Old 18th September 2008, 15:28   #2116
rakowli's Avatar
Originally Posted by amit_mechengg View Post
finally i have got a 100/90 philips rally H4 for my alto old model headlights.
i have put a PMP relay kit.
its a marginal upgrade as the high beam is very powerful , but the low beam spread could have been better.
cost of each bulb is 150rs and kit costed 500 rs , fittment 50 rs.
i am totally satisfied. thanks to happy wheels
Try setting the headlamp assembly a bit on upper side. It must be having a screw to adjust the settings. That will give you a better low beam spread.
rakowli is offline
Old 18th September 2008, 16:49   #2117
Thanked: 571 Times
...i am totally satisfied. ...
way to go amit!
Glad to be of help!
HappyWheels is offline
Old 18th September 2008, 17:00   #2118
tsk1979's Avatar
Thanked: 23,484 Times
Originally Posted by Path_Finder View Post
I would guess that life is marginaly lower than regular, but not very low. We will have to wait for sometime for actual use experience. The Philips website gives the following ratings on X-treme Power bulbs
Lifespan
Performance
Practicality
Styling
Life of +80% and +80% bulbs is usually less than half than that of normal bulbs. esp with frequent high/low beam switching.
tsk1979 is offline
Old 18th September 2008, 20:52   #2119
Hella Rallye 4000
I'm planning to install a pair of Hella Rallye 4000 with 100W H1 bulbs on my Indica Lxi. What are the precautions/steps i need to take during installation. Planning to install a seperate switch to control them. What are the addons i need to purchase to install the Rallye 4000?
underground1419 is offline
Old 19th September 2008, 09:55   #2120
Path_Finder's Avatar
I also have doubts about the 80% of normal life claimed on a bulb which will 80% more light! I have put it on my CEIDA - so let me see over time. These bulbs are new in the market and will know after some time only.
Apart from the cutting and relays need, the problem I find with higher wattage bulbs is that they kind of balcken a bit over time and you will not see the initial advantage after some time.
Path_Finder is offline
Old 20th September 2008, 23:18   #2121
ethanhunt123's Avatar
Thanked: 1,035 Times
Where and which bulb did you get for your CEDIA Pathfinder ?
ethanhunt123 is offline
Old 21st September 2008, 10:41   #2122
badboyscad's Avatar
Thanked: 483 Times
Urgent advice needed:
what type of headlamp bulb does the scorpio has (h4 or h7 or etc)??
Will Phillips Xtreme bulbs fit in my 2003 scorpio?
If not, then what is the brightest bulb available for the scorpio?
Please reply ASAP guys, im gonna go shopping now.
TIA
badboyscad is offline
Old 21st September 2008, 10:48   #2123
I picked it up from JC Road after some search. Check out my post http://www.team-bhp.com/forum/test-d...tml#post978507 - I have included the shop address and some direction there
Old 22nd September 2008, 14:08   #2124
kumar_ranjan's Avatar
Thanked: 19 Times
I have Angle eye in the swift, the problem is that some of the LED's are not working and when I took it to some electronics shop for repair, he told me that some of the resistance were broken and he was not able to find the correct values of it. Can anyone have an idea if I can get the complete kit of LEDs with the wire so that I can replace the existing one.
kumar_ranjan is offline
Old 22nd September 2008, 19:00   #2125
manojgautham's Avatar
Thanked: 11 Times
Need urgent help, I am planning to put in H4 HID in my car.
Has anyone here bought a 4300k or a 6000K bixenon. If so what brand and how much does it cost.
I've been quoted Rs8500 for the Philips kit, it comes only in 6000k, I was more keen on 4300k. Will there be a large difference between 4300k & 6000k. I would anyday prefer a Philips kit to a Chinese kit. Kindly advice me on the modification.
thanks in advance,
Manoj
manojgautham is offline
Old 22nd September 2008, 19:32   #2126
ImmortalZ's Avatar
Thanked: 601 Times
6000k = lots of show, no light advantage from halogens, worse than stock in fog/rain.
4300k = reason you should be using HIDs.
ImmortalZ is offline
Old 22nd September 2008, 20:06   #2127
Akshay1234's Avatar
Thanked: 12,914 Times
not really. they are much better than halogens though not as good as 4300k. and not as irritating as 8000k and 10000k. 6000k is the best compromise between show of and utility.
Akshay1234 is offline
Old 22nd September 2008, 21:46   #2128
ImmortalZ's Avatar
Thanked: 601 Times
I disagree, but I don't want to argue
Old 23rd September 2008, 02:05   #2129
akshay4587's Avatar
Thanked: 4,722 Times
you got it all wrong here
even a 8000K HID though irritating is better than halogens
akshay4587 is offline
Old 23rd September 2008, 10:25   #2130
Thanked: 11 Times
Guys I am furthur confused now....
Do I go with Philips 6000k (Rs. 8500) or with 4300k Chinese brand (9500 Rs).
