, brands like Preethi and few others command.
paragsachania is offline   (2) Thanks
Old 12th January 2021, 14:36   #8472
KPR
Thanked: 2,535 Times
I had learnt the english word guarantee in my childhood from Preethi's advertisement only. The caption is Preethikku Naan Guarantee which means I stand guarantee for Preethi. Of course for the mixer product.
KPR is offline   (2) Thanks
Old 12th January 2021, 15:04   #8473
vsrivatsa's Avatar
Thanks everyone for the recommendations. Is it OK to buy Mixer Grinder on Amazon.in or should we pick it up from a nearby store?
Old 12th January 2021, 15:23   #8474
Red Liner's Avatar
Panasonic. Superbly built
Old 12th January 2021, 15:25   #8475
Thanked: 2,427 Times
I have heard good reviews about Bosch and couple of my friends using it have good reviews about it. A bit noisy is all they say.
We use Kenstar at our home and happy about it. Does the job with ease.
I prefer to buy things at an appliance store than online for home appliances.
TorqueyTechie is offline
