Old 16th July 2020, 21:29   #7981
AtheK's Avatar
Thanked: 10,237 Times
Re: The Home Appliance thread
Our Kent Water purifier to give up, after 6 years and numerious repairs. So i have decided to not get it repaired anymore and get a new one, have zeroed the one below.
Eurek Forbes Aquasure
Anyone using the same, and any inputs, reviews generally seems favorable. TIA.
AtheK is offline
Old 17th July 2020, 06:25   #7982
Ithaca's Avatar
Thanked: 896 Times
As a loyal Eureka Forbes customer, only suggestion from my side would be to contact your local Eureka Forbes dealer and ask them about the unit you are interested in or if they have better product. And they will give you a better bargain for sure.
And when you go for an extended warranty, do not forget to go for the ones including rubber parts - amount seems insignificant now but is worth taking considering you have to pay for rubber parts otherwise.
Ithaca is offline   (1) Thanks
Old 17th July 2020, 06:32   #7983
Thilak29's Avatar
Thanked: 3,663 Times
I am looking for a room heater to keep our work area dry so that laundry drying happens during 4 months of incessant rains we experience in this part of the world.
Thilak29 is offline
Old 17th July 2020, 07:28   #7984
Amrik Singh's Avatar
Thanked: 3,655 Times
Would that solve the problem ? In my opinion, it is the moisture in the air caused from Wet Clothes in the vicinity which would still remain, rather increase with rise in room temperature.
You should create a cubicle open from above and below (even a thick cloth would suffice) to contain the wet laundry. Place a fan high above it directing air out of some open window and a heater placed on floor. When both operating, hot air will be sucked up through wet laundry and vapour laden air ejected out of Window. Quite a set up.
Positioning it in kitchen or Bathroom and using its exhaust would serve the purpose.
Amrik Singh is offline   (2) Thanks
Old 17th July 2020, 08:23   #7985
ghodlur's Avatar
Thanked: 4,738 Times
I am using the model, infact got it second hand when I moved to Bangalore from one of my office colleague who had barely used it for a couple of weeks. Was using the RO filter for the first time infact. The model is quite compact and has a 6 litre inbuilt storage. I had to replace the all the filters before I started using the unit. The biggest worry is the correct adjustment of the TDS. When I had installed the TDS knob was completely closed, didnt realize this and was drinking like water which was more like distilled water. Got the TDS adjustment done twice. The taste of the water is a bit weird but thats ok.
ghodlur is offline   (1) Thanks
Old 17th July 2020, 09:43   #7986
sagarpadaki's Avatar
Thanked: 6,799 Times
You are better off placing drying the cloths in room that has good ventilation. In a similar situation, i found fan + open window to dry the cloths without the damp smell
sagarpadaki is offline   (3) Thanks
Old 17th July 2020, 10:34   #7987
Thanked: 3,008 Times
If your clothes can fit a framed drying rack the do the following
1. Arrange all your clothes on the rack so that there is air flow in vertical direction.
2. Put a blower type room heater at the bottom of the rach. The air flow should be upwards.
You now have a powered clothes dryer.
Aroy is offline   (3) Thanks
Old 17th July 2020, 11:00   #7988
Thanked: 387 Times
I would be wary of using a space heater to dry clothes. All heaters and infact air conditioners as well recommend against using the same to dry clothes. Operating such equipment specially heaters in high humidity scenario can create safety hazards of all kinds.
+1, ventilation is the key here
I would rather suggest buying a dedicated cloth dryer from the likes of Bosch etc. or front loading W/Ms with built in dryer functionality (This is less efficient). Considering this is an annual phenomenon based on your geography, in my opinion the investment would be justified.
roamer012 is offline   (1) Thanks
Old 17th July 2020, 18:14   #7989
Hudson's Avatar
I got a great price on this one in Bangalore. Almost 10K off. And it's imported from Korea. Feather touch controls, 4 swing arm with three water sprays etc. Waiting for installers to come since LG has switched off all lines. This model can be controlled even from your workplace using your phone
Congratulations on your purchase. You got a great price. I was checking reviews about this model online and at some places it is mentioned that if there is a power cut then it doesnot resume.
Review-1:
(https://www.amazon.in/review/R10R9XV...SIN=B07Q2PFV8D)
Review-2:
(https://www.amazon.in/review/R2JG2UK...SIN=B07Q2PFV8D)
It would be great if you could let us know your experience on this since you have first hand experience.
Hudson is offline
Old 17th July 2020, 18:29   #7990
Thad E Ginathom's Avatar
Thanked: 29,987 Times
Have an AC? ACs are really good at drying the atmosphere. Some have a special setting for drying clothes.
Usually, though, we just dry clothes outside, either on a line which is sheltered from rain or on a drying rack. The drying rack we can put under a fan, which we have outside the front door.
Basically: just accept that it is going to take a couple of days to dry instead of a few hours. Imagine drying clothes in British weather!
Thad E Ginathom is offline
Old 17th July 2020, 20:21   #7991
Thanked: 12,179 Times
Infractions: 0/2 (11)
Yes it resumes from where it left off. I'm thinking probably the earlier models had this issue. This dishwasher has been around for some time now
Sebring is offline   (1) Thanks
Old 17th July 2020, 23:37   #7992
Thanked: 1,695 Times
Mine imported in the month of march, also doesn't remember the cycle time left after power cut, it again starts from first. Can you check by switching off the socket switch, to simulate a power cut.
DIY410 is offline   (1) Thanks
Old 18th July 2020, 05:56   #7993
Sure. This might take few weeks though since we are outside Bangalore for some time.
Sebring is offline
Old 19th July 2020, 11:22   #7994
click's Avatar
Thanked: 620 Times
Originally Posted by sukhoi View Post
So our mixie gave up (repairs will take time) and hence am looking for a hand blender. Main requirements are:
- Should be able to work as an immersion blender to make soups, pastes etc. in the vessel in which food is being cooked
- Should be able to make a paste of onions & tomatoes (typically used as a base for the masala while making rajma, chole etc.)
- Blend smoothies using fruits & ice cream
Late reply as I saw you have already purchased one, but putting it out there for others who might also be looking. We just replaced a 15 year old Braun hand blender with another Braun MQ100 (curry). The new one is 450W. The main use in our kitchen is for making chatni and various pastes. I can safely vouch for the quality and decent power.
click is offline   (1) Thanks
Old 19th July 2020, 12:02   #7995
My 1983 purchase and import. Still going strong. Virgin from any Mechanics.
