Old 27th November 2016, 17:00   #10186
ayankm's Avatar
Thanked: 171 Times
Originally Posted by Aston Singh View Post
Guys, out of these two which one is better or are they equally good/worse?
Osram Nightbreaker Unlimited
http://www.amazon.in/Osram-P64193-Ni...headlight+bulb
I have replaced the stock H4 in my Eon with the Osram Nightbreaker and its a really really good bulb. The throw in low beam mode goes far enough for safe driving. You can give it a try and will not regret.
ayankm is offline   (2) Thanks
Old 30th November 2016, 11:14   #10187
Thanked: 104 Times
I own a Hyundai Xcent and after my recent run to Goa, i feel to change the stock lamps. I spoke to my Service agent and he says that they are of Hyundai make (12V, 60/55W). Will there be any difference if i change to Philips or Osaram with the same ratings or shall i upgrade to Philips 12569EVB1 H4 Essential Vision Headlight (12V, 100/90W). I don't want to tamper with the inner wiring's and warranty.
HighwayHopper is offline
Old 30th November 2016, 15:15   #10188
Thanked: 9,552 Times
Originally Posted by HighwayHopper View Post
Shall i upgrade to Philips 12569EVB1 H4 Essential Vision Headlight (12V, 100/90W).
100/90W is any day a better option. This will need a relay to be fixed. This is a common thing many car owners do and haven't heard of any warranty declines due to this setup yet.
abirnale is offline   (1) Thanks
Old 1st December 2016, 10:34   #10189
tharian's Avatar
Thanked: 8,642 Times
The bright mode of my car's headlamp failed on one side. It is 100/90 bulb which was replaced with the stock ones with a relay fitted.
I have the stock bulbs the car came with . Is it possible to fit them back although there is a relay fitted for the 100/90 or does the relay and wiring have to be removed .
tharian is offline
Old 1st December 2016, 10:42   #10190
condor's Avatar
Thanked: 16,889 Times
You can directly put in the stock 55/60 W bulb without any changes to the wiring.
The idea of the relay was to support the higher current required by the 90/100 bulb. This can very easily support the lower current required by the stock bulb.
Old 2nd December 2016, 14:39   #10191
aaggoswami's Avatar
Thanked: 3,000 Times
I believe your query is already being addressed, but still would chip in.
The H4, 60/55W bulbs are mostly of Phenoix make that Hyundai offers in Eon, Grand i10 in general.
Upgrade the wiring with relay when you are planning to install H4 100/90W bulbs. Here is wiring kit : http://www.amazon.in/Philips-12003XM...ng+kit+philips
For bulbs, Philips Rally are the best when it comes to sheer amount of light throw. But I faced alignment issues with them, and my Swift (still in warranty) is running Lumax wiring kit with Osram H4 100/90W bulbs.
If you still want to stick to 60/55W bulb, I found Ring Automotive Ultima +130 the best of all bulbs (in 60/55W range) I have used till date. I had them in my Grand i10 and those bulbs made night drives better. Also, get the beam alignment done if you plan to install new bulbs. There is separate thread for alignment of lights.
aaggoswami is offline   (2) Thanks
Old 2nd December 2016, 15:23   #10192
condor's Avatar
If I want to replace the H3 bulbs in my fog lamps with LED type, can I do a direct swap ?
condor is offline
Old 2nd December 2016, 15:33   #10193
Thanked: 33 Times
Hi!
I am in search of Ring Automotive Ultima +130. Where did you buy them from?
ronello is offline
Old 3rd December 2016, 00:40   #10194
aaggoswami's Avatar
Originally Posted by ronello View Post
Hi!
Here is the link on Flipkart.
https://www.flipkart.com/ring-xenon-...me3jqdkhkzn3ut
And another link : http://www.epitstop.in/Upgrades/Ring...id-944795.html
In my case, a first set I ordered from Flipkart was defective, it was replaced by a genuine set and the real difference was in high beam. I would recommend it over Philips Xtreme Vision +.
Old 6th December 2016, 08:20   #10195
Thanked: 104 Times
Since how long have you been using Ring Automotive Ultima +130. Are they durable? I will look at both these options. Thank you for your suggestions.
Old 6th December 2016, 12:15   #10196
arindambasu13's Avatar
Thanked: 2,558 Times
The 100/90 Philips Rallys that I have just installed (along with the necessary relay wiring) heat up the headlight outer casings real fast, within a few minutes of usage. Is there anything that I need to be concerned about? Any potential pitfalls? I know this is a common occurrence with higher powered headlamps, but are there any complications that usually lead out of it? The vehicle in question is a Swift VXI.
Look forward to hearing from users of upgraded bulbs.
arindambasu13 is offline
Old 6th December 2016, 14:37   #10197
Thanked: 21,451 Times
Originally Posted by arindambasu13 View Post
The 100/90 Philips Rallys that I have just installed (along with the necessary relay wiring). The vehicle in question is a Swift VXI.
I am using this combination from approximately 2 years/70,000 kms in my Swift ZDi. You can check my ownership thread for details.
Till date no issue, no kind of damage to reflector or any kind of discoloration.
I love the setup and recommend to many.
Old 9th December 2016, 13:52   #10198
Thanked: 104 Times
Thanks for your suggestions on the wiring kit. I will go with this.
I dont see much reviews on Philips H4 12v 100/90 P43t Rally. Are these the bulbs you are using ? If this is good, then i will go with the below combination.
Philips 12003XM H4 Heavy Duty Relay Wiring Kit for High Power
Old 9th December 2016, 20:15   #10199
Here's are the bulbs and wiring harness that I am using in my Swift.
Using this bulb currently
Old packaging of the same bulb that I am using
Wiring harness that needs to be used with the bulbs
Old 12th December 2016, 11:26   #10200
Thanked: 104 Times
Thank you a4anurag. I met a local accessory guy who was talking about Lumex relay kit and was insisting me to go with this by saying that it was much better than Philips. He also said that he will only install the kit and if there were any alignment issues then that needs to be sorted out by an electrician. I will visit Ministers road this weekend and see if I find this original Philips combination from any of them.
