Old 28th June 2010, 12:32   #3976
Guys - Anybody know where I can get H1,H7 ceramic holders in Bangalore? I've only seen H4 ceramic holders in the shops.
thanks
bdubya is offline
Old 28th June 2010, 21:34   #3977
Aniket6's Avatar
Thanked: 242 Times
Hello, I have been searching to upgrade my Fiesta's headlamps to 100/90.
The problem is it has separate bulbs for low beam and high beam.Therefore, a lot of shops i inquired claim that its not possible to upgrade Fiesta's lamps to 100/90, while others claim that its very risky and problematic.
Is that true?
If not where might i get them in Bangalore?
Aniket6 is offline
Old 30th June 2010, 17:01   #3978
Ushuaia's Avatar
Thanked: 23 Times
Need help, I have a 2003 Zen mpfi with glass lens. I have had Crystalvision and Visionplus and just dont help especially for highways. I have also used Philips 100/130 for 2.5 years with exceptional performance
My query
1. Can i change my current prism lens to Zen Carbon (2 door) clear lens, if yes who (MASS or Accessory Dealer) can help
2. Will put 130/100 again, also with glass lens I find the lighting amazing but is there any known issue with older zen reflectors
3. How can I brighten pilot lamps, though I run good headlamps, but the pilot lamps just look so shriveled compared to the headlamp. After lot of inquiry, no success.
Ushuaia is offline
Old 30th June 2010, 17:27   #3979
kishoryk's Avatar
Ford Fiesta Bulb type
100/90 type spec is usually meant for dual filament bulbs such as H4. These are for Dual-headlamp cars. For the quad type ones you have on your car, you might have H1 + H7 combination for short and long beams. You can get these details from your car manual (some section that talks about replacing parts) or other fellow owners.
Once you determine the bulb type, you can then look for performance bulbs of that same category. For my case, I have both H1 type bulbs in short and long beam pair of headlamps and I use Osram night breakers on both the two pairs. They work pretty fine for me.
HTH,
KK
kishoryk is offline
Old 2nd July 2010, 18:49   #3980
kishoryk's Avatar
Hella Relay
Originally Posted by kishoryk View Post
My existing relay looks like this:
(Courtesy: http://images.solidcactus.com/autobarn/hel87106.jpg)
Any idea, where can I get a spare of this relay
Thanks in advance!
Cheers,
KK
kishoryk is offline
Old 5th July 2010, 22:14   #3981
Schoudhury's Avatar
Thanked: 483 Times
Auxillary Lamps For Ritz
Hi Friends.
I wanted to check , if its possible to fix auxiliary-lamps in Ritz.
I feel the front of the Ritz will look really nice with auxiliary-lamps fitted and moreover it will also help to improve the visibility ( the stock lamps are bad, real bad ).
Please advise , and also how much does good pair of lamp costs ?
Saw a couple of safari's with Light Force lamps, they looked really nice.
Schoudhury is offline
Old 5th July 2010, 22:52   #3982
Can some one help me in focusing the headlight of OHC Type 2 . I remember that i saw some photos of the adjusting nut but couldnt recollect in which thread ?
vinu_pm is offline
Old 5th July 2010, 23:24   #3983
kingofmyworld's Avatar
Thanked: 537 Times
Originally Posted by Schoudhury View Post
Hi Friends.
It is possible to fix auxiliary lamps. Get hella auxilarys if you have a small budget, say around 5k. If you don't mind spending more stacks, then get light force. they cost around 10k + ( if you want driving lights )
kingofmyworld is offline
Old 6th July 2010, 07:25   #3984
josejoseph's Avatar
Thanked: 408 Times
Dear Schoudhury,
Last day I checked with an accessory shop in Cochin for Hella Comet 450 series. They have it for 3K for a set. I don't remember if it included wiring harness.
Thanks,
Jose.
josejoseph is offline
Old 6th July 2010, 12:06   #3985
Thanked: 537 Times
Originally Posted by josejoseph View Post
Dear Schoudhury,
Thanks,
Jose.
Hella supplies all its light range with the wiring harness, mounting brackets , fuses etc. If you spend a few grand more, you can probably get hella projector lamps. like the one posted below, reviews say its prety good. check on ebay for hella optilux 1102.
OT : I ordered it along with H3 hids. Eagerly waiting for it to arrive
Auto Lighting thread : Post all queries about automobile lighting here-optilux1102electronbluedefoglightslarge.jpg
Old 6th July 2010, 12:20   #3986
shyamhegde's Avatar
That is a good one I suppose. Any price and order term details please ?
shyamhegde is offline
Old 6th July 2010, 12:24   #3987
Thanked: 537 Times
Costs appx 120-130 $ for both HID and the projectors. If you want only projector then it'll sum up to 90$ including shipping. I'll post a review once I get the product. I'll be doing the install as always so guys, Need some hints on where to mount it. ( btw, I drive a 5 speed mpfi M800 )
Old 11th July 2010, 20:42   #3988
msaudf's Avatar
Thanked: 164 Times
Hi Guys,
is it a good idea to replace halogen bulbs to HID in the older type non clear lens headlamps?
i'm not thinking of adding projector lenses but just replacing the bulbs. to my best knowledge i think they'll work fine, but i tired to look at other conversions on older cars and they all have replaced their glass lenses to clear lenses. what do you guys think... will the conversion work by just changing the bulbs??
oh and the car i'm talking about is a 1984 Mercedes W123
msaudf is offline
Old 11th July 2010, 20:46   #3989
Mr. Nobody's Avatar
Thanked: 637 Times
Originally Posted by msaudf View Post
Hi Guys,
is it a good idea to replace halogen bulbs to HID in the older type non clear lens headlamp?
i'm not thinking of adding projector lenses but just the bulbs. to my best knowledge i think they'll work fine, but i tired to look at other conversions on older cars and they all have replaced their glass lenses to clear lenses. what do you guys think... will the conversion work by just changing the bulbs??
non clear lens one will block a lot of usable light . you can anyway upgrade to HID kit now and if too much light is being blocked you should go for clear lens .
Mr. Nobody is offline
Old 12th July 2010, 03:08   #3990
msaudf's Avatar
Thanked: 164 Times
is that right?? if thats the case then I'm gonna stick to 100/90 halogens and my original headlamps and maybe go for the hella optilux 1102 as another member is opting for.
cheers mate
msaudf is offline
