Old 24th December 2010, 21:54   #3976
sagarpadaki's Avatar
Thanked: 6,848 Times
re: A superb Car cleaning, polishing & detailing guide
Here is my detailing armory.Will be getting megs UC soon.These will go on our beige i20 soon!
sagarpadaki is offline
Old 24th December 2010, 22:10   #3977
blackfire_9's Avatar
Thanked: 192 Times
^^ Hey mate, seeing your armory, I wanted to ask a doubt. What is the difference between the two car shampoo bottles from Sonax? One of them contains a light yellow coloured solution & the other one is orangish.
Drive safe.
blackfire_9 is offline
Old 24th December 2010, 22:21   #3978
rk_sans's Avatar
Thanked: 989 Times
Drive safe.
Yellow is Windscreen wash concentrate
Orange is Gloss Shampoo
I hope this will clear your doubts.
@sagar,
Let me know how is mother's clay bar. I have seen Meg's clay bar at action but want to know about mother's CB also. Please update after using it.
rk_sans is offline
Old 25th December 2010, 00:27   #3979
Thanked: 192 Times
^^ Thanks mate.
Drive safe.
Old 25th December 2010, 20:28   #3980
rk_sans's Avatar
Thanked: 989 Times
Detail gurus,
There is some white patches on the side plastic skirts on my i10 and this is because of my negligence on the initial days of detailing on my car. It is the tech wax on those panels. I tried using IPA but it was of no use.
Any other suggestions ?
rk_sans is offline
Old 25th December 2010, 22:05   #3981
mkh
Thanked: 135 Times
Originally Posted by rk_sans View Post
Detail gurus,
Just keep adding good plastic polish like Turtle Wax Platinum Series or Megs, nothing that i have seen can be done at all.I just keep them black enough, even i had done this mistake! Will be glad if someone can share something else
mkh is offline
Old 25th December 2010, 23:03   #3982
rk_sans's Avatar
Thanked: 989 Times
thanks @mk for the reply.
One more question, anybody of you tried Mother's clay bar ? Any reviews on it.
rk_sans is offline
Old 26th December 2010, 00:49   #3983
sohail99's Avatar
Thanked: 235 Times
Yup! that happens quite often(painters tape not easily available here for masking trim)
Wax deposition on textured plastic trim requires scrubbing that trim piece with a toothbrush(improvise) and a strong yet car safe cleaner(Degreaser or any paint and trim safe all purpose cleaner)
You can start with using a car wash shampoo in a spray bottle and a tooth brush and just scrub.
After you get it off, protect the trim with a good protectant like those mentioned by mkh!
To prevent that from happening in the future, dress the trim first and then apply sealant. That way, even if wax is applied there by accident, you'll be able to remove it easily!
@rksans - Mother's clay bar system is a real VFM kit and its got great reviews all over the detailing forums!
I too have that but I'm still not done with Megs clay!
sohail99 is offline
Old 27th December 2010, 08:19   #3984
Thanked: 658 Times
Hey Guys, I finally for my Kestrel DAS 6 DA Polisher. It has come with 6'' backing plate. This is the 1st time i will be using DA polisher. Now all i need is Foam pads which i did not buy before as there was confusion that they will give 6'' or 5'' backing plate. I am thinking of buying the lake country kit. Please let me know if this should be sufficient? 6.5'' polishing pads is a perfect fit for 6'' backing plate?
Amazon.com: Dual Action Deluxe CCS Foam Pad Kit: Automotive
Also please please invite me for next session of mini detailing meet, so that i could also start developing my basic skill set
shamanth is offline
Old 27th December 2010, 13:12   #3985
rk_sans's Avatar
Thanked: 989 Times
What is the difference between the Maroon/Red colored Meg QD which comes with Megs smooth clay kit and the regular black colored Meg QD ? Or is it the same in different colored bottle ? Or different series of product but same content ?
rk_sans is offline
Old 27th December 2010, 13:25   #3986
Garipagol's Avatar
Originally Posted by nirmaljusdoit View Post
Akshay - The clear coat was extremely hard & is definitely different from the other Merc's painted in India. The C class has much softer paint compared to this import. Youre right about the AMG badge, guess only the rims are from AMG !
To the best of my knowledge all Mercs use PPG Industries CeramiClear for clear coat as OEM product. Different models may have more or less layers of CC. Now you know why denting costs the earth !
Rgds
Garipagol is offline
Old 27th December 2010, 13:40   #3987
sohail99's Avatar
Thanked: 235 Times
^Nice to see you again!!(after quite some time!!)
So, how's UPGP holding up?
I have both, and clearly UQD(black bottle) is more easier to work with and leaves a very thin sealant coat behind(durability ~7 days is used on a properly prepped and pre-sealed paint)
The maroon bottle QD is a little less concentrated than UQD, but its ok for a surface cleanup if the car isn't dusty and is also good as a clay lube.
mild beading observed with it too but lasted not more than 2-3 days!
I wish I had bought UQD instead of that maroon QD bottle!
Now I use it on non critical paintworks and mostly as rim QD and clay lube!
sohail99 is offline
Old 27th December 2010, 14:52   #3988
rk_sans's Avatar
Thanked: 989 Times
Thanks Sohail. This clears my doubt. I have couple of bottles of UQD and i want to buy clay bar now and i was thinking why should i buy the whole Meg's clay bar kit ( which has a QD+clay bar + some sample clear wax). I can buy just the clay bar.
rk_sans is offline
Old 27th December 2010, 15:05   #3989
raghu230506's Avatar
Thanked: 64 Times
Any place in Bangalore where we can get the Clay Bar?
raghu230506 is offline
Old 27th December 2010, 15:27   #3990
rk_sans's Avatar
Thanked: 989 Times
I do not know if it is available anywhere in bangalore. But probably we can check with the 3M outlet which has opened if he has it. If not, then we need to go thru amazon or autogeek, etc.
rk_sans is offline
