Old 25th December 2015, 08:10   #451
Thanked: 37 Times
Originally Posted by mrbaddy
That's one heck of a trip. How did the second row passengers held up? Did they complain about any discomfort? I'm asking this because the second row seat is too upright for my liking and thought it wouldn't be comfortable for long journeys.
I too had the same question for Sandev. The 2nd row doesn't seem to have good under thigh support. Were the 2nd row passengers comfortable? Were any tall people sitting in the 2nd row?
narenteam is offline
Old 25th December 2015, 08:25   #452
Thanked: 144 Times
Re: SOS - TUV300 Engine Check light on - Stuck on NH8
Thanks guys. Called Mahindra Helpline, they directed me to a service center which is not opened yet.
CEL is off now. What should I do? Is it safe to go ahead? There is no major town till Ahmedabad now.
ntomer is offline
Old 25th December 2015, 08:33   #453
batterylow's Avatar
Thanked: 990 Times
I would suggest you get it checked once the service center opens and proceed, as you have mentioned that there are no major towns till Ahmedabad.
Ask them to run a diagnostic check and look for errors, if any. That will give you an idea what might have caused the CEL to come on.
Have a safe trip.
batterylow is offline   (1) Thanks
Old 25th December 2015, 08:43   #454
Thanked: 216 Times
Even if the CEL is off right now, when the service technician attaches his laptop to the port, he can show show you why the light went on in the first place. Until he clears the error from his laptop, the error codes are stored in the ECU.
As long as there is no visible loss of power, drive carefully to the nearest service center and ascertain the reason. CEL coming on always doesn't mean that some thing is seriously wrong. So don't worry.
chandras1 is offline   (1) Thanks
Old 25th December 2015, 08:47   #455
sandev's Avatar
Thanked: 101 Times
Re: Mahindra TUV300 : Official Review
Originally Posted by vito_parry View Post
This would be the primary commute on long drives.... So the comfort of the 2nd row has to be taken into consideration. Are there any options where we can increase the comfort using seat covers???
To answer all. I never get any complaint from the second row through out my journey. Infact I kept on asking them, knowing the second seat is not that comfortable. But no one complained.
Reason could be as both female passenger height's were in between 5'2" - 5'3". There were too many small luggage placed around there foot area and middle of seat. And almost through out the journey they had woolen clothes on, so may be they had good back support because of the heavy woolen clothes.
Did you get your first service done when you crossed the 3000 km milestone? If not then you should get it done immediately.
Yes I did my first service @ 2100 KM's and had done thorough check up before leaving for this trip. I usually do services much before the manual instructs. My earlier car, Punto suggest to do service every 15,000 KM but I used to do it around every 12 KMs. May be that's the reason it never troubled me till 1,55,000 KMs. There after we parted :(. I still miss my Punto.
sandev is offline   (3) Thanks
Old 25th December 2015, 09:00   #456
Sheel's Avatar
Thanked: 15,137 Times
ntomer - Some issue with boost pressure I assume. Please get it looked into via the OBD tool.
Please update whenever you come across the issue [once pinpointed & its cure]
Something similar had happened with my car as well, have a look
Sheel is offline
Old 25th December 2015, 09:36   #457
Thanked: 144 Times
Getting it checked at Nagaur Automobiles, Ajmer.
Helpdesk directed us to Rathi Mahindra showroom. There we came to know that their service center is somewhere else. We went there and came to know they don't attend to TUVs. They directed us to Nagaur and we are here right now.
One would expect Mahindra Helpdesk to have known this.
ntomer is offline   (2) Thanks
Old 25th December 2015, 09:42   #458
Thanked: 144 Times
This is the diagnosis.
Mahindra TUV300 : Official Review-img20151225wa0013.jpeg
ntomer is offline   (4) Thanks
Old 25th December 2015, 09:44   #459
Thanked: 61,937 Times
As long as the light is steady on, not to worry at all. As long as the car behaves normally just drive on and get it seen to in due course.
It could be something as simple as the filler cap not fitting properly. Actually this one is one of the most frequent sources of a CEL! Just check and retighten. It might take a while before the CEL resets.
If the CEL is blinking there is a more serious issue, which might lead to damage. So in that case is advisable not to drive on.
I must admit I have seen hundreds of CELs. There are millions of drivers who don't worry about their CEL at all, until they take their car for a regular service. In some countries it is a legal requirement no to have the CEL on in order to pass the MOT. So that's when people tend to get it fixed. They will also check if the CEL is in working order. I don't think I've ever come across a blinking one.
Remember your CEL is there for first and foremost environmental reasons. Not necessarily a problem for your engine as such.
Jeroen
Jeroen is offline   (2) Thanks
Old 25th December 2015, 09:47   #460
PatchyBoy's Avatar
Thanked: 2,161 Times
The lights in the console are color coded.
1. Green / Blue / White - Informational
2. Amber - Warning - proceed carefully
3. Red - Fatal error - stop and rectify
CEL is always amber. Meaning proceed carefully. You can drive the car, but don't push it.
PatchyBoy is offline   (2) Thanks
Old 25th December 2015, 09:50   #461
batterylow's Avatar
Thanked: 990 Times
And what is the prognosis now?
Very true, the information is useless if the service center is not equipped to deal with the issue.
Old 25th December 2015, 09:57   #462
Thanked: 144 Times
They have put this part - cut the pipe and inserted it.
Mahindra TUV300 : Official Review-img20151225wa0015.jpeg
ntomer is offline   (1) Thanks
Old 25th December 2015, 11:54   #463
TaurusAl's Avatar
Thanked: 551 Times
What is it ? Did they explain you why have they done this ? Also, please ask what are those warning in detail if possible.
TaurusAl is offline
Old 25th December 2015, 18:40   #464
AutoIndian's Avatar
Thanked: 5,038 Times
ntomer, hope your return journey is safe and sound. Could you please pin-point the part/pipe? Though we can see the picture we cannot just make out.
AutoIndian is offline
Old 25th December 2015, 21:31   #465
Thanked: 144 Times
No return journey, I am on my way to Mumbai. Delayed by three hours due to all these chaos. Surat, my stop for tonight is still 80 kms away. Tomorrow, I will go to Udvada, and then Mumbai.
The part they place is that black rubber thingie on the grey pipe. They cut the pipe and put it there. It is some sort of modulator.
I have booked an appointment for service in Mumbai, I will ask for details there.
ntomer is offline
