Old 30th June 2009, 14:10   #3001
hellstar's Avatar
Thanked: 44 Times
yes you can , get a relay which is rated for operational currents of more than (250/12) ~ 21 amps and you should be safe.
hellstar is offline
Old 30th June 2009, 14:52   #3002
tsk1979's Avatar
Thanked: 23,484 Times
Originally Posted by KSM-Vtec View Post
Ok i have a question here - Can i run these lights AIRCRAFT LANDING LIGHTS / HALOGEN LANDING LIGHTS on a gypsy??
What will be the impact or using a 250watts light?
It will overload the alternator.
Two 100W bulbs in the main headlamps means 200W.
One lamp will draw more current than 2 headlights,.
If you want brightness without upgrading your alternator, I suggest you look at Xenon.
Buy two cheapo fog lamps, and fit H3 Xenon in them, cost = 4500rs approx for everything.
tsk1979 is offline
Old 30th June 2009, 15:39   #3003
bblost's Avatar
Thanked: 17,974 Times
A simple look at it is this.
Watts / Volts = Amp
Your Car battery is 12 Volts.
Your lights need 250 Watts.
So you need about Amp = 250 / 12 = 21 (approx)
But your car battery has less than a fourth of that.
When the battery is being charged by running the car engine, the drain is still enough to dry it out.
Any such mod will require a couple more batteries and some very thick wiring.
bblost is offline
Old 30th June 2009, 16:00   #3004
tsk1979's Avatar
What do you mean that battery has less than a fourth of that?
Battery is rated at Ah.
For example a 65aH battery means that if you draw 65 Amperes the batter will die in one hour.
If you are running 21Ampere light, your battery will run out in 3 hours from full to flat.
Now if your alternator is supplying more current than consumed by system, your battery will keep charging, however if drain current exceeds charge current battery will die.
So if you intend to use the light for couple of minutes in emergency, its okay, but if you want them as running lights, a strict no no.
tsk1979 is offline
Old 30th June 2009, 16:11   #3005
bblost's Avatar
oops. confused with my bikes battery.
The primary task of a battery is to store electric current chemically. Make it available when its needs and be able to deliver large amounts in a short period of time. The last being the difference between a battery being used in a car and an inverter.
A load of 250 Watts will be difficult to sustain by the stock battery.
So the battery needs to be upgraded and also the wires.
bblost is offline
Old 30th June 2009, 16:41   #3006
tsk1979's Avatar
250W? 250W is nothing in a car.
Lets see in a stock setup
Headlights = 200W
Tail lamps = 40W
Front Fogs = 100W
Music system = 50W onwards
AC blower = 100W+
Fan = 250W
At any given time its around 50A of current at peak load with AC and headlights working
250W will add 20A to that load.
So if the user is not running the headlights, 250W is okay, but with headlights on, this will be an issue, and battery will slowly start to drain.
Normally cars have 45Ah batter, SUVs have 75-80Ah battery, and diesels have 55Ah battery(indica etc.,)
So using a 250W spotlamp for 10-15 minutes is not an issue, but using it as the main headlight, i,.e using 2 of them is not really recommended.
tsk1979 is offline
Old 30th June 2009, 17:01   #3007
gpa
gpa's Avatar
Thanked: 345 Times
Originally Posted by nareshtrao View Post
Can any of the users give me a comparison between
1. OSRAM Night Breakers,
2. Philips Extreme Vision and
3. Philips Crystal Vision ?
I see different recommendations here and have not been able to make up which is suitable under what circumstances?
nareshtrao,
I have used all 3 bulbs and here are my opinions on each of them. Steer clear of the Crystal Visions, they are useless at lighting up the road especially in the rain and are mere "show off" light as they emit a white light.
Osram Night Breakers are good performance. But they tend to fail after a few months of extensive usage. Philips Xtreme Power bulbs are good. They actually provide much better lighting than the stock bulbs. Also, the beam throw is much wider on the low beam and the high beam has a good throw. The light emitted is brighter and whiter than when compared to the stock halogens.
Hope this helps.
Cheers,
gpa
gpa is offline
Old 30th June 2009, 17:06   #3008
KSM-Vtec's Avatar
Thanked: 447 Times
So in that case using 2 spot lamps having a total of 500W is not recommended for a long duration.
But if i use it for say 5 min will it still load the alternator/battery causing any kind of permanent damage?? and when will be the next best time to switch the light back on again??
Headlights = 200W
Tail lamps = 40W
Front Fogs = 100W
AC blower = 100W+
Fan = 250W
KSM-Vtec is offline
Old 30th June 2009, 17:11   #3009
Thanked: 625 Times
Originally Posted by ALSUDA View Post
Any expert opinion on Phillips Xtreme compared to 100/90?
I am not expert. However, I have Phillips Xtreme on myswift from last 4-5 months and I had 100/90 on my Indica. Here are my observations.
1. Phillips Xtreme : Really good, till now no issues. Excellent visibility. No changes in wiring, plug and drive.
2. 100/90 : Firstly this is wattage. In the beginning, it was better than Phillips Xtreme, however, within 2-3 months, the refectors started to darken. Additionally, needs rchange in wiring and it is not street legal.
So my vote to Phillips Xtreme .
regards,
-manju
manjubp is offline
Old 30th June 2009, 17:12   #3010
Thanked: 54 Times
Originally Posted by nishantgandhi
@SRS - Any specific reason why you want to go for the Xtreme power series? Would be good to know how its different from the normal 'Rally' halogen bulbs?
If you are not in a hurry, I can get you in 2 weeks time. My mechanic is out of town. He sources everything for me from Opera but at good prices.
Hi Nishant
I too am keen on getting my headlamps changed for the monsoons. I have a Indica Xeta GLS.
Do let me know as well once your mechanic is back in town
saildrive is offline
Old 30th June 2009, 17:34   #3011
Thanked: 25 Times
Dear Manju, how's the performance in rain? Osram NB during nights are pathetic & also the throw of high beam is not that good for highway drive. I remember reading a review in this thread, saying xtreme's highbeam throw is far better than NB.
I feel it's better to stick to 55/60 instead 100/90 which shortens life(shine) of reflectors. I would like to try Xtremes, I 've to go to AK Traders & pick them up.
Thanks for the response Manju.
Suda
ALSUDA is offline
Old 30th June 2009, 22:16   #3012
tsk1979's Avatar
If you want to use it for short burts, get a more powerful 65Ah battery instead of the 45Ah you have now.
Also. whats your alternator capacity? Its usually written on the alternator.
Make sure that the circuit controlling these lights is totally separate with its own wiring and heavy duty 50A switch . These are going to be seriously thick wires.
tsk1979 is offline
Old 30th June 2009, 23:43   #3013
ultimatechamp's Avatar
Thanked: 165 Times
Headlights = 200W
Tail lamps = 40W
Front Fogs = 100W
AC blower = 100W+
Fan = 250W
I had a similar question which I asked in the Power Horn thread,that whether fitting more than one horn and too many lights (obviously all with relay,except fogs) puts to much pressure on the ECU/ECM in the long run?
Immortalz says no,if relays are in place.
To be more specific,I have the following set up in my car:
Headlights: 2 130/100W bulbs with twin relays
Foglights: 2 55W bulbs without relay.
Underbody Neons all round
Under-dash and under-seat neons
PLUS the usual as well when driving at night in rain,such as:
Wipers on
AC on
ICE on
Now my ICE set-up is quite powerful too,such as:
Alpine HU 9886
4 Illusion Speakers (2 compos & 2 coaxials)
Big Sub from GZ
the compos and sub run from a JBL GTO 1004 Amp
Entire wiring ( lights+ICE) in the car is branded and of very good quality.
Although this is an exclusive auto-lighting thread,I still want to ask tsk and others whether fitting extra electricals put a load on the ECU in the end? Does it put a load on the battery and alternator as well? Please all kind souls,do elaborate and explain so that this never remains a grey area for all petrolheads like us in the future.
ultimatechamp is offline
Old 1st July 2009, 10:18   #3014
tsk1979's Avatar
If you are continuously using stuff such that the alternator current is less than the drain current, your battery will eventually go dead.
So it depends on how much current are your neons drawing.
since you have just one AMP driving the sub, it should not be a problem unless you see your headlights flickering rythemically to the Bass.
tsk1979 is offline   (1) Thanks
Old 1st July 2009, 11:04   #3015
karizma_devil's Avatar
Thanked: 21 Times
Originally Posted by karizma_devil View Post
i Want to have Philips Crystal Vision for my Palio s10 ( head unit + Fog lamps).
PLease suggest availibility im Mumbai ( Preferably in and around Colaba or Thane)
Cheers !
PLease help !!
karizma_devil is offline
