Old 18th November 2016, 15:13   #10171
Thanked: 954 Times
Originally Posted by ARAY View Post
Ordered them off Amazon. I am not a big fan to the fan types
They suck in dust and when the cooling system of those LEDs die ,the LEDs do flicker and eventually die...
Attachment 1576188
looks neat. how's the light throw/reach wrt stock halogen? which bulb type did you replace ? which brand and how much did it cost?
i know too many queries but appreciate your reply !
somspaple is offline
Old 18th November 2016, 21:15   #10172
SunnyBoi's Avatar
Thanked: 4,461 Times
Originally Posted by SunnyBoi View Post
CNLight 45W 4300K D2S bulbs
Hyluxtek 50W ballast
3 inch projectors
A video of the output thanks to my dashcam. Please note I have a VLT70 sunfilm on the front glass and I have a polarising filter on the dashcam. The light in person is much brighter
Since I have 4300K bulbs, the light colour is the same as halogens, although its not very obvious in the pictures and video.
I still have a long way in correctly aligning the projectors, both are off a lot in both axes.
SunnyBoi is offline   (1) Thanks
Old 19th November 2016, 21:03   #10173
condor's Avatar
Thanked: 16,891 Times
Probably most of us Duster owners know the downside of buying a duster with the headlight assembly.
@Aray, Are you using the LED's in the high-beam ?
I dont see any projectors there .. So the light would not be focussed, but quite dispersed ?
Moreover Duster has dust caps .. .
Did you make a hole in the dust caps to take out the heat-sinks ?
condor is offline
Old 21st November 2016, 12:05   #10174
Thanked: 572 Times
Anyone know what bulbs are to be used in the High beam of the Innova Crysta with the LED projectors?
venom_op is offline
Old 21st November 2016, 13:15   #10175
Thanked: 9,253 Times
HB3/9005 bulbs.
High beam bulb is same for projector light crysta and non projector light crysta.
Sankar is offline   (1) Thanks
Old 21st November 2016, 14:09   #10176
Guite's Avatar
Thanked: 646 Times
Does anyone know what is the bulb type in Vento double barrel headlight? The user manual is common for a lot of their cars so I am unable to pinpoint bulb type for 2016 Vento.
Guite is offline
Old 21st November 2016, 14:19   #10177
Both high and low beams are H7 bulbs. My GT TDI came with these same double barrel lights.
Old 22nd November 2016, 11:23   #10178
Thanked: 572 Times
HB3/9005 bulbs.
Are you sure? I'm about to import an HID kit. Aren't HB3/9005 bulbs mostly used in the fog lights?
venom_op is offline
Old 22nd November 2016, 13:54   #10179
Thanked: 366 Times
I hope you are considering HID projectors too.
HID bulbs in halogen housings, especially for high beam, would put out very less usable light, with most of the light scattering around and causing glare to other road users, thereby posing a safety issue for them as well as you.
halfbytecode is offline   (1) Thanks
Old 22nd November 2016, 14:21   #10180
Thanked: 572 Times
MOrimoto Mini H1 7.0. Definitely projectors.
venom_op is offline
Old 22nd November 2016, 20:57   #10181
Thanked: 366 Times
That's good. It would be interesting to know how you plan to use the Bi-xenon projectors with the existing low-beam LED projectors.
Old 22nd November 2016, 21:43   #10182
condor's Avatar
Just in case not posted earlier:
What I Didn’t Like About The LED Headlights (in standard reflectors designed for Halogen)
  • Borderline dangerously bright for oncoming traffic. Blinding other cars is no better than not being able to see yourself.
  • Just how hot the heat-sinks got was a little disconcerting. Even with all the safety guarantees from the purveyor, I’d want to be extremely wary of how they were positioned.
  • Throw-distance felt shorter than halogens; a big disadvantage for high-speed driving. But what’s more, the LEDs had a very tight flood pattern. I like the way traditional lights bleed into the woods a bit; the LEDs didn’t do that as much.
Source: Jalopnik
Old 23rd November 2016, 10:00   #10183
SunnyBoi's Avatar
Source: Jalopnik
The technology used in LEDs are changing at a rapid pace. If you do your research, you will be able to find a set of LEDs you can use in reflectors without having negatives like I did.
The LED bulbs I had went to a friend who used them on his Duke 390. Here are the high and low beam pictures taken side by side with another duke with stock bulbs. The LEDs are much brighter although its not clearly visible in the pictures. :
Auto Lighting thread : Post all queries about automobile lighting here-whatsapp-image-20161121-1.40.57-pm.jpeg
Auto Lighting thread : Post all queries about automobile lighting here-whatsapp-image-20161121-1.40.59-pm-1.jpeg
Here is his feedback on the LED bulbs :
Auto Lighting thread : Post all queries about automobile lighting here-ninja.jpg
PS : The duke friend is a far more responsible headlamp user than I will ever be and had more reservations about using LEDs in reflectors then me. The fact he is happy made me think that the right LEDs will do the job better than halogens.
SunnyBoi is offline
Old 23rd November 2016, 14:33   #10184
Thanked: 572 Times
Attachment 1577825
Attachment 1577826
Attachment 1577827
What LEDs is he running?
venom_op is offline
Old 23rd November 2016, 16:31   #10185
Thanked: 12 Times
Originally Posted by Aston Singh View Post
Guys, out of these two which one is better or are they equally good/worse?
Philips Xtreme Vision
http://www.amazon.in/Philips-12342XV...headlight+bulb
Osram Nightbreaker Unlimited
http://www.amazon.in/Osram-P64193-Ni...headlight+bulb
Looking to swap the stock H4 bulbs for my GT TSI.
What is the model year for your GT TSI? Doesn't it come with separate bulbs for low and high beams? I do not think the bulb type is H4.
skydiver is offline
