Old 21st February 2013, 23:18   #6961
Thanked: 21,238 Times
Originally Posted by el lobo 6061 View Post
Bhpians need help on headlight relays.
Current setup in my Vento is 100/90W bulbs with PMP relay. It has two 30A fuses which tend to go out say within 5 days with usage of headlights for 1.5 hr during return drive from office.
Think you should remove and reinstall connections to be on the safer side. Maybe there is a loose contact somewhere which is spiking up and fluctuating current now and then. I have PMP relays which havent caused a problem in two years.
Lastly can someone provide a way to install & uninstall relay DiY, as I don't like road side mechanic messing up with my car's electrical's. From my understanding of current installation, there is one relay which takes care of both headlamps and has a wire from battery going to the relay and both ceramic holders having a black earthing wire screwed to metal.
Thanks.
If you want to remove the relay only, its as easy as replacing a blown fuse. The relay meant for headlamps have a connector, one on the relay and the female attached to the harness. Grasp both by either hand and pull apart. Just make sure there is no other fastening like a clip or so. If there is, remove or press it first. Removal of the harness is also quite easy. You need to get hold of a cutting plier or spanner usually of 10mm size. Start from the battery connections and end with the male pin of the harness that goes into the stock holders.
Old 24th February 2013, 01:28   #6962
el lobo 6061's Avatar
Thanked: 2,401 Times
Thanks for the reply. Checked for loose connections, none found.
Another question : What if I replace the 30A fuse with a 40A fuse? Will it cause any troubles? Since extra 10A would aid in more current delivery and wouldn't cause 40A fuse to melt out which in the case of 30A is a regular affair.
Please advice.
el lobo 6061 is offline
Old 24th February 2013, 17:51   #6963
sohail99's Avatar
Thanked: 235 Times
Please advice.
I think it'd be safer to replace it with a new relay harness(philips) and use a little silicone dielectric grease on the connections!
Replacing 30A with 40A fuse is not a good idea!
sohail99 is offline
Old 24th February 2013, 21:10   #6964
Fortuner71's Avatar
Thanked: 345 Times
Dear team bhpians please suggest auxiliary lights for my strome . I do regular night drives on the highways , though the existing lights are good , extra lights with a longer range will be of help during night drives on lonely stretches. Also suggest places to buy in Bangalore . Thanks in advance .
Fortuner71 is offline
Old 25th February 2013, 19:13   #6965
Chetan_Rao's Avatar
Thanked: 28,310 Times
Any downsides to downgrading to OEM bulbs from a relay-based 100/90W setup?
Car in question is a Hyundai Accent 1.5P.
The headlamp assembly gets a bit too hot after a couple of hours of night driving with the 100/90 bulbs, and I don't want trouble on a long drive planned this weekend. I never got these installed in the first place, and I'm not too keen on retaining the setup if I can get decent lighting with an OEM-rated bulb. I also have OEM fog-lamps installed, if that helps in mitigating some of the illumination lost with the downgrade.
Are Philips XtremeVision 100+ (60/55W rated) available off the shelf easily?
Chetan_Rao is offline
Old 25th February 2013, 20:06   #6966
Akshay1234's Avatar
Thanked: 12,919 Times
Since your car has projectors, get a good HID kit installed. 4300K to give you good visibility. Get a reputed brand like Philips or something, don't worry about the warranty since the HID has its own wiring. But do make sure you go to a good installer.
Then for the high beam bulbs, upgrade those to something like extreme vision, which should again give some more light. Only after these, if you still find the light output lacking, then look at Aux lights.
Akshay1234 is offline   (1) Thanks
Old 25th February 2013, 23:40   #6967
Changed the relay today with ROOTS for Rs 1000 with installation from Opera House. I think I overpaid by huge margin. What are your all views about the ROOTS brand?
Old 26th February 2013, 08:01   #6968
1k just for the relay? You must be kidding. You could have got a phillips relay + entire wiring harness for that amount, leave any other brand. The common relays I have seen is from Roots, PMP, Lumax and Bosch, which is not available lately as far as I know. It is a reputed brand when it comes to lights and horns. But you paid a lot. A headlamo relay costs less than 350, unless you got the entire harness changed.
audioholic is offline
Old 26th February 2013, 08:37   #6969
sagarpadaki's Avatar
Thanked: 6,848 Times
You are kidding right? 1K for a relay is daylight robbery. Last time i checked in bangalore, hella 40A relay costed 350 in bangalore!
Roots is a good brand.But unless you have changed the entire wiring harness, 1K is robbery!
sagarpadaki is online now
Old 26th February 2013, 10:21   #6970
I got the complete wiring harness with dual head lamp relay. I guess I still paid a lot. How much does ROOTS wiring harness with dual head lamp relay cost? I had sent the driver to have it changed, seems he made a buck for himself.
Old 26th February 2013, 10:26   #6971
Think the wiring harness of most brands cost 400-500. Add 200-300 for the relay. That means you paid more. Only the phillips kit coated some 1100+ that too in reliance autozone. Think outside it will come to around 1k rupees.
Old 26th February 2013, 19:39   #6972
Thanked: 41 Times
Hey buddy...can u share the pics of your leds and prefarable a video from you tube of ur car will help us to view this nice work ..
pratap.pratu is offline
Old 28th February 2013, 13:25   #6973
Rajesh Rawal's Avatar
Thanked: 159 Times
Not sure if this needs to be here ,thought i'll share.
Got this fixed on my santro ,these are Hyundai 'ghost lights'.Looks pretty cool eh!(apologies if the picture quality is sub standard)
Auto Lighting thread : Post all queries about automobile lighting here-new-image.jpg
Rajesh Rawal is offline   (3) Thanks
Old 28th February 2013, 17:00   #6974
Sommos's Avatar
Thanked: 1,592 Times
Yeah, it looks good. Is this a DIY ?
Would you mind sharing the cost and from where you procured the material.
Sommos is offline
Old 28th February 2013, 18:31   #6975
Thanked: 159 Times
Got it online from dailyobjects.com .inr 1700 for 2.(There are other brands as well vw/honda/suzuki etc)
Got it fitted through a local accessory shop ,this requires a drill towards the bottom of the door for the lights to be placed there.the moment you open the door it will flash on the floor.
You can always have an on/off switch option incase you dont want it to beam everytime
Cheers,
RR
