Old 23rd May 2010, 10:55   #1186
inder's Avatar
Thanked: 101 Times
Thanks khoj,I will check out hitachi 2.2 aswell.
will consult u again for a final word,before putting down the money
inder is offline
Old 23rd May 2010, 11:47   #1187
mobike008's Avatar
Thanked: 17,195 Times
Boy! am i really happy with Whirlpool, the cooling is awesome
dunno Khoj, mine is a 1.5T chrome edition, its 3 star rated
+1 on that. I too have the same make and model but 2.0 Ton. Cooling indeed is awesome.
Even i have not checked on the make of the compressor yet.
mobike008 is offline
Old 23rd May 2010, 12:32   #1188
Thanked: 15 Times
Which small ac??
Hi all,
I need an ac for one of the bedrooms for my flat in Delhi. The size of the room is 10'(W) X 11' (L) X 9' (H). None of the walls is exposed to sun. The room has three doors and one window. The room is going to be used by only one person.
I have following options :-
(a) General 0.8 ton 2 star for 16800/-
(b) Carrier Estrella 1 ton 3 star for 17200/-
(c) Whirlpool Delux 1 ton 2 star for 14553/-
Which one should I go in for? Is 0.8 ton General sufficient for this room? Or is there any other option that i should go in for? Guys advice needed on very urgent basis. AC is required to be fitted by evening.
Thanks for your time.
-Navneet
Navneet is offline
Old 23rd May 2010, 16:39   #1189
Kool_Kid's Avatar
Thanked: 16 Times
Thanks Khoj
Originally Posted by khoj;
You can go the General Arcade in Mansarovar Garden and find the entire range of General machines. The best part is that the same company is also an authorized dealer for Daikin and Panasonic. Their contact details are
Saviour Aircon
Address1 FB-122&127, Mansarovar Garden, New Delhi
City Delhi, PIN 110 015
Telephone 011-25116191 / 25933991
Fax 011-25158685
Mobile 9811131655 , 9811229205
Owner 1 Mr. Yogesh Bibra
There is another General arcade in Rohini, in case the above does not work out you could contact them on 27216370; 9312243532.
Thanks you Khoj ,
general dealer is asking 41,000 for ASGA18ACT ( + 2000 fitting + 1500 pipe + 550 Outdoor unit stand ) so the total comes to 45,000 Rs
The Hitachi dealer is around 36,000 for RAU018HQDP + 1500 fitting so total comes to around 38,000 Rs
I have have also looked up VOLTAS Vertis Gold , dealer is asking around 28,000 + 2000 so total comes to around 30,000 Rs
Please note that all these have BEE 5 star rating .
Can you please advise if its voltas should be considered ? I have enclosed the BEE rating
VOLTAS SPLIT AIR CONDITIONER 4501166 3.2 1.5 5270.0(Cooling Capacity) 1650.(Power Consumption )
Kool_Kid is offline
Old 23rd May 2010, 20:15   #1190
khoj's Avatar
Thanked: 1,288 Times
@Kool_Kid
In that price range you would do better to go with a Whirlpool 5 star rated machine rather than Voltas. Whirlpool machines are a whole lot better and maybe a shade cheaper too.
Try the Rohini guys for a price comparison.
These days 1.5 ton Daikin is available for 38K++++; Daikin inverter 1.5 with R22 gas for 44K++++ and Daikin inverter with the eco friendly R410 gas for 52K+++. The mansarovar guy is quoting somewhat on the higher side.
Ask him for a quote on the Daikin too and another Daikinn dealer too, use this link
http://daikinindia.com/showfilter.as...selCity=Delhi+
@Navneet
Theoretically a 0.8 ton machine should be sufficient if the roof is not exposed to sun and you are not expecting to achieve 22~23 C temperatures in the afternoons. A 1 ton is definitely better as it gives a bit of extra capacity for those extra hot days and also in view of 3 doors!! Entry/exit; bathroom and balcony I presume?
Choose between General and Whirlpool but 1 ton and not the 0.8 and forget the Estrella it is a good machine but not for your service conditions.
khoj is offline
Old 23rd May 2010, 20:40   #1191
Thanked: 15 Times
Originally Posted by khoj View Post
@Navneet
... and forget the Estrella it is a good machine but not for your service conditions.
Khoj,
Thanks for your reply. However, did not quite get part of answer quoted above. You mean because of the frequent moves ?
Navneet is offline
Old 24th May 2010, 00:23   #1192
khoj's Avatar
@Navneet
I meant the service conditions that exist for the air con in the given room .
Heat loss from three doors, a window, the individual in the room, light fittings and other electric/electronic gadgets all together and the aircon working on its limit all the time. This can be dealt with in a better manner by the units from General and Whirlpool compared to the Carrier machine.
khoj is offline
Old 24th May 2010, 02:03   #1193
harry10's Avatar
Thanked: 4,108 Times
Getting Whirlpool chrome split 3 star at -22500 and Chrome 5 star at 27500.
Its a 1.5T Ac.
Difference is 5k.
And the only difference between them is power usage.
Chrome 3 star uses 223w more than chrome 5 star.
So my Q is is it worth to go for 5star chrome considering my daily ac use is 5-7 hours.
Kindly suggest as need to get it by tommorow.
Also chrome 3star EER- 2.84
Chrome 5 star EER- 3.24
harry10 is offline
Old 24th May 2010, 03:17   #1194
khoj's Avatar
If it is within your planned budget get the 5 star machine.
khoj is offline
Old 24th May 2010, 13:17   #1195
harry10's Avatar
Thanks.
My budget was 25k so i can stretch if needed.
Can you elaborate a bit more regarding the advantage of getting it just for my info?
harry10 is offline
Old 24th May 2010, 14:38   #1196
khoj's Avatar
You will get a machine built with components that have tolerances closer to the design criteria. Results are higher efficiency, smoother operations, longer MTBF/service life and maybe better finish on the indoor units face plate.
Edit Silent running maybe! check the dB values on the spec sheets of the 2 machines.
khoj is offline
Old 24th May 2010, 14:47   #1197
harry10's Avatar
Then will go with this itself.
Also someone told me 5star are more silent. Is that true?
harry10 is offline
Old 24th May 2010, 15:36   #1198
inder's Avatar
Thanked: 101 Times
Hi Khoj,
I have decided to buy the O Gen 2 tonner split.Went to the dealer and got further confused.He gave me a brochure which has 3 models ASG24A,ASGA24AET,ASG24ACT .I checked at compareindia.com,but it shows only one 2 ton model in wall split ASG24A.now there is mismatch of specification betwn compareindia/khoj on one hand and OG brochure on the other.
BTU/hr 24000 as against 25300
running current A 11.8 as against 11.1
power consumption 2700 as against 2400
EER 2.7 kW/KW (???) as against 10.54
None of the models given in brochure matches the specification of compareindia
PLZ clarify my confusion Khoj
inder is offline
Old 24th May 2010, 20:29   #1199
khoj's Avatar
ASG24A is a long running model from General that has been around since eternity. All of the units mentioned by you are 2 ton rating that is evident from the nomenclature. The last two digits may be for new models from the 2010 range. Check the regular model in the link :: Welcome to the OGENERAL AIR CONDITIONERS ::: and confirm visual differences/similarities between this and the models in your brochure.
Can you scan the brochure and post it here.
khoj is offline
Old 24th May 2010, 22:05   #1200
Thanked: 15 Times
@Navneet
Thanks Khoj for helping me choose the right ac for me.
Bought and installed 1 ton Whirlpool Royale 3 Star for 15977/-
Satisfied with cooling and dB levels.
-Navneet
Navneet is offline
