Old 11th July 2017, 22:15   #10531
arjithin's Avatar
Thanked: 2,551 Times
Originally Posted by straight6 View Post
You will have to check for the dealer in your city. I know where to get it here. Unless, you're coming to Bombay soon.
I couldn't find a website or directory listing for them. Do you mind sharing the Mumbai contact details?
arjithin is offline
Old 11th July 2017, 22:30   #10532
kpzen's Avatar
Thanked: 1,882 Times
Anyone tried excelite bulbs from korea.?.
I'm using it on my scross.
http://www.team-bhp.com/forum/offici...ml#post4230524
Do you have the 130w version of it .?
kpzen is offline
Old 11th July 2017, 23:29   #10533
straight6's Avatar
Thanked: 310 Times
Yes its available here.
straight6 is offline   (1) Thanks
Old 12th July 2017, 11:21   #10534
Red Liner's Avatar
Thanked: 19,186 Times
Does this brand have h7 55w? Wondering if it makes sense to go for this over a philips or osram.
Red Liner is offline
Old 12th July 2017, 16:10   #10535
Thanked: 39 Times
Would suggest importing an Osram Nightbreaker Unlimited from powerbulbs.co.uk . They usually have a 20% off offer running and they are 100% original. You will find a lot of fakes in India.
I personally am using them on my Duster and I can see a significant improvement in visibility compared to stock lights. Just ensure they are focused properly.
ArvindMaveric is offline
Old 12th July 2017, 21:14   #10536
samkat1's Avatar
Thanked: 92 Times
I second this. It's worth getting stuff from powerbulbs. Just ensure you manage to get hold of someone who can safely replace the bulbs for you incase you are not confident in swapping the bulbs.
samkat1 is offline
Old 12th July 2017, 23:25   #10537
Thanked: 36 Times
Replaced incandescent W5W stock bulbs in high mount stop light of our Wagon R Vxi to Philips T10 LED. I tried Osram T10 LEDs first, but the reflector is designed in such a way that light from bulbs must have a good spread in order to light up the entire reflector cavity and not a strong forward focus as is with Osram LEDs; thus I switched to Philips T10 LEDs with 360 degree coverage. Earlier consumption was 20 watts, which has got down to mere 4 watts for this stop light.
Auto Lighting thread : Post all queries about automobile lighting here-philipsxtremevision360led6000kt10_750_750.jpg
Auto Lighting thread : Post all queries about automobile lighting here-img_1795.jpg
sumitmajumdarin is offline   (2) Thanks
Old 12th July 2017, 23:31   #10538
JMaruru's Avatar
Thanked: 430 Times
Re: 75W/75W H4 for Alto?
This 75W/75W H4 would have been a worthy upgrade for alto, what with it's battery. I would NOT know where can I source the same in B'lore.
Are there any other headlight upgrades possible for our humble alto?
JMaruru is offline
Old 12th July 2017, 23:36   #10539
Thanked: 571 Times
I had 100/90 bulb in my Alto for couple of years with no noticeable damage to the headlight case.
As for higher watt H4 bulb, just got myself one from Ali Express.
https://www.aliexpress.com/item/Long...650232837.html
Will be able to test it only once I am back in India next month.
HappyWheels is offline
Old 13th July 2017, 13:12   #10540
straight6's Avatar
Thanked: 310 Times
We had 2 altos earlier and the one I was driving had 130/100 Philips rally bulbs. Other one has Bosch 100/90. No problems.
Please stop using such rubbish products. They're more expensive than the Philips rally 130/100 plus they will give less light on the road because the glass is tinted yellow. Any tint on the glass always results in less lumens on the road.
Old 13th July 2017, 15:00   #10541
Thanked: 571 Times
...Please stop using such rubbish products. They're more expensive than the Philips rally 130/100 plus they will give less light on the road because the glass is tinted yellow. Any tint on the glass always results in less lumens on the road.
Have you used this or is it just your assumption?
Old 13th July 2017, 20:38   #10542
straight6's Avatar
Thanked: 310 Times
Yes, I've use something similar and it was bad. Its the basics of lighting when the glass is tinted with any colour it restricts the actual lumens produced. Always go with clear glass. In the case of HID's its the gas and the temperature that results in the colour and not the colour of the glass on the bulb.
I guess if you have to go with something like this it definitely has to be 130/100 to make up for the loss of lumens.
straight6 is offline   (2) Thanks
Old 14th July 2017, 16:30   #10543
Thanked: 571 Times
...I guess if you have to go with something like this it definitely has to be 130/100 to make up for the loss of lumens.
Already have 130/100.
This was just a spur of the moment purchase. Looks like that is money gone.
Had done something similar a long time back - bought a xenon gas filled bulb which was all good during normal times, but come fog or rain - just a white wall in front; absolutely no visibility and absolute mess!!!
Old 14th July 2017, 16:38   #10544
straight6's Avatar
Thanked: 310 Times
That's exactly what I was saying. Xenon is only filled in hid bulbs and not filament ones. Those always have halogen gas.
Ideally fog lights should always be yellow for best vision in those conditions as the whiter the light the more its absorbed and negated by fog and rain. So the yellow bulbs need to be 130/100 I say.
In fact I've used the Hella 130/90 and found those to be inferior to the Philips Rally 130/100 because their light was whiter even though the glass was clear.
Old 15th July 2017, 11:41   #10545
Thanked: 18 Times
Looking to upgrade my Ciaz Headlamps. Procured H7 100W Osram Bulbs and went to a local electrician. The relay kit he was trying to put was not compatible with the socket available in the car. He said he will have to make cuts, and use the relay he has.
Pls advise, are there any tailormade relay kits available for Ciaz headlamps, so that i can carry out a upgrade without cutting the existing wires?
sandeep959 is offline
