Old 29th March 2019, 09:18   #676
Thanked: 33 Times
Re: VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread
I'm in the market for scanner. Found this interesting from the aftermarket section. https://medium.com/@shijiavs2012/vcd...0-4c653f7f8c71
Talked to the guy via WhatsApp. Details verified with original software update and support.
Has anyone tried this cable. Shall I proceed to buy?
anoop.nair is offline
Old 29th March 2019, 10:03   #677
MileCruncher's Avatar
Thanked: 1,374 Times
So essentially the extra $30 is for the software update support? But is it genuine RossTech? Doesn't seem so as you have to update / activate the software thru them.
MileCruncher is offline
Old 30th April 2019, 21:41   #678
Thanked: 627 Times
Hey,
For how much can we procure a "proper working" vagcom cable? By proper I mean with a reliable software and the cable.
Also, I'm from Hyderabad and I need this for a one-time use only. Can anybody from Hyderabad lend me one?
Thanks and Regards
Sarfraz Khan
sarfraz1997 is offline
Old 1st May 2019, 10:55   #679
graaja's Avatar
Thanked: 25,731 Times
Originally Posted by sarfraz1997 View Post
Hey,
Thanks and Regards
Sarfraz Khan
There is only one option if you need a "reliable" cable - the original RossTech cable which sells for $200 for 3 VIN numbers. Any other cable is a duplicate and just a matter of luck if it works with all the controllers in your car.
Having said that, if you are just planning for a one time use, then the original cable does not make sense. You could just order one from AliExpress. The AliExpress cables mostly work for the common tweaks done on the BCM. Only if you are looking for some advanced settings like brake assist, XDS etc., they have chances of not working.
graaja is offline   (1) Thanks
Old 1st May 2019, 15:25   #680
Thanked: 627 Times
Thanks for your input. I found this place called GT Tunerz in Hyderabad who have the VCDS cable and would offer services based on the same. They charge 500 for one use. I'd now like to know what all features can be activated on a 2011 MK6 Jetta Highline. Any suggestions are welcome
Thanks and Regards
Sarfraz Khan
Old 31st May 2019, 11:09   #681
Thanked: 133 Times
Hello boys (and girls?). I am unable to figure out which one of the below two is best suited for my GT TSI May 2019 model. Any help will be appreciated muchly.
VAGCOM 18.9 USB Cable & VCDS 18.9 Original VAG-COM Software:
https://www.totalcardiagnostics.com/shop/vagcom-vcds-18
VAG-COM VCDS 2019 - OBD2 Diagnostic Cable & Software
https://www.totalcardiagnostics.com/...-rosstech-vcds
The latter is a whole 9 Heinekens cheaper.
keith2524 is offline
Old 6th July 2019, 13:24   #682
Thanked: 133 Times
Update: I have purchased and received a VAG COM VCDS 18.9 cable on AliExpress. Installed the provided software on a Windows 10 installation (on MacBook via Bootcamp). The cable seems to be active and all the buttons on the software are enabled. Have not tried connecting it to the car yet, but all seems good. Will update further when I have a chance to hook it up and play with it. Photos attached.
VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread-img_7798.jpg
VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread-img_7799.jpg
Last edited by aah78 : 25th July 2019 at 19:51. Reason: Pictures inserted in-line.
keith2524 is offline   (1) Thanks
Old 21st July 2019, 22:15   #683
unknown's Avatar
Thanked: 23 Times
Need help!
Car ac not throwing air from middle both vents out of sudden, both corner vents working with cold air flow, just checked for error code with vcds cable, anybody can guide what's wrong & whether it can be corrected itself or not?
These are the fault codes -
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CJLA) Labels: None
Part No SW: 03E 906 019 AQ HW: 03E 906 019 AQ
Component: SIMOS11.2 H04 1968
Revision: --H04--- Serial number:
Coding: 00110016032400000000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12MPI02103E 001001
ROD: N/A
VCID: 73E53947DA40F386991-8026
No ASAM data for: "EV_ECM12MPI02103E" (VW25)
3 Faults Found:
7118 - ROD - Unknown Error Code
- 00 [100]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 78181 km
Date: 2016.10.14
Time: 16:33:17
6322 - ROD - Unknown Error Code
- 00 [096]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 74318 km
Date: 2016.09.03
Time: 19:53:33
16882 - ROD - Unknown Error Code
- 00 [096]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 78162 km
Date: 2016.10.14
Time: 13:43:15
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BP HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0003
Serial number: --------------
Coding: 60DD2763212A18C7061CE46A845318000000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 8D11CFBF5CA405766F5-80D8
1 Fault Found:
0909 - Please Check Fault Codes in Engine Control Module
U101F 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 233
Mileage: 74318 km
Date: 2016.09.03
Time: 19:53:34
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 4189A38FD87C1116DBD-8014
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 234
Mileage: 77634 km
Time Indication: 0
Date: 2016.10.08
Time: 21:24:52
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 086 P HW: 6RU 937 086
Component: BCM IM M+4 H41 0444
Revision: BY041001 Serial number: 8600 261160292
Coding: 3AB02BFF08A10000013800006E2B069000C0600F608E010022 0000000A00
VCID: 6ED32833B962DE6E76F-803B
Subsystem 1 - Part No: 5K7 955 559 C
Component: RLS 110716 04 42 0106
Coding: 036800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2551
Coding: 000000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED
Component: J387__TSG_BT 023 2551
Coding: 000000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H06 0023
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1552
Coding: 000000
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1552
Coding: 000000
2 Faults Found:
03302 - Response Closing Status of Passenger's Door
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 254
Reset counter: 224
Mileage: 58427 km
Time Indication: 0
Date: 2016.03.21
Time: 03:49:23
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 5
Reset counter: 251
Time Indication:
Address 44: Steering Assist (J500) Labels: Redir Fail!
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisNSK 014008
ROD: EV_SteerAssisNSK.rod
VCID: 4189A38FD07C1116DBD-8014
1 Fault Found:
0196 - Supply voltage
U1011 00 [008] - Voltage too Low
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 HW: 6RF 035 187
Component: Radio 018 0120
Revision: -------- Serial number: VWZGZ1S2540454
Coding: 0000040000000F
VCID: 06037093B1D2F62EAEF-8053
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 39187 km
Time Indication: 0
Date: 2015.09.03
Time: 00:00:23
Freeze Frame:
Temperature: -0.0°C
Any help would be really appreciated!
unknown is offline
Old 22nd July 2019, 01:14   #684
Thanked: 37 Times
Originally Posted by unknown View Post
Need help!
This could be an issue with the alternator not charging properly. Please get your battery and alternator checked. How did you find the issue? during a cold start or while driving?
Last edited by Gannu_1 : 22nd July 2019 at 04:53. Reason: Trimming quoted post. Please avoid quoting a large post as it inconveniences small screen users. Thanks.
Darkman is offline
Old 22nd July 2019, 07:41   #685
tbppjpr's Avatar
Thanked: 2,396 Times
Need help!
Is it manual or auto AC?
If the air flow is set for 'legs' then the middle air vents stop throwing air but side vents keep throwing the air in the VWs, check the air flow settings first.
tbppjpr is offline   (1) Thanks
Old 22nd July 2019, 08:17   #686
graaja's Avatar
Need help!
Revision: V0000000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 234
Mileage: 77634 km
Time Indication: 0
Date: 2016.10.08
Time: 21:24:52
The fault indicates positioning motor for central flap could be having a problem. Could be some simple mechanical issue like stuck flap, or electrical issue like the motor gone faulty. I think it would be possible to check only after opening the system.
Also, all the faults have time stamp with year 2016. Could be the clock in the car has a wrong date. What is the present Odo reading in your car?
Old 24th July 2019, 09:07   #687
Thanked: 42 Times
Hello guys
Can we deactivate rain sensing activity used for the wipe? It works weirdly and I feel manually operating it would be good for me.
Kindly let me know please.
Prash is offline
Old 24th July 2019, 11:51   #688
adi_petrolhead's Avatar
Thanked: 2,658 Times
It is possible to de-activate it in the head unit under car settings. At least possible with my MY14 Octavia with the MIB I unit.
adi_petrolhead is offline   (1) Thanks
Old 25th July 2019, 17:42   #689
cosmic_ocean's Avatar
Thanked: 308 Times
Originally Posted by Epic View Post
'Interface: Not Found'. In this case you will need to contact the team at OBDTool.
In my case, they weren't able to resolve the "Interface not found issue". The cable doesn't work. They stopped answering my whatsapp and email thereupon. We buy it with our hard earned money and get duped with such people. Avoid these Chinese scamsters and buy the original.
cosmic_ocean is offline
Old 25th July 2019, 22:56   #690
Thanked: 42 Times
Not there in my Passat
Prash is offline
