Old 5th January 2021, 14:30   #766
abhinavinc's Avatar
Thanked: 85 Times
Re: VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread
Originally Posted by Sen View Post
Awesome! Can I ask you for help then? My cable is gonna take weeks.
Auto-unlock on ignition off has been disabled I think on my car already. The car doesn't unlock until a passenger pulls the door handle to leave the car.
And without request sensors, it'll be difficult managing the other occupants needing to get in or to get somehing if I enable only driver door upon remote unlock, which is something that happens to me a lot.
Originally Posted by sivasain View Post
Sure. I stay around whitefield side. But travelling till new years. PM me and we can sync up
Thanks for offering to help Sen. I stay in Whitefield as well, possible for me to join the meetup as well? This will be the first time for me to configure on my Skoda Fabia.
abhinavinc is offline   (1) Thanks
Old 5th January 2021, 17:21   #767
Sen
Sen's Avatar
Thanked: 530 Times
If it helps, I got my VCDS cable finally, so I haven't taken up Sivasain@'s offer. Hit me up if you're near Ecity phase 1 after 19th January! (gonna be in Hyd)
Sen is offline   (2) Thanks
Old 6th January 2021, 09:11   #768
Thanked: 275 Times
Just putting this here and hoping for the best.
Any BHPian in/ around Chennai with VCDS who could help out with a Polo? Specifically, to make the MID usable after 80+ kmph.
Thanks!
SS8939 is offline
Old 7th January 2021, 11:32   #769
Thanked: 400 Times
Request to Hyderabad BHPians, if anyone who can lend their VCDS cable so that I can make the following changes to my Vento.
Comfort turn signal to 5 clicks
Time to 24H format
Needle sweep
Unable to procure VCDS cable from Aliexpress.
Tried making the changes at PPS motors Gachibowli/Kukatpally, however, their software does not show the above changes in the system.
I can get my car for a small catchup and make the changes
cormodore is offline
Old 7th January 2021, 16:02   #770
Request to Ahmedabad BHPians, if anyone who can lend their VCDS cable so that I can make the following changes to my Vento 1.2 TSI as i'm unable to procure VCDS cable from aliexpress
Brake Assist to Early
Emergency Braking Flashing lights check
Reverse buzzer sound to a lower tone
Needle sweep/indicator celebration/staging on
Tear wiping
Also can't get hold of tuner in Ahmedabad who would help out.
Achalchoukhany is offline
Old 7th January 2021, 20:38   #771
Sen
Sen's Avatar
Thanked: 530 Times
Time to 24H format
Needle sweep
You're in luck! I'll be in Hyderabad from 9th - 17th Jan! Hit me up via PM.
PS - I tried getting the time to 24H format on my Vento, it sorta failed to do that. But trial and error is the name of the game!
Sen is offline   (1) Thanks
Old 8th January 2021, 14:00   #772
Thanked: 110 Times
Tear wiping
I have a VCDS cable plz DM me
amit_i is offline   (1) Thanks
Old 8th January 2021, 14:07   #773
I still dont have the privilege to pm other BHPians. Please if you could ping me on my cell number- 9925016620. Whatsapp or call or sms would do. Thanks ��
Old 8th January 2021, 16:27   #774
Thanked: 400 Times
Hi Sen,
Thank you for responding. Unable to PM you as I am a newbie.
If you can PM me, pls do so. Else, request you to drop me a note to my mail id sudakr@gmail.com with your mobile number and I can connect.
Old 12th January 2021, 14:12   #775
Thanked: 48 Times
Thanks!
Am based out of Adyar. Let me know what you need. I have a V20.4.2 cable.
Drop me a private message.
vasanthjn is offline   (1) Thanks
Old 12th January 2021, 14:18   #776
Thanked: 48 Times
I have a 2015 HL AT Jetta. Need help with respect to the ORVMs.
I read in this thread that it is possible to Open / Close the ORVMs through the Keyfob. Please let me know if anyone has tried that.
Alternatively is it possible to Open / Close the ORVMs based on the ignition input?
Also once intpo the VCDS, am not able to access only the Instruments (I think Section # 17) section. Is anyone facing this issue?
Old 12th January 2021, 14:39   #777
Thanked: 787 Times
It is possible if you have a Jetta Highline with ORVM adjustment on the doorpad. I have done it on my Passat Highline - originally done on a Jetta. See https://www.team-bhp.com/forum/offic...ml#post4801639 (Volkswagen Jetta : Test Drive & Review)
rpunwani is offline
Old 13th January 2021, 22:11   #778
Hello Amit, i don't have the privilege to dm other BHPians, Please contact me on 9925016620 whenever possible for you.
Old 21st January 2021, 17:26   #779
Thanked: 30 Times
Hi guys. Wanted some advice. Friend has a 2011 Polo Comfortline and wants to enable the usual bunch of features. Would you'll recommend getting a VCDS cable or an OBDeleven adapter ? Any other suggestions are welcome too.
revvhed is offline
Old 6th February 2021, 22:56   #780
Thanked: 48 Times
Thanks a lot. I tried it today and in the first attempt it didnt work. Later when I enabled the comfort windows option, it worked. Once again thanks a lot.
