Old 6th May 2010, 23:19   #2251
sohail99's Avatar
Thanked: 235 Times
Whoa!! then I need to try collinite or wolfgang stuff!! might need to place a blind trust in 20north guys again!! (hate doing that)
btw I didn't use Blackfire, but had read some of their tutorials(with their products in it)
I just followed their steps with what I had available with me!
Their website is really impressive and really encourages you to try their waxes and sealants!
I'll try to get some other things over next few months and try them out!
sohail99 is offline
Old 9th May 2010, 15:32   #2252
Thanked: 368 Times
Watermark on rear window
Guys, have a small problem. My car has picked up watermarks only on the boot and rear window due to the car not being fully under the portico when it rained.
The boot is fine after a quick shampoo/rubbing compound/wax. However, the marks still remain on the glass window since i cannot use rubbing compound there. Two lines of trickled water can clearly be seen at night when another car behind you has his headlights on.
Any suggestions ? It has not gone after 2 shampoo washes.
Ash_vtec is offline
Old 9th May 2010, 17:42   #2253
sohail99's Avatar
Thanked: 235 Times
Try cleaning the spots with some vinegar!
this might help - http://www.team-bhp.com/forum/techni...dshield-2.html
sohail99 is offline
Old 9th May 2010, 23:13   #2254
I 2nd that, vinegar with water of course you can add a little priil or similar( If you add liquid handsoap it will be milder and more fragrant, use on interior glass also), that will give you the best glass cleaner and damn cheap, don't let it get on you clear coat though, it will be stronger than bird sugar!
stefanm is offline
Old 10th May 2010, 08:55   #2255
Thanked: 368 Times
@ Sohail & Stefan : Thanks for the prompt response used a 50:50 vinegar water solution and wiped it off with cotton wool. Works like a charm.
Ash_vtec is offline
Old 11th May 2010, 15:49   #2256
samsag12's Avatar
Thanked: 263 Times
Can anybody state whether this polisher is a good buy or not.
eBay India: Auto Car Polisher (item 180495019893 end time 17-May-2010 00:42:08 IST)
samsag12 is offline
Old 11th May 2010, 19:55   #2257
Thanked: 386 Times
The item looks great, I'll be satisfied if it helps my arms from buffing.
Will order one soon
akshay_b is online now
Old 11th May 2010, 21:05   #2258
benzinblut's Avatar
Thanked: 884 Times
Guys I bought Jopasu duster and its magic wipe last sunday. Thanks to mailmishra for sharing the contact of the salesguy. I bought the mini kit (car duster + magic wipe + shampoo) for 600 (MRP675). The products are nice and i think it will extent the shine on my car. The sales guy is Milind and I had a nice experience with him. Would like to share his contact with anyone if required. I also learnt that if we have a bigger order then we can get better discounts. So anyone looking to buy their products (around new mumbay), let us know here on the forum. BTW i would be interetsed in buying their hand glove mini duster.
I was looking for a foam buff pad for my buffing machine. Our Esteem is now 7yrs old and I think polishing it once would improve its looks a lot. I had been to a local paint shop and found one from 3M. Its the one the local mechanincs use for polishing. Was quoted 350 for it. My question here is
1) Is this the right price?
2) What would be a nice polish to be used with the machine? I am looking for mild polishes and I guess waxes with mild polishes would also do the job. Advice needed.
sohail, any experiences on the above?
benzinblut is offline
Old 11th May 2010, 21:20   #2259
Will order one soon
Please do post your reviews. However it seems it will be taking power from car battery. The only aspect of worry is it works on Car battery, not sure how effective it will be!
mailmishra is offline
Old 11th May 2010, 23:12   #2260
sohail99's Avatar
Thanked: 235 Times
Are you getting a foam polishing pad??(check out the attached pic!)
don't use wool pads as they cut like crazy!!
2. as you'll be using a rotary, I'd suggest the mildest(finest) polish possible!
as with a rotary, you cut through the clear quite quickly!
A DA polisher is safer(if you're machine polishing for the first time) as it cuts slowly and the risk of paint burn is minimum!
regarding the polishes, I have 'Sonax car polish' which states on its back label that 'Can also be used with polishing machine' (I bought it from Reliance Autozone)
I guess that'd work!
btw you've GOT to read this article before machine polishing! - Machine Polishing by Rotary Polisher - Full Guide - Detailing World
sohail99 is offline
Old 12th May 2010, 10:30   #2261
benzinblut's Avatar
Thanked: 884 Times
Thanks for the link there. Ill have to go through it on a sunday afternoon.
Unfortunately I do not have a DA polisher and will be using my rotary polisher.
The pad im talking about is a 3M foam pad. Similar to the picture but has a wavy surface (I hope you understand). I will be using this only for polishing. I was quoted Rs 350 for it. Is the price ok?
For polishing, I was considering this waxpol product: 2K RUBBING COMPOUND.
Suggestions and recommendations pls. I am looking for something mild and easily available in the market.
Old 12th May 2010, 10:43   #2262
sohail99's Avatar
Thanked: 235 Times
OK! I have an attached pic
btw the waxpol compound looks like it'd work!
for older paintwork, you might need a glaze to revive the shine(if its a dark color)
regarding the price, I have no idea! couldn't find any foam pads here(had to make my own! lol)
can you tell me from where you're getting them?
and here someone quoted like 750/- for the buffing pad alone!!
sohail99 is offline
Old 12th May 2010, 10:54   #2263
benzinblut's Avatar
Thanked: 884 Times
Yes. Thats how it looks. Its called waffle face. Its indeed 3M perfect it foam pad but in grey color. The only difference on the pad i saw was that its rear end (with the velcro) was flat like in your previous picture and unlike this. The size i found is perfect for my machine.
There is a correction, the price is Rs.450. I think thats fine because if you convert the cost in USD to INR, this price looks justified. I saw it at a paint and carcare product dealer in navi mumbai and its next to the many car detailing shops at sec19C Vashi. I was looking for a foam pad and my mechanic told me they got their products there.
The esteem is white. I think ill try the waxpol product. But that will not be before 2 weeks.
Old 12th May 2010, 11:45   #2264
mkh
Thanked: 135 Times
Got some stuff from the US, not much but some meguiars supreme shine, UQW and NXT liquid. Will be posting to those in order of prio who had requested
Had put a coat of NXT paste about 15 days back, served extremely well in the rains here.
Going slow on my car, as am going to sell it(have a good reason only) so feeling nostalgic when i go out to treat it! Wish the new owner will take good care of her, wish find such a buyer who values a well maintained car!!!
mkh is offline
Old 12th May 2010, 12:17   #2265
_raviShankar_'s Avatar
Thanked: 75 Times
I just saw the ad in the classifieds section after our conversation yesterday and was wondering why you were going to sell it off. Well the new owner will be lucky to get a well maintained beauty .
_raviShankar_ is offline
