Old 25th August 2012, 10:01   #6151
NOTORIOUS's Avatar
Thanked: 124 Times
Re: A superb Car cleaning, polishing & detailing guide
@ SDP ; Use light polish like sonax paint cleaner first , i am sure you will get rid of stains if not then use 3M finishing compound (Black container with purple cap) it is less abrasive then Rubbing compound and will clear out all scratches.
Please update After Use and please get a good body cover.
NOTORIOUS is offline   (1) Thanks
Old 25th August 2012, 12:19   #6152
HighOctane's Avatar
Thanked: 194 Times
Originally Posted by drsingh
Where can i buy something like this.? preferably in ludhiana/chandigarh?
Spot Polishing 4" Inch COMPLETE KIT (FOR USE WITH ANY DRILL OR ROTARY) : Amazon.com : Automotive
Just vist www.machpowertools.com you may find B&D and Bosch. Or in ebay, you get some cheap stuff which may not last long.
HighOctane is offline
Old 25th August 2012, 22:57   #6153
riturajsharma19's Avatar
Thanked: 199 Times
Originally Posted by shashank.nk View Post
Wash and shampoo the car on first day,do claying,polishing and sealant/waxing etc can be done on the 2nd day. Its easier on your body too
Thanks, however, I could manage washing, claying and half-polishing today. The remaining half of polishing and waxing is scheduled for tomorrow.
riturajsharma19 is offline
Old 26th August 2012, 12:07   #6154
sagarpadaki's Avatar
Thanked: 6,799 Times
One suggestion, before you attack the next day, clean each panel with a damp microfiber and wipe with a clean one before proceeding to remove any dust that would be accumulated over night.
sagarpadaki is offline
Old 26th August 2012, 13:12   #6155
Thanked: 40 Times
I suggest, it's better to give 24 hours of time before waxing. Hope you are using a good sealant after polishing.
My usual routine is wash and clay on Friday evening, entire polishing and sealant application on Saturday and waxing on Sunday . You will get time to relax.
toms_2191 is offline
Old 28th August 2012, 15:40   #6156
samsag12's Avatar
Thanked: 263 Times
If you're looking to buy applicator pads, here's a good deal i found,8 for 580 bucks including shipping!
Buy 2 Set-Meguiar's Gold Class Applicator Pad(Pack Of 4) Each - Autofresh
Mods: Just sharing a good VFM deal here, i'm in no way associated with the seller.
I doubt the quantity, its for 4 applicator pads i.e. 2 sets (Pack of 4). Quantity is also mentioned in the product description.
Here it is;
CLEAR COAT SAFE Meguiar's Foam Applicator Pad(4)4.5 inch reusable pads in a convenient polybag."
samsag12 is offline
Old 28th August 2012, 15:44   #6157
shashank.nk's Avatar
Thanked: 1,067 Times
A pack consists of 4 applicator pads and for 580 you get 2 such packs totalling to 8 applicator pads.
I'm sure of this as I ordered and got 8 for 580!
shashank.nk is offline   (1) Thanks
Old 28th August 2012, 15:51   #6158
samsag12's Avatar
Thanked: 263 Times
Thanks for clarifying though its strange, even i ordered them a month back with the same description but got only 4 pcs.
It seems they have updated the price too so that deal is sweet
samsag12 is offline
Old 28th August 2012, 15:53   #6159
When I ordered and going by the rather confusing description I thought its a set of 2 and each pack contains 2 applicator pads,totalling to 4 pads in all.
Was surprised when I opened the package and found 8 ! Looks like I won't be needing applicator pads for a long time
Old 28th August 2012, 16:04   #6160
Thanked: 199 Times
My DIY detailing session over the weekend went off quite well. However, here's where I messed up. There is one place where I didn't properly buff off the Meguiars Swirlx that I had used and applied sealant over it. Dried polish marks are visible through the wax layer on top but can't be removed. Now, how do I deal with the situation? Do I clay over the area and apply SwirlX again? Experts, please suggest a remedy.
Old 29th August 2012, 00:09   #6161
Gurus please help!
I detailed my car on 14th August, using BF combo after claying the car. On 19th my had a massive fuel leak and was with the A.S.S till today.
Its been raining very heavily in bangalore over the last few days and my car was parked in the open exposed to the rain at the workshop.
Today when I cleaned the car using the duster I noticed that the smoothness is no longer there like before, especially the hood and side panels.
Will a coat of Blackfire wet diamond paint sealant on the existing surface suffice ?
Old 29th August 2012, 07:57   #6162
mkh
Thanked: 135 Times
Gurus please help!
Should be ok, the "smoothness" does not remain for more than 5-6 water washes, but that does not mean sealant protection is non existent. Check for water beading. However we do love the smoothness, do go ahead and apply. Multiple coats are good too, with a gap of 12-24 hours.
mkh is offline   (1) Thanks
Old 29th August 2012, 08:15   #6163
Chris_Xtreme's Avatar
Thanked: 35 Times
Originally Posted by WindRide
Rubbing compound has abrasives in it, like liquid sandpaper? wont it take away the finish?
I had experienced the same in my black WagonR and used Wurth's fine rubbing compound followed by a brief polishing using Wurth's paint restoration polish. Since the intensity of the scratch was not too deep, it disappeared. To answer to your question, once you use a rubbing compound, a coat of polish will bring back the finish.
Chris_Xtreme is offline
Old 29th August 2012, 09:51   #6164
Thanked: 714 Times
My DIY on? Do I clay over the area and apply SwirlX again? Experts, please suggest a remedy.
You can use some iso propyl alcohol to remove the remaining residue or you can even use some more Swirl X & get it out. Apply sealant to affected area once more.
nirmaljusdoit is offline   (1) Thanks
Old 29th August 2012, 11:35   #6165
Another query i had, does dragging a car cover on the surface leave micro scratches or swirls ?
A certain amount of dragging is inevitable I guess. Any tips on how to use one safely then ? I make it a point to dust the car with Jopasu duster before the cover goes on.
