Old 28th February 2012, 13:11   #7981
phamilyman's Avatar
Thanked: 4,675 Times
Originally Posted by Athani View Post
I think you guys haven't set up the app correctly. If you set it up to deny USB access as well as USB debugging, I don't see how anybody can flash a ROM. Even using fastboot. ODIN may be another thing...
What is ODIN?
Odin is the software which flashes Samsung firmwares in bootloader mode (or whatever download mode they call it).
I do the exact same via RSD lite for motorola.
You have to grant that others here who have spent money and are ruing it, may be doing so because they have gone the whole hog. I am of course open to making the app work - but your suggestions don't
phamilyman is offline
Old 28th February 2012, 14:28   #7982
Athani's Avatar
Thanked: 19 Times
Originally Posted by phamilyman
What is ODIN?
Nope. ODIN is not bootloader dependant. ODIN is used to revive bricks. I don't think anti-theft can block that. But then, nothing can :-)
And btw, anti-theft is free.
Athani is offline
Old 28th February 2012, 14:33   #7983
_raVan_'s Avatar
Thanked: 660 Times
More rumors for SGSIII:
Sources close to BGR have leaked some valuable information regarding the hardware specs that everyone has been waiting to hear. Without further adue, the Samsung Galaxy S III is expected to feature Samsung's 32nm 1.50GHz quad-core Exynos 4412 SoC, which packs four Cortex-A9 processing cores (improving CPU performance by up to 26% from current 45nm Exynos SoCs) and four ARM Mali GPU cores (improving GPU performance by up to 50% from the 45nm Exynos SoCs).
The device also features a 4.8-inch “Full HD” display with 1920x1080 resolution and a 16:9 aspect ratio, an 8-megapixel rear camera, a 2-megapixel front camera, a 4G LTE radio and will run the Google Android 4.0 Ice Cream Sandwich operating system.
Of course, we have yet to hear any details about RAM, storage capacity, size and weight, but the specs that have been released thus far paint a picture of what to expect from Samsung's "top flagship" smartphone for the year 2012.
Source: Samsung Galaxy S III hardware specs leaked
_raVan_ is offline
Old 28th February 2012, 14:37   #7984
clevermax's Avatar
Thanked: 2,903 Times
Thought of sharing some basic adb usage to manage apps, configuration, copy files etc from a PC.
If you have Android SDK installed in your PC, you can get the terminal of your Android phone in your PC using abd. You need a USB cable to connect, need to enable USB debugging in the settings of the phone.
From your PC's command prompt, you can type in
C:\>adb devices
To see if the phone is getting listed first. If there's no devices listed, then the phone is not detedted through adb.
C:\>adb shell
Use this to get the terminal of the phone in your PC. Then basic linux commands can be used to install/manage apps, change configuration settings etc. if you know what you're doing
C:\>adb push
can be used to install an apks directly into the phone's system/app folder. This can be used to copy any file anywhere in the phone as well.
Example:
C:\>adb remount
C:\>adb push Mycalc.apk /system/app
will remount the /system as read write and then the specified apk will get copied form PC to phone. You wil be able to notice the app icon appearing in the app drawer after this. You need to be rooted and HTC guys will need to be S-OFF'ed as well.
All these are achieved by connecting the phone to the PC using a USB cable. Now going one step further, you can actually do all these wirelessly, if your phone and PC are in the same Wi-Fi netwrok. Here's how.
First open up terminal emulator in the phone, and do the following, starting from the 'su' command. (You need to be rooted)
Android Thread: Phones / Apps / Mods-20120228_140824.jpg
These commands can be saved in a shell script and that can be called as well, for ease of use.
Now in your PC, type in
C:\>adb connect <Phone's IP address>
Example:
C:\>adb connect 192.168.1.6
C:\>adb shell
Now you will get access to phone's terminal via Wi-Fi.
clevermax is offline   (6) Thanks
Old 28th February 2012, 14:49   #7985
_raVan_'s Avatar
Thanked: 660 Times
Do we have a command to send sms or make calls directly from the command prompt if the S2 is connected to the system?
_raVan_ is offline
Old 28th February 2012, 14:52   #7986
Warwithwheels's Avatar
Thanked: 1,762 Times
Why not use apps like airdroid which are intended for that purpose?
Warwithwheels is offline   (1) Thanks
Old 28th February 2012, 14:54   #7987
clevermax's Avatar
I don't think we can send an sms or make a call from a terminal as it is.
But, you can very well send sms &make calls easily from your PC using apps like MyphoneExplorer. You can even use your PC's keyboard for inputting text directly onto any input field that comes up in your Phone - you can watch text appearing in the phone's screen as you type in PC.
clevermax is offline   (1) Thanks
Old 28th February 2012, 16:58   #7988
S_U_N's Avatar
Thanked: 418 Times
I have noticed that on my Motorola Defy with CM 7.1, the temperature of the phone shoots up to around 40 degrees (as reported by the internal applet/ widget) while I am traveling and keep the phone in the car (with AC on).
Also the temperature is 35+ even while at home when I do some heavy browsing and Google maps/ Sygic maps with GPS on.
The phone becomes slow when it is at these temperatures. It takes 15-20 minutes to cool down and the speed/ response is back to normal.
Anyone having related observations?
S_U_N is offline
Old 28th February 2012, 18:02   #7989
clevermax's Avatar
When your phone heats up (I don't know for sure why) there could be some CPU scaling settings taking place, whereby it caps the max speed of the CPU to a lower value, in order not to heat it up further. That's probably the reason why you see reduced performance when it is too hot and increased performance when it cools down.
I have this setting enabled in SetCPU - the max CPU speed will be reduced from 1.1Ghz to 691Mhz when the temperature of the phone goes above 45 degrees, which so far only happened a couple of times when the phone was mounted on a holder in the car's windshield in direct sunlight with Navigation on.
Old 28th February 2012, 18:04   #7990
R2D2's Avatar
Thanked: 5,858 Times
I had tried the much touted ICS update on my rooted Razr - and reinstalled the original ROM within a day. Issues were:
a) Phone heating up - the back was continuously very warm to the touch. I noticed battery life was severely affected
b) Buggy as hell! Setting a launcher as default didnt seem to work at all. The start up screen froze after every reboot.
c) Garbled screen - the kind you see on your TV when your satellite tv signal goes wonky.
Luckily Moto has the ICS update scheduled for a roll out from April onwards. I'll wait for it. No more screwing around with ROMs for now.
Unlocked bootloader - no luck yet. Though some guys at XDA Dev are trying to crack it.
R2D2 is offline
Old 28th February 2012, 18:38   #7991
anilisanil's Avatar
Thanked: 291 Times
But did you analyse why is it heating up?
The following questions come to my mind.
Have you over clocked your phone? Did you pad it up too much making it impossible for it to reject heat? Has it been happening recently (after installing a few apps)?
And I am not too sure why you want the GPS on while browsing at home, if you think it is unnecessary, it would be a good idea to disable GPS.
Regarding slowing down. The CM mod has CPU governor which would decrease the CPU speed when temperature crosses certain threshold and the defaults would be restored only when the temperature is back with in limits, you could change the same using apps like CPU master etc.
anilisanil is offline
Old 28th February 2012, 19:11   #7992
zenx's Avatar
Thanked: 162 Times
Temperature issues : check/play around with CPU settings and don't overclock too much. Also look around on the net - there may be other kernels that run cooler.
zenx is offline
Old 29th February 2012, 10:13   #7993
clevermax's Avatar
It may not be only the CPU settings that could be the culprit. If the phone uses excessive amount of data over EDGE/3G, it will definitely heat up. You need to check in that direction too. Installing an app which will monitor the data usage will be of help in determining the issue.
In MIUI, there is an inbuilt data monitor and firewall where one can monitor the the usage as well as block apps that uses data for no real purpose.
Old 29th February 2012, 13:23   #7994
headers's Avatar
Thanked: 564 Times
AFAIK - the voltage levels help control the phone overheating..or heating.
CM7.1 runs hotter than WIUI 1.12.16 hotter than CM 7.1 whiterabbit hotter than MIUI Pikachu for the Defy!
The best w.r.t battery temp is Pikachu and Best w.r.t battery life overnight is Whiterabbit [just 3% over 9 hrs]
Will test it again before reporting!!
headers is offline
Old 29th February 2012, 13:32   #7995
offroad_maniac's Avatar
Thanked: 156 Times
Yeah, even I was experiencing temp up to 44c when using default CPU settings on cm & miui. Later I changed the CPU voltage as below on my defy & now temp stays below 40 even under heavy net usage.
300/20:600/30:1000/40 (freq/vsel).
offroad_maniac is offline   (1) Thanks
