Old 19th December 2010, 23:04   #4621
blackfire_9's Avatar
Thanked: 192 Times
^^ Ricky sir, he wasn't impressed with them & as per his post, they were removed within 3 days. Though he has still retained them with him due to the looks enhancement that these offered to the Tuscon.
Drive safe.
blackfire_9 is offline
Old 20th December 2010, 05:35   #4622
camchennai's Avatar
Thanked: 11 Times
Quick question to guru's
I have a 2004 Camry and I am not happy with the light dissipation, both low beam and high beam are very poor and the spread is very less. While driving in city, i have to put high beam since the road visibility is very poor.
Now the question is, it does come with HL adjustment but how do I check it is working. It has 5 settings however whenever I change it I don't see any level adjustment.
Anything can I do about this??
camchennai is offline
Old 20th December 2010, 09:08   #4623
prince_pervez's Avatar
Thanked: 53 Times
Question
Do we get Wheel well neons in India/BLR? I want to order from a website here and I was wondering if we get it in India.
prince_pervez is offline
Old 20th December 2010, 09:54   #4624
ilangop's Avatar
Thanked: 928 Times
Re: For those who think Linea Headlight is in adequate
Originally Posted by nitrous View Post
You're atleast gonna need strong holders or the factory ones that are made for 55 and 60 are gonna melt.
I'll guarantee that.
You are right nitrous. A Ceramic holder is a must. As well an external relay with its own higher capacity wiring harness would be the best. The OE wiring harness is made as per the ratings of the electrical load. Now that it has to carry twice as much current, better to go for an additional relay. In case one fears of losing warranty, this job can be got done from the dealer I guess.
ilangop is offline
Old 20th December 2010, 10:31   #4625
mjothi's Avatar
Thanked: 233 Times
All the above posters were right. I myself have seen a damaged headlamp of Optra in service station. That was the result of upgrading only the bulbs.
But again, it does not happen to everyone, chances are high.
I also know of Optra owners who still have it in this setup without issues in this very forum.
So, is it luck? Or duration of usage? Or others? No clue.
mjothi is offline
Old 20th December 2010, 10:49   #4626
naveen.raju's Avatar
Thanked: 9,485 Times
It does come with HL adjustment. To see the working, switch on the headlights and try adjusting it. See the video below. This shows the level adjustment in my Swift which also got projector headlights.
Try changing the bulbs to 4300k HID's. This will drastically improve the visibility.
naveen.raju is offline
Old 23rd December 2010, 10:48   #4627
funkykar's Avatar
Thanked: 6,883 Times
I wish to upgrade the lighting on my Fiat Palio Stile to 80W H7. Do we get ceramic holders for H7 in Bangalore? If yes, where and what would be the approximate cost?
funkykar is offline
Old 23rd December 2010, 11:01   #4628
praful's Avatar
Thanked: 759 Times
Ceramic holders for H7 are easy to get for H7. Should about 60-80 bux tops.
But if you plan on upgrading the Hi Beam i.e. H1's enjoy the treasure hunt to get a hold of ceramic holders for that. Took me close to 6 months to source H1 ceramic holders for my highbeam.
Btw, which 80W bulb are you upgrading to?
Is the Palio stile also following the same config H7-Lo Beam, H1-Hi beam?
praful is offline
Old 24th December 2010, 17:51   #4629
drpullockaran's Avatar
Thanked: 388 Times
If you are going above stock wattage then you will need a constant flow of wind over the plastic headlamps. This means you cannot use it in bumper to bumper traffic. The only option presently for the Chevy Cruze I have in tungsten bulbs of higher wattage are Hella 100/55 bulbs. The high beam to be used when there is good flow of air over the headlamps. The lows can be used as normal as its stock wattage. Unfortunately these are not available in India and I have ordered for a pair from Dubai. The other option is to go Philips Xtreme power or Xtreme vision or alternatively Osrams latest + rated bulb the Nightbreaker+ bulb and not the ordinary nightbreakers.
However the output from the Hella 100/55watts will be better. Take care not to use the 100 watts in crawling traffic.
drpullockaran is offline
Old 24th December 2010, 22:20   #4630
freakmuzik's Avatar
Thanked: 1,797 Times
Hello everyone,
I would like to upgrade the headlamps of my nano. The ones present in the car are not adequate at all. The specifications are : 12V 60/55W. Is there any other info that i should put in here? Please suggest an ideal upgrade.
freakmuzik is offline
Old 26th December 2010, 10:42   #4631
headers's Avatar
Thanked: 564 Times
Originally Posted by jeepster View Post
+1 to nitrous.
you will need some ceramic holders.
Strangely, back in 1993, I did upgrade my M800 DX from stock 55/60W to 90/110 and all i did was a suitable relay and wiring change.
Have driven that car over long distances in the night and never felt anything burn!! Have used that setup in that car for over 40,000 kms FYI.
And I dont think I used ceramic holders!
headers is offline
Old 26th December 2010, 16:37   #4632
Ashley2's Avatar
Thanked: 1,526 Times
I wish to Install a HID kit for my Swift VDi. Right now I have a stock bulbs along with Hella 500 series of fog lamps.
I enquired about the cost in JC road.
Osram H4 7000K - 7800/-
I also have some serious doubts regarding the HID kit.
Can the same white light been replicated with Philips blue vision.Is this a cheaper option.
Kindly guide me dudes
Ashley2 is offline
Old 27th December 2010, 09:39   #4633
The exact white light of the HID bulbs cannot be replicated with normal halogens bulbs. Although there will be a small difference in the color, the exact output cannot be expected. For this you will need HID's. I have used these kinda bulbs before. Now am using Auto Gauge HID's with Projector headlights.
HID's will be expensive. You could try out Auto Gauge or Philips, where Auto Gauge will be the cheaper option when compared to Philips.
Cheers.!
Old 27th December 2010, 11:30   #4634
motomaverick's Avatar
Thanked: 989 Times
All visions except for Essential Vision is of no use as they block quite a bit of the visible light. All the bulbs that we see coated with blue or gold color will obstruct some amount of light to give the desired light color.
HIDs can never be compared to Halogens as the tech is totally different. There is no filament in HIDs and hence, less heat.
If you have Hella 500 FF driving lights then that should suffice. Just this weekend had night drives for 430kms and the 90/100 did not feel inadequate. (I wear glasses so there is some more glare of oncoming vehicles)
motomaverick is offline
Old 27th December 2010, 12:28   #4635
BANDHAV's Avatar
Thanked: 2,999 Times
A noob question from my side, I have upgraded my Ritz's lighting system to 6k HID, but the heat generated by HIDs are damaging the upper portion of reflactor, what can be done about the same? Will fitting after market projector solve the problem? If yes, then from where can I source the projectors and at what price?
BANDHAV is offline
