Old 28th December 2015, 12:01   #9541
SunnyBoi's Avatar
Thanked: 4,462 Times
Originally Posted by TorqueyTechie View Post
3. Would going for HID's is right or should I go with LED's?
Something for you to ponder
Auto Lighting thread : Post all queries about automobile lighting here-img_20151205_0904212001.jpg
Auto Lighting thread : Post all queries about automobile lighting here-img_20151205_1504172001-copy.jpg
A video made when testing /aiming the light.
SunnyBoi is offline
Old 28th December 2015, 12:24   #9542
Thanked: 2,431 Times
Thanks sunnyboi. Did you get this done because of difficulty in setting up HID's? How much did this setup cost you? I would keep this as my last option if I am unable to replace the OEM lights.
TorqueyTechie is offline
Old 28th December 2015, 19:45   #9543
Thanked: 290 Times
How is the HID for a swift recommended and what specs
Dieseldunk is offline
Old 29th December 2015, 16:38   #9544
Aston Singh's Avatar
Thanked: 176 Times
Anyone using Philips H4 Heavy Duty Relay Wiring Kit 12003XM ?
It's available on Amazon for just under a 1000 bucks.
Currently using stock fog lamps (useless ) and Philips Xtreme vision H4s (quite decent). Planning to switch to 100/90W with Philips relay and H11 55W fogs instead of stock H8 35W.
Any valuable feedback/suggestions would be highly appreciated. Thanks in advance!
Aston Singh is offline
Old 29th December 2015, 17:43   #9545
noelnelly's Avatar
Thanked: 135 Times
I'm using the Philips H4 Wiring Kit in my Amaze with Philips Rally 100/90 W bulbs and the lighting is superb although I remember buying the Wiring Kit for some 700 odd rupees from Opera House in Mumbai, around a year ago. Try asking around at auto parts store and you might get it cheaper.
noelnelly is offline   (1) Thanks
Old 29th December 2015, 19:29   #9546
rakesh_r's Avatar
Thanked: 3,473 Times
After five years the left side bulb (Philips Rallye) low beam conks off. Went to my trusted electrical guy and replaced both the headlamps with Osram Bilux Rallye 100/90 bulb (Made in Germany ones).I guess 5 years was quite decent life for a light bulb considering the extensive night drives i had done.Yet to test how effective the bulbs are.
rakesh_r is offline
Old 29th December 2015, 21:53   #9547
Geo_Ipe's Avatar
Thanked: 3,708 Times
Is it possible for me to upgrade my Santro Xing's fog lamps to 55W? What all would be necessary?
If not, can someone recommend a reliable brand of aux lamps, which are not too huge, yet VFM?
Geo_Ipe is offline
Old 30th December 2015, 09:36   #9548
sgiitk's Avatar
Thanked: 4,809 Times
Have you considered using HIDs. Even 35W 2700K will do. make sure you get a good ballast - AC, preferably Hyaluxtek. I replaced the Fogs in my Civic with 55W 3000K units and they are working like a dream.
sgiitk is offline
Old 30th December 2015, 09:42   #9549
ant_vas's Avatar
Thanked: 794 Times
Was browsing for fog lamps for my Punto and found they are now available in LED from Osram!
http://www.epitstop.in/DRL-s-and-LED...d-1998893.html
Unfortunately my punto active model doesn't come with fog lamp setup so buying these LED fog lamp bulbs won't help me!
Last edited by ant_vas : 30th December 2015 at 09:48. Reason: had posted the wrong link
ant_vas is offline
Old 30th December 2015, 09:49   #9550
sgiitk's Avatar
Originally Posted by ant_vas View Post
Is it recommended to use HID's in a car without the projector setup? won't it be dangerous to the oncoming vehicles?
How about a simple halogen bulb like Philips Xtreme Vision Plus H4 which claim to give 130% more light? Found them on ePitstop.in:
http://www.epitstop.in/Upgrades/Phil...d-1917113.html
The fogs are designed for diffuse lighting, so blinding is not an issue. Yes, I am using Osram NB+ in my Brio, with good results, but then again the light is 'colder'. not so good for fogs. My son has HIDs in his City but in projectors!
sgiitk is offline
Old 30th December 2015, 21:26   #9551
Thanked: 1,843 Times
Attachment 1453912
Could you share the details of the light bar, like wattage, size and landed cost?
Sridhar
sridhar-v is offline
Old 31st December 2015, 00:27   #9552
SunnyBoi's Avatar
I have 4 projectors with me to try a quad projector setup. SOmewhere down the line I lost interest and bought the Lightbar instead.
Its a 210W 20inch lightbar. Cost me 120$ from aliexpress and it has Osram LEDs.
Anyways, I bought a pair of Xtremevision +130 bulbs from eBay at good discount. OXIGENDEC4 coupon gives 30% off with max discount of Rs 250. I ordered one bulb and asked a fellow BHPian to order the second bulb. So in total got 500rs off for the pair. Not bad. Let's see how these bulbs fare.
Auto Lighting thread : Post all queries about automobile lighting here-130.jpg
SunnyBoi is offline   (1) Thanks
Old 7th January 2016, 20:28   #9553
condor's Avatar
Thanked: 16,902 Times
Looking for the dust caps from the headlight of the Vista / Manza. This would be the ones from the double-barrel headlamps ..
Appreciate any help in sourcing the same.
condor is offline
Old 8th January 2016, 21:03   #9554
Darth Sid's Avatar
Thanked: 119 Times
I have ordered these already for my Swift.
I expect the light to be near white but not white as it is 3400K.
Anurag, are you sure about those H11's? I don't think they would be plug and play. We are talking about over 40% extra current drain here. I wonder if the stock wiring can take the extra load reliably. Even I wanted to make the upgrade but don't want to make another relay harness. It took me an hour to remove the headlight harness, horns mounted behind the radiator grill and associated wiring before getting my car's 2nd service done.
But still, I was disappointed with the light quality. The Osrams are nowhere close to the Rallys(german made) on my SX4.
The WagonR earlier had Philips 60/55(german) made and this 100/90 from Osram gave very minimal improvement.
Are the Osrams that inferior? The Philips Rally that I had bought were not German made and had started to fog up on the inside with minimal use as had the stock Indian made Osram bulbs. The Osram Rallye are pretty good but I haven't seen German/Polish made 100/90W Philips bulbs' performance yet.
Originally Posted by Unavowed_X9 View Post
you could also try the 100/90 W Philips Premium Vision. They are awesome...
Do you have a link to where these could be bought from? Am curious.
replaced both the headlamps with Osram Bilux Rallye 100/90 bulb (Made in Germany ones)...Yet to test how effective the bulbs are.
Have you had the chance to test the bulbs yet? How did you find the performance?
Do you have a link to the item or the seller? How is this seller? Am interested in smaller light bars/pods.
Darth Sid is offline
Old 9th January 2016, 19:07   #9555
Screwdriva's Avatar
Thanked: 532 Times
CIAZ: HID Xenon Upgrade in Mumbai
After researching for ages, I'm happy to report that my newest car, our Maruti Ciaz ZDI+ has received its first non-OEM upgrade. Say hello to the RSR 4300K (also available in 6000K) HID kit, courtesy Rishi from Sainath Ultimate, Khar. Pics attached!
The MRP is 9K but was able to get it for Rs 6K with a 1 year (If he doesn't honor the price, I'd reference TeamBHP). The guy is extremely knowledgable about L.E.D's and has parts imported from all over the place. (The bulb in the picture, an OSRAM, was important from Germany and costs Rs. 2000/- a set. Ouch!)
On a side note, I also purchased a set of Philips LED driving headlights for my Yeti (HID's won't work on the car). Amazing stuff though not quite as powerful as a HID Xenon upgrade despite being twice the price!
Auto Lighting thread : Post all queries about automobile lighting here-img_9130.jpg
Auto Lighting thread : Post all queries about automobile lighting here-img_9131.jpg
Screwdriva is offline   (1) Thanks
