Old 26th August 2021, 17:32   #13831
Thanked: 987 Times
Re: The iPhone Thread
Originally Posted by altius View Post
I got my 6s battery replaced at Cashify recently and no issues so far.
If you happen to have a Mac, could you check if it properly shows you the number of cycles and actual battery capacity and health using coconut battery.
My aftermarket battery after 1 years still shows 100% and shows 3 or 4 cycles, both of which I know is wrong. I am pretty sure that local guy did some jugaad to make it work like this.
raksrules is offline
Old 26th August 2021, 17:45   #13832
AJ56's Avatar
Thanked: 3,248 Times
You don’t need a Mac, just go in settings - privacy - analytics and improvement - analytics data - scroll down to log aggregated with the latest date and in it you’ll find the current battery cycle count, max fcc and nominal charge capacity of your battery.
Note: share iPhone analytics must be turned on for at least 24 hours for the log to be generated.
AJ56 is offline   (1) Thanks
Old 26th August 2021, 17:55   #13833
Thanked: 987 Times
My aftermarket battery still shows all incorrect info there. Anyways I have booked appointment with cashify for replacement of battery tomorrow so lets see how it goes. I am not keen to spend on original battery only because I have been burned once with apple original in US after their slowing down phones fiasco and they made battery replacement $25. I had to replace that battery in 7 months (just one month after warranty expiry).
My wife's iPhone X bought in 2017 is also showing 77% battery health now and "service". But it is not really that bad in terms of usage so we are going to keep this battery until it goes very bad.
Old 27th August 2021, 10:46   #13834
2500cc's Avatar
Thanked: 354 Times
People who are still using older iPhone models, here's an interesting article I found to speed up the phones if you feel the performance is degrade. Worth trying..
https://www.businessinsider.in/tech/...w/85583982.cms
2500cc is offline
Old 27th August 2021, 10:56   #13835
Thanked: 20,625 Times
The problem with this approach would be: several apps are region specific (HDFC Bank's for instance). So, those apps only available in India would no longer be usable.
libranof1987 is offline
Old 27th August 2021, 11:01   #13836
Thanked: 329 Times
Quick query, we have a iPhone 12 within the family.
Sometimes when we try to make a WhatsApp call to the iPhone, it does not connect ie it just shows "Calling" instead of "Ringing" and does not indicate the incoming call to the recipient. It does not matter if its connected via 4G or Wifi.
Is there some setting which can be enabled to rectify this behavior.
kochup is offline
Old 27th August 2021, 14:33   #13837
saket77's Avatar
Thanked: 14,767 Times
I called the nearby Apple Authorized service center (Aptronix in Borivali (West), Mumbai) and they quoted me 2854 Rupees. Will see if I can go on weekend. As of today, she told battery is available so replacement can be done right then and there.
I don't know why this amount is not uniform at Apple Service. I just got my 6S battery replaced which cost me Rs. 3600/-. They kep the part they replaced and told me that this 3.6K is the 'exchange price'. If I want my old battery back (which by the way was at 80% health), I will need to pay 6K instead of 3.6K
saket77 is offline
Old 28th August 2021, 10:00   #13838
Thanked: 479 Times
It is not due to phone settings but it is a network issue. The calling/ringing is affected by both the calling parties. If either of them has a poor network it will show as calling only. Even with good connection speed, latency will play a role.
NG_EV is offline   (1) Thanks
Old 28th August 2021, 10:29   #13839
Chetan_Rao's Avatar
Thanked: 28,308 Times
Apple is quoting INR 5350 for a battery swap on an iPhone SE 1st gen. That seems a bit, erm...ridiculous!
Chetan_Rao is offline
Old 28th August 2021, 12:40   #13840
Thanked: 329 Times
Thanks NG_EV, the reason i suspected some setting on iPhone is because all the other phones in the house gets connected (Android) while the iPhone does not while on the same Wifi connected and Airtel as the 4G provider.
kochup is offline
Old 28th August 2021, 13:13   #13841
Thanked: 2,101 Times
That's great deal. When I had gone to Apple care in Mantri mall, the quoted Rs. 7000/- and 10 day TAT.
With guidance of friends here at Team-BHP, I bought a battery and tools from Amazon and replaced it myself. Total cost was Rs. 1600/-
wildsdi5530 is offline
Old 28th August 2021, 14:30   #13842
Pancham's Avatar
Thanked: 3,161 Times
It is. The standard price at Apple workshops is INR 3,600 approximately.
Pancham is offline
Old 28th August 2021, 15:16   #13843
Thanked: 479 Times
Is the device old? Older devices had some network issues due to over-voltage done by Apple at the time of software update.
Unrelated post:
Apple is offering earpiece replacement free of cost for some iphone 12 and 12 pro. Details in the link below.
https://support.apple.com/iphone-12-...o-sound-issues
Old 28th August 2021, 16:11   #13844
Thanked: 329 Times
No it's a 2021 iPhone 12, maybe I will just try a reset of the phone to see if it helps ... thanks
kochup is offline   (1) Thanks
Old 28th August 2021, 17:15   #13845
speedfreak01's Avatar
Thanked: 475 Times
I had got my wife’s iPhone X battery replaced in June from a private retailer for 4000 and was also given a 6 month warranty on the battery. Dont know whether I paid more as per the market rate because I didnt double check the price anywhere else. However the battery is working flawlessly.
speedfreak01 is offline
