Old 15th June 2018, 11:25   #1171
navin's Avatar
Thanked: 9,957 Times
Re: The Damping Material and Sound Deadener Thread
Originally Posted by IshaanIan View Post
STP Silver getting a pack of 10 sheets of 2mm thickness for about 9k
i-COPPER i-D9 getting a pack of 9 sheets of 2mm thickness for 6k
i-COPPER i-D5 getting a pack of 5 sheets of 7mm thickness for 5.5k
Now the main difference between the STP Silver and i-COPPER i-D9 of comparable 2mm thickness, is that STP uses silver.
The other difference between the 2mm sheets and the 7mm i-COPPER i-D5 sheets that I could make out is that the i-D5 sheets come with a layer of foam. How important is this layer of foam?.
I am sure there is no real silver or copper in any of these packs. Most of them have an aluminum backing.
Get the pack with the 5mm of foam. If you want to understand more about this google "Constrained Layer Damping". The foam in this case helps a lot.
Hope this helps.
navin is offline   (2) Thanks
Old 15th June 2018, 11:42   #1172
Thanked: 1,804 Times
So I have done some research of my own. The Forester seems to have a naturally low noise intrusion compared to other cars of this vintage. I would say it even offers good noise insulation compared to a lot of today's cars. Still, I would like to damp the roof and doors.
You can also look at Dampmat.
http://www.dampmat.com/
keroo1099 is online now
Old 19th June 2018, 00:37   #1173
AutoNoob's Avatar
Thanked: 4,168 Times
Originally Posted by straight6 View Post
I eventually bought 44 sq ft of Dampmat Exceed. Installation will be done soon.
How is your experience with Dampmat exceed? I am looking to damp doors and spare tire floor area in my car.
Also, though it's about 2years since you did installation, can you please share the cost of Dampmat Exceed that you paid. This will be a good reference point for me.
AutoNoob is offline
Old 19th June 2018, 00:40   #1174
straight6's Avatar
Thanked: 309 Times
Its very good so far. I paid 10k.
straight6 is offline   (1) Thanks
Old 18th July 2018, 16:11   #1175
Thanked: 386 Times
hello gurus,
can any of the products here be used on domestic windows ? My house is located in a busy locality with plenty of buses and trucks plying and there is terrible noise coming in via a window. looking for solutions and hence the question.
vaasscit is offline
Old 18th July 2018, 16:14   #1176
condor's Avatar
Thanked: 16,887 Times
These damping materials are opaque, and to be used on metal sheets. Not on glass. These will not be suitable for your requirement.
If you are facing noise due to vehicles, then suggest to check on sound-proofing ( non-automotive). You could try heavier glass in the windows, and thick curtains.
condor is online now   (1) Thanks
Old 18th July 2018, 20:05   #1177
Thad E Ginathom's Avatar
Thanked: 29,976 Times
Good double glazing, as I have seen in houses on busy roads in UK, cuts out a lot of noise. Also a good insulator
Thad E Ginathom is offline   (1) Thanks
Old 11th August 2018, 22:41   #1178
jobinjv's Avatar
Hi
Wanted to know how audio being heard outside of the car can be controlled.
At a very low volume of about 12 or so the sound is very audible outside on the Honda Amaze. It’s got two layers of STP damping.
I have experience on previous cars like Volkswagen and Tata that at least till the volume peaks past 18 or so does people outside make out what is played.
What can actually be done to contain the sound within the car at such low volume levels. I do understand the car is very flimsy, but feels even an old Hyundai Santro was better at this part.
jobinjv is offline
Old 22nd November 2018, 12:30   #1179
Thanked: 248 Times
Is damping useful on older cars? I have a 12yr old Esteem which has rattles and squeaks galore. Would damping make a significant difference?
zhopudey is offline
Old 22nd November 2018, 12:36   #1180
condor's Avatar
Rattling and squeaks in an old car are about parts getting loose over the years. Damping most likely will Not help you here.
Old 12th December 2018, 18:27   #1181
If done correctly, yes it is extremely helpful.
I'm not to sure about the range of products available to you, but there are products for treating all sorts of noise.
Neeresh is offline
Old 19th December 2018, 16:03   #1182
Thanked: 115 Times
I have a 9 year old Safari 2.2, done 1 lakh kms, well maintained, single-hand driven by me only, all parts changed as per manual. Though engine is in superb condition, still sound of engine, as well as other (wind, tyres), inside cabin has increased a lot, obviously.
What solution I can apply to reduce sound from entering cabin?
I am based in Lucknow, so no such outlets with professional people are available here like in metros (Delhi, Mumbai, Bangalore, Pune, etc.).
Thanks in advance
LongDrive lover is offline
Old 28th December 2018, 08:26   #1183
Thanked: 99 Times
I have a 9 month old S-cross and interested to do damping of doors. 3M provides an acoustic solution as well as we have dampmat and others.
Which solution is better for NVH reduction?
Anyone knows a professional installer for damping in Pune?
Thanks in advance.
findviru is offline
Old 28th December 2018, 10:38   #1184
arvindmanju's Avatar
Thanked: 578 Times
Thanks in advance
What make and How old is the Safari tyres? I have changed my Safari tyres to Michelin LTX Force and the road noise compared to Bridgestone is very less.
Wind noise might be due to ageing of all the four door rubber beedings. Just get the doors realigned and if required get beedings changed.
arvindmanju is online now
Old 28th December 2018, 13:54   #1185
Thanked: 2,736 Times
I would prefer Dampmat/Dynamat depending on your budget. I have Dampmat in Innova for last 6 years.
You can try this at any of audio installers in Pune namely Poona motors in Camp, Bhandari Auto on JM road, Bafna cars on Ghole road, Car Cupid on Sus road.
sukiwa is offline   (2) Thanks
