Team-BHP > Motorbikes
Old 17th January 2020, 15:41   #1621
shabih's Avatar
Thanked: 424 Times
Re: Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin
Originally Posted by amrutmhatre90 View Post
Attachment 1957935
Attachment 1957936
These are dealer level customization. Check the comments. But it does look dope and fab. Silencers are SS which are official accessories sold at some places.
I would envy if this thing pulls next to my Silver INT on a stop light
Source
I wish they had painted the engine black as well, that would have given true run for its money to Street Twin.
shabih is offline
Old 17th January 2020, 16:21   #1622
amrutmhatre90's Avatar
Thanked: 2,731 Times
Same thoughts bro, 1st thing when I saw the image was the engine casing.
All in all. Twins are really doing well for RE. And kudos for the team to make such a product at an attractive price.
My cousin who was a die hard RD350 fan till now is on a verge of booking the INT.
amrutmhatre90 is offline
Old 18th January 2020, 00:17   #1623
swiftnfurious's Avatar
Thanked: 9,792 Times
Probably once the BS6 conversion is done, they'll get us a Himalayan 650? I'd be very interested in that.
swiftnfurious is offline   (1) Thanks
Old 18th January 2020, 08:20   #1624
Red Liner's Avatar
Thanked: 19,315 Times
Not any time soon. It needs a whole new frame, and i will be damned if i buy it within the first two years of launch. Expect one sometime in 2022/23.
It will also be way heavier than most other 650's in the market. The interceptor is already what, 220?
Not for me.
Red Liner is offline   (1) Thanks
Old 18th January 2020, 15:27   #1625
It will also be way heavier than most other 650's in the market. The interceptor is already what, 220?....
If the improvements and learnings they had from Interceptor is to go by, may not be a very bad deal unlike other launches.
I have seen Interceptors belting at 140 kmph, seems quite capable even if heavy.
Old 18th January 2020, 16:26   #1626
Red Liner's Avatar
To go offroad, not on the highway exclusively.
Old 18th January 2020, 22:27   #1627
Thanked: 837 Times
Thrissur-based ‘Legundary Custom Built is offering after market belt drive system for Royal Enfield Interceptor 650. The chain kit is replaced by the belt drive which they claim improves transmission efficiency. Cost 15,800 with three year replacement warranty.
https://www.rushlane.com/royal-enfie...-12349116.html
Sarvodaya is offline   (2) Thanks
Old 19th January 2020, 00:08   #1628
isldhn's Avatar
Thanked: 148 Times
You mean like this :-). Hehehe, i know, i know, I’m a show off, but just couldn’t miss taking you guys views on this work in progress.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-4063cc126e234cf783715cc35b3fdd03.jpeg
isldhn is offline   (10) Thanks
Old 19th January 2020, 11:06   #1629
TheParsiStig's Avatar
Thanked: 58 Times
Wouldn't recommend it as belt drive is known to be slightly heavier and hence lesser wheel horse power. Stick to good old chain drive.
TheParsiStig is offline   (1) Thanks
Old 19th January 2020, 11:43   #1630
Thanked: 837 Times
They are claiming 44 bhp at wheel versus 39 bhp with chain after dyno test. Expensive. You can get four chain kits 80,000 kms usage.
Sarvodaya is offline   (1) Thanks
Old 19th January 2020, 13:39   #1631
Thanked: 6,658 Times
Hi, this is your guardian angel from the future with a very important message.
Neither you nor 'Legendary Customs' are as equipped as the collective heads of the manufacturers R&D department.
So leave the chain as is and dodge the headaches that you'd surely face going for alternatives.
You could use the money to actually buy fuel and ride the motorcycle to places as should be intended, what say?
P.S. If you do some research about such conversions and the feasibility of running niche technology to far away lands, you'd understand why I'm recommending against such jugaad's.
Cheers.
A.P.
ashwinprakas is offline   (16) Thanks
Old 19th January 2020, 15:30   #1632
Thanked: 113 Times
I wanted higher, narrower handlebars so fitted a Honda Unicorn BS4 handlebar because it has the width I wanted and the maximum height that can be fitted without changing brake hose and cables.
Fitting was straightforward apart from having to drill a locator hole for the throttle/brake body clamp. The handlebar clamps are wider on the Interceptor than the Unicorn so some knurling is exposed (photo). The Interceptor bar end protectors do not fit and the Unicorn ones are too weak to be any use so I left the bar ends open.
Incidentally there was a useful weight reduction (any weight reduction is useful!).
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20200115_121719-25.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20200115_121749-25.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20200115_121806-25.jpg
Mod Note : It is imperative for you to upload pictures directly to the Team-BHP Server. Click here to view our pictorial help article on uploading pics.
Please submit images ONLY via the Team-BHP Attachment System.
Last edited by Aditya : 20th August 2020 at 20:26. Reason: Inserting replacement images
catkins is offline   (6) Thanks
Old 19th January 2020, 18:34   #1633
Thanked: 1,590 Times
Dubious claim. Belt drives have various advantages over chain drives, such as lower noise, lower maintenance, lower stretch. But higher efficiency is not one of the benefits. Belt drives have a higher power loss compared to chain drives.
So their claim of greater power at wheel must be taken with scepticism.
Motard_Blr is offline   (1) Thanks
Old 19th January 2020, 22:52   #1634
Thanked: 176 Times
This is true for flat belts and v-belts, where the belts are susceptible to slippage. The toothed belt (or) synchronous belts used in motorcycles are highly efficient (slightly more than chain drives as they are lighter and less mechanical friction).
However, as others mentioned earlier the R&D folks at RE know better and it is not wise to change such critical components.
knaveen is offline   (2) Thanks
Old 20th January 2020, 11:07   #1635
nasirkaka's Avatar
Thanked: 4,365 Times
Sir, thats your Versys 650 weight playing on your mind. Himalayan Is not that bad, Kerbing at approx 182 odd kgs. I dont mind a 650 Himalayan if they can keep it sub 210 as the 650 engine and gear box is an art of engineering. Advantage i see it over conventional 650 imports is cheap cost of repairs even if we drop is a few times. AND it will not be way heavier then most other 650s as long as benalli trk 500 is there. Wait, its not even a 650.
No! No!! Not there. Try and reduce weight elsewhere, but handlebar WEIGHTS are given for a reason.
nasirkaka is offline   (2) Thanks
