Old 30th January 2019, 11:07   #661
epicenter.rulez's Avatar
Thanked: 277 Times
Re: VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread
Hi Gaaij,
I got the cable that I had ordered from EOBDTools along with the CD. It took all of 8 days to reach me and I paid around 3700 INR including shipping and everything. I went to their support page during the installation itself and followed it to the letter.
I also sent a Whatsapp message to the EOBD support number and I must say they are a fabulous lot of people. Even though they are closed on weekends, they rushed through and sent me the registration patch. I then activated the software, updated the firmware as well as the software to 18.9.1 and all looks good.
Now for some fun.
Drive safe, always wear a seat-belt
Last edited by navin : 30th January 2019 at 13:14. Reason: typos and missing articles.
epicenter.rulez is offline   (1) Thanks
Old 30th January 2019, 13:12   #662
WasavaTyres's Avatar
Thanked: 459 Times
I've managed to deactivated high beam through my stalk. Don't know what I have selected / deselected wrong via VCDS but unable to bring it back on despite fiddling with some settings. Can anyone help ?
WasavaTyres is offline
Old 30th January 2019, 23:55   #663
Akshay1234's Avatar
Thanked: 12,914 Times
Will probably be something to do with bi-xenon or high beam settings. Do check central electric again and see what it might be. Did you not save the original long code?
Akshay1234 is offline
Old 31st January 2019, 12:23   #664
swissknife's Avatar
Thanked: 1,434 Times
While talking to someone I know, he said that it could probably something to do with the Control Module ->[Instrumentd Module -> Advanced Function Coding 07. The 5th digit should be 4.
Try this out without saving the config. If you have to save it, you may want to take note of the original value to revert to if it doesn't work.
NOTE: I am not an expert in VCDS and this info is from another person who knows a little bit.
swissknife is offline
Old 1st February 2019, 11:10   #665
Thanked: 459 Times
Lesson learnt albeit a little late in the day.
Also, the headlamp washer and windshield washer do not work from the stalk. I removed the washer motor and connected it to a battery and it whirred to life. Ran a windshield washer check from VCDS and it works from there. I guess the wiper stalk has gone bad.
Old 4th February 2019, 12:00   #666
Thanked: 459 Times
So sunday morning was spent resolving the issue. I had managed to turn off 'Headlight assist' and HBA [High Beam assist]. Fixed now.
Old 13th February 2019, 11:08   #667
Thanked: 277 Times
Hi Gaaij,
Noobie question.
Is cluster staging/indicator celebration possible on the 2011 Passat HL DSG?
Tried it through VCDS but it says no channel available.
Screenshots of the same for any advice
Any help appreciated. TIA
VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread-img20190210wa0029.jpeg
VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread-img20190210wa0031.jpeg
Old 13th February 2019, 11:47   #668
Gannu_1's Avatar
Thanked: 20,675 Times
Originally Posted by epicenter.rulez View Post
Hi Gaaij,
Noobie question.
If it says Channel not available, you'll have to scan the cluster's EEPROM and recode it. VCDS unfortunately won't be able to help here.
Check out this video:
Gannu_1 is offline   (2) Thanks
Old 20th February 2019, 14:12   #669
Thanked: 17 Times
I have polo gt tsi (2019), 10 days old. After going through this thread, had bought VCDS cable from eobdtool (18.9). I was able to modify lane change indicator, tear wiping from the Central Electronics menu. But on ABS Brakes, adaptation is grayed out. Any one faced this issue before?
VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread-eobdtool.jpeg
pradeepmr is offline   (1) Thanks
Old 20th February 2019, 15:25   #670
MileCruncher's Avatar
Thanked: 1,332 Times
I now have a GT TSI and Laura TSI, and hence in utter need of a VAGCOM. Will V18.2 work for me or do I need to get something else.
Please help.
MileCruncher is offline
Old 28th February 2019, 09:24   #671
I just ordered the VCDS cable from AliExpress. 18.9
https://www.aliexpress.com/item/VAG-...212f4c4dMirOf9
Lets see if this works or not. Fingers crossed.
Old 17th March 2019, 23:42   #672
I got the cable and ran diagnostic on the Polo GT TSI.
The log is as follows:
Saturday,16,March,2019,09:32:15:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
Chassis Type: 6RU
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6RU 937 087 R HW: 6RU 937 087 R
Component: BCM IM H+4 H42 0452
Revision: BZ042001 Serial number: 6800 141180007
Coding: 3AB02BFF08A10000013800006E2B069000C0600F608E010022 0000000A00
Shop #: WSC 124697 483 00190
VCID: 71E963C5A8A91DC22A-8024
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 050418 04 47 0106
Coding: 0368DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2551
Serial number: 13202848180414091705
Coding: 000000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2551
Serial number: 13102849180417152939
Coding: 000000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1552
Serial number: 13102728180414111005
Coding: 000000
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1552
Serial number: 13102729180418071733
Coding: 000000
No fault code found.
Address 15: Airbags
Cannot be reached
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 087 R
Component: GW-K-CAN TP20 H42 0452
Revision: BZ042001
Coding: 002300
VCID: 19397B651099B58232-804C
Address 25: Immobilizer
Cannot be reached
Address 44: Steering Assist
Cannot be reached
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 04:00)--------------------------
And am unable to reach the controller. This is the screen shot
Name:  Polo Session Log 1.png
What should I do>
Old 18th March 2019, 06:51   #673
graaja's Avatar
Thanked: 25,620 Times
What should I do>
Unfortunately, nothing other than buying another, I guess. Or send a note to the vendor and see if he has any solution.
Cables from AliExpress are always a hit or miss. They hack into the software available at that time and the cable will work only with that version of software. And you may not be able to communicate with all the controllers.
I had tried two AliExpress versions when doing some casual coding, and both these cables did not read some controllers in my Polo GT and the Jetta. When I upgraded to the original cable from Ross-Tech, everything worked smooth. With the original cable, even if a controller does not exist in their database, you can contact their support and they will add the new controller to the database and release an update to the software.
graaja is offline   (1) Thanks
Old 20th March 2019, 10:53   #674
Thanked: 17 Times
I tried two cables on 2019 GT TSI, one from EOBDTOOLs and another from Aliexpress. Both couldn't read most of the controllers. Vendor at Aliexpress mentioned that it won't support 2019 models. As suggested by graaja, original cable seems to be safe bet.
Old 20th March 2019, 11:59   #675
My GT TSI is MY July 2018. Problem is its not reading a MYJuly2018 Laura TSI also.
someone help. The vendor has suggested some steps and given me a new software download link.
